Solving a Differential Equation Conflict
  • Thread starter Thread starter gulsen
gulsen
I have a basic differential equation:
\frac{dy}{dx} = x + y, y(0) = 1
Now, when I try to solve this by making it exact
\mu \frac{dy}{dx} + \mu y = \mu x
I get \mu = e^{-x} and solution -x-1. This doesn't satisfy the initial condition. But when I try to solve it as a non-homogenous equation as:
\frac{dy}{dx} + y= x
I get
y_p = 2e^x, y_c = -x-1
so
y = 2e^x-x-1
Which seems to be a correct & full solution. What was I missing in the first try?
You are solving dy/dx + y = x which is wrong since the original equation is
dy/dx = x + y, or dy/dx - y = x so now u(x) = e^(-x) and so on and it works out.
And yes, the answer is y = 2e^x - x - 1
I assume this was just a typo, but that equation should be
\mu \frac{dy}{dx} - \mu y = \mu x
Your error: you forgot the constant of integration. You should have obtained
y = -(x+1) + c/\mu = ce^x - (1+x)
and then solved for the initial condition y(0)=1 yielding c=2 or
y = 2e^x -(x+1)
I get
so
y = 2e^x-x-1
You're nomenclature is backward here. The solution to the homogeneous equation is called the complementary function and is denoted as y_c. The complementary function generally involves arbitrary constants. A solution to the inhomogeneous equation is called a particular function and is denoted as y_p.
In this case, the solution to the homogeneous equation y^\prime-y=0 is
y_c = ce^x
where c is an arbitrary constant and
y_p = -(x+1)
is a particular solution to the inhomogeneous equation. Combining these,
y = ce^x - (1+x)
which meets the initial conditions when c=2.
Oh, that was just a typo. Thanks D_H, it ends up that I've forgotten the integration constant.
About naming, take it easy, I'm just a freshman!
