How Much Dry Steam Is Required to Melt Ice in an Open System?
The discussion centers on calculating the amount of dry steam required to melt 450 kg of ice at -18 degrees Celsius in an open system, with the final effluent temperature set at 5 degrees Celsius. The user, Chopper, identifies the need to calculate the energy required to raise the ice temperature and equate it to the energy lost by the steam as it cools. The approach involves using algebra to set up an expression for the heat needed to raise the ice temperature and the heat lost by the steam, ultimately solving for the mass of steam required.
  • Understanding of open and closed thermodynamic systems
  • Basic principles of thermodynamics, specifically heat transfer
  • Knowledge of specific heat capacity and phase change energy calculations
  • Familiarity with algebraic expressions and equations
  • Research the specific heat capacity of ice and steam to perform accurate calculations
  • Learn about the enthalpy of fusion for ice and the enthalpy of vaporization for steam
  • Study the principles of energy conservation in thermodynamic systems
  • Explore practical applications of steam in heat transfer processes
This discussion is beneficial for students and professionals in thermodynamics, mechanical engineers, and anyone involved in heat transfer calculations or studying open system dynamics.
chopper
I need a kick start for the following question. We're studying open/closed systems at the moment.
"450kg of ice at -18 degrees C is to be removed from a freezer using a jet of steam. How much dry steam at 100 degrees C is required if the final temp of the effluent is 5 degrees C?"
This is what I've sussed out so far.. because mass is being added to the system (the mass of the steam) I assume this is an open system problem. I haven't been given any information regarding enthalpy of either the ice or the steam so I'm assuming it's a simple matter of working out how much energy I need to bring the ice up to 5 degrees and introducing that energy into the freezer in the form of steam that will be giving up energy as it cools down to 5 degrees.
Can anyone point me in the right direction?
Cheers
Chopper
It should be a simple matter of algebra. Just set up the expression for heat h needed to raise the temperature of 450 kg of ice to 5 degrees and the heat lost by a mass m of stream. Equate the two and solve for m.
AM
  • · Replies 17 ·
  • · Replies 16 ·
