Understanding Isotopic Spin in Standard Model Doublets: Electron or Neutrino?
  • Context: Graduate
  • Thread starter Thread starter Ruslan_Sharipov
    Spin
The discussion revolves around the concept of isotopic spin in the context of the Standard Model, specifically focusing on the doublet formed by the electron and the electron neutrino. Participants explore the implications of gauge transformations on the wave functions of these particles and their physical interpretations.
  • Some participants propose that the wave function of the electron-neutrino doublet can be expressed as a combination of both particles, with the possibility of describing either state depending on the values of the components.
  • One participant argues that from the perspective of weak interactions, the electron and electron neutrino are two states of the same particle, similar to spin states of an electron.
  • Another participant questions the physical significance of gauge transformations, suggesting they are merely mathematical constructs and inquiring how they affect the states of the particles.
  • It is noted that the weak interaction can change an electron neutrino into an electron and vice versa through the emission or absorption of W bosons.
  • Concerns are raised about the mass of particles in a multiplet, with a participant pointing out that they should have the same mass, which leads to a humorous acknowledgment of the Higgs mechanism.
  • Some participants clarify that gauge transformations do not affect physical states or observables but act on fields that are not directly observable.
Participants express differing views on the role and implications of gauge transformations, with some asserting their mathematical nature while others question their physical relevance. There is no consensus on the interpretation of the doublet and the effects of gauge transformations on particle states.
The discussion includes assumptions about the nature of gauge transformations and their effects on particle states, which remain unresolved. The relationship between mass and particle states in multiplets is also touched upon but not fully explored.
Ruslan_Sharipov
Some elementary particles in Standard Model are grouped into doublets, e. g. electron and e-neutrino (both left). As to me, the wave function of such a doublet should be
[tex] \psi^{ia}=\left(\begin{array}{c}\nu^a \\ e^a \end{array}\right)[/tex]
where [itex]i=1,2[/itex] and [itex]a[/itex] is a spinor index. In other words it is composed of electron and neutrino components. If [itex]nu^a=0[/itex], it is a pure electron wave function, and if [itex]e^a=0[/itex] it is a pure nutrino wave function. However, performing an SU(2)-gauge transfoprmation, I can mix the components of the doublet. My question is what particle I actually describe - an electron or a neutrino?
You describe both. That's the whole point: from the ''point of view'' of the weak interaction, the electron neutrino and the electron are two states of the same particle. They really are very similar to the spin up and spin down states of the electron, except that we don't give different particle names to the spin up and down of the electron. The weak interaction changes an electron neutrino into an electron and vice versa (through the emision or absorption of a W+-) as the elctromagnetic interaction may flip the spin of an electron.
Hope this makes sense.
Patrick
gauge transformation is not a physical process.
nrqed said:
The weak interaction changes an electron neutrino into an electron and vice versa (through the emision or absorption of a W+-).
Well, I understand that if W+- is absorbed or emitted, then electron/neutrino states could change. My question was about a gauge transformation which is a purely mathematical trick.
Why (and how) it changes electron/neutrino states?
Ruslan.
But all the particles in a multiplet commuting with Poincare should have the same mass... Oh wait, they have: they are both massless.
Ruslan.
The gauge transformation doesn't affect the states, nor the observables, it acts only on fields, classical/quantum, which are not really observable.
Daniel.
P.S. Think about the EM field. Do we measure [itex]A_{\mu}[/itex] ...? (which is affected by a U(1) gauge transformation)
Yes..thanks Higgs!:biggrin:
  • · Replies 18 ·
  • · Replies 23 ·
