Cant find an appropriate fluids equation
  • Thread starter Thread starter ben.herbener
    Fluids
The minimum power required to pump blood in the human body, given a total average pressure rise across the heart of 120 mm Hg, is calculated to be 1.49 watts. This calculation is based on a heart rate of 80 beats per minute and a stroke volume of 70 ml, resulting in a volumetric output of 336 liters per hour. The discussion emphasizes the importance of understanding fluid dynamics in biological systems, particularly in relation to cardiovascular physiology.
  • Basic understanding of fluid dynamics
  • Knowledge of cardiovascular physiology
  • Familiarity with pressure units (mm Hg)
  • Ability to perform power calculations in physics
  • Research the Bernoulli equation and its applications in biological systems
  • Explore the relationship between heart rate and cardiac output
  • Learn about the effects of pressure on fluid flow in the circulatory system
  • Investigate the role of stroke volume in determining cardiac power output
Students and professionals in the fields of biology, medicine, and physics, particularly those interested in cardiovascular mechanics and fluid dynamics.
ben.herbener
Hi guys this is my first post on here, and I like the look of it so far. I've tried to look everywhere for an approprate equation for this question but I can't come up with one, or maybe I am overlooking something.
What is the minimum power (W) required to pump blood in the human body? Assume a total average pressure rise across the heart of 120 mm Hg.
Given: 80 beats per minute, stroke volume of 70ml, volumetric output is 336 liters per hour.
Thanks,
Ben
Hi Ben,
Welcome to Physics Forums! It is our policy not to simply give out the answer, but I will give you a good page to help you get started: http://www.rwc.uc.edu/koehler/biophys/3a.html
Let me know if you have any more questions.
Thank you very much for that link it was very helpful. I didn't expect a straight out answer, I was just quoting the problem exactly.
I got 1.49 watts, which sounds about right.
Thanks,
Ben
