What is the Definition of d(a^x)/dx?
  • Context: Undergrad
  • Thread starter Thread starter G01
    Definition
The discussion revolves around the definition of the derivative of the function f(x) = a^x, specifically focusing on the limit involved in calculating the derivative and the interpretation of that limit in relation to f'(0).
  • One participant expresses confusion about the limit involved in the derivative calculation, questioning why the limit equals f'(0).
  • Another participant points out an error in the first post regarding the sign in the numerator of the limit expression and clarifies that the correct limit relates to f'(0).
  • The same participant suggests substituting 0 for x in the derivative expression to understand the relationship between f'(x) and f'(0).
  • A later reply indicates that the clarification provided was simpler than initially thought, suggesting a resolution of confusion but not necessarily agreement on all points.
Participants do not fully agree on the initial interpretation of the limit, as one participant identifies an error in the formulation. However, there is a shared understanding that the limit relates to the derivative at zero.
There are unresolved aspects regarding the interpretation of the limit and the implications of the derivative's definition, particularly in how it connects to f'(0).
G01
Hey. I'm having trouble understanding part of the definition of this derivative. Any help will be appreciated.
[tex]f(x)=a^x[/tex]
Using the definition of a derivative, the derivative of the above function is:
[tex]f'(x) = \lim_{h \rightarrow 0}\frac{a^{x+h} + a^x}{h} =[/tex]
[tex]\lim_{h \rightarrow 0} \frac{a^x(a^h - 1)}{h}[/tex]
Since a^x does not depend on h it can be taken outside the limit:
[tex]f'(x) = a^x \lim_{h \rightarrow 0} \frac{a^h-1}{h}[/tex]
Now here is where I get confused. The text tells me that:
[tex]\lim_{h \rightarrow 0} \frac{a^x(a^h - 1)}{h} = f'(0)[/tex] (1)
If that is true then [tex]f'(x) = f'(0)a^x[/tex], but I have no idea why equation 1 is the way it is? How is that limit equal to f'(0)?:confused:
[tex]f(x)=a^x[/tex]
Note:
[tex]\lim_{h \rightarrow 0} \frac{(a^h - 1)}{h} = \lim_{h \rightarrow 0} \frac{(a^{(0 + h)} - a^0)}{h} = f'(0)[/tex]
You've made some errors. In the second line, you should have a minus sign, not a plus sign in the numerator. Equation (1) should read:
[tex]\lim _{h \to 0}\frac{a^h - 1}{h} = f'(0)[/tex]
You already have the equation:
[tex]f'(x) = a^x\lim _{h \to 0}\frac{a^h - 1}{h}[/tex]
Substitute 0 for x, and recognize that [itex]a^0 = 1[/itex], and you'll see why the equation for f'(0) holds.
Ahhh icic that was simpler than i thought. Thank you.
  • · Replies 22 ·
