Discover How to Measure Laser Wavelength with Modern Physics - HELP 911
  • Thread starter Thread starter kizersi5
The discussion focuses on deriving formulas for measuring laser wavelength using interference patterns. The key equations presented are (1) λ = 2 * dm/m and (2) m = (n-1) * (2 * d/1) * (Dp/Patm), where dm represents the distance moved by a mirror, m is the number of fringes, Dp is the pressure difference, d is the distance of the vacuum air cell, and Patm is the atmospheric pressure. The process involves splitting a monochromatic beam at a half-silvered mirror, creating two beams that interfere at a point O, resulting in observable fringes. Understanding these principles is crucial for accurate wavelength measurement in laser applications.
  • Understanding of laser physics and interference patterns
  • Familiarity with optical components such as beam splitters and mirrors
  • Knowledge of pressure measurement and its impact on optical experiments
  • Basic mathematical skills for deriving and manipulating equations
  • Study the principles of optical interference and fringe formation
  • Learn about laser wavelength measurement techniques, including Fabry-Pérot interferometry
  • Explore the effects of atmospheric pressure on laser experiments
  • Investigate advanced optical components and their applications in wavelength measurement
Students and professionals in physics, optical engineering, and anyone involved in experimental laser applications will benefit from this discussion, particularly those focused on precise wavelength measurement techniques.
kizersi5
:!) :confused: My problem is that I am required to derive such formulae, which are:
MEASUREMENT of the LASER wavelength.
(1) 1 or lamda = 2* dm/m & (2) m=(n-1) ( 2*d/1)*(Dp/ Patm)
dm= distance of the movable mirror moved toward a beam splitter.
m= no. of fringes that cross a given reference point.
Dp = Pressure(final)- Pressure(initial)
d= distance of the vacuum air cell that was used upon experiment to generate fringes
Patm= atmospheric pressure=760atm.
I would appreciate any help deriving these formulae in step by step way.
A monochromatic beam (1) entering from the left splits up at B, a half silvered mirror, into two beams (2) and (3) and is reflected back by two mirrors. Beam (2) continues onwards to O and on its return (3) is reflected downward also to O (part of both beams actually since the mirror is half silvered). At O the beams are combined optically resulting interference of the two beams. If the paths of the two beams , (2) and (3), are the same length constructive interference will result at and a bright fringe will be observed at O. If the movable mirror is moved [itex]\frac{\lambda}{4}[/itex] closer to the beam splitter this condition will change to destructive interference. If the mirror is moved by [itex]\frac{\lambda}{2}[/itex] one fringe change will be observed at O. This gives you your first equation.
