Did the core of the Earth collide with the Earth billions of years ago?
  • Thread starter Thread starter verdigris
    Core Earth Years
The discussion centers around the hypothesis of whether the Earth's core originated from a collision with a large body in outer space or if it is an intrinsic part of the Earth itself. Participants explore the implications of such a collision on the formation of the Earth and the Moon, as well as its potential role in initiating plate tectonics. The conversation includes theoretical considerations, geological evidence, and the mechanics of celestial impacts.
  • Some participants propose that the core of the Earth may have come from outer space, suggesting that the volume of the Moon and continental rocks should equal the volume of the core, implying a significant impact event.
  • Others argue that all mass of the Earth originated from outer space, but they question the specifics of a large iron core impacting the Earth.
  • There is a suggestion that a collision would have melted the Earth rather than fractured it, and that plate tectonics could have started without such an impact.
  • Concerns are raised about the precise angle required for a collision to avoid catastrophic consequences, making such an event seem unlikely.
  • Some participants agree that while early impacts contributed to the core, a large ball of iron did not directly collide with the Earth to form the core.
  • Evidence is presented against the core colliding with Earth, including the expectation of water being ejected into space, which does not align with current observations of deuterium levels in Earth's oceans.
  • There is speculation that the Earth and Moon formed side by side in space, rather than through a collision, with some suggesting that the Moon preserves records of early impacts.
  • Participants discuss the mechanics of the Moon's formation and the implications of a collision on the Earth-Moon system's orbit, questioning how such an event would affect the resultant momentum vector.
Participants express multiple competing views regarding the origin of the Earth's core and the role of collisions in the formation of the Earth and Moon. There is no consensus on whether the core originated from a collision or if it is an intrinsic part of the Earth.
Some claims regarding the age of the core and the mechanics of celestial impacts remain unverified, with participants requesting references for certain statements. The discussion reflects a range of assumptions and hypotheses that have not been conclusively resolved.
verdigris
Does the core of the Earth belong to the Earth or did it come from outer space and collide with the Earth.In this scenario the volume of the moon added to the volume of the continental rocks should equal the volume of the
core ( the collision would have displaced material from inside the Earth).And could such a collision have fractured the Earth's surface starting plate tectonics?
ALL of the mass of the Earth came from "outer space".
I'm not too familiar with the theory of collision of a large body with the early earth, but I thought that the theory went that the Earth was pretty much melted, rather than fractured. Plate fracturing doesn't seem to need any impact to start it off today, so I doubt that it would be nessecary on the early crust, which was most likely quite a bit thinner.
The collision would have had to have been at a precise angle or else the extra momentum imparted to the Earth would have made it leave the solar system or go into the Sun.This makes a collision on this scale seem unlikely in itself.
Well I think it would probably be agreed that some of the core came from early impacts, if you're suggesting that we were hit by a large ball of iron that eventually found its way down to the centre of the Earth then no, that didn't happen.
A large impact would have melted (some of) the Earth by the mechanism of decompressional melting, caused by a phase of decompression immediately following the impact. It is actually thought that this would cause a plume in the upper mantle, perhaps somehow this helped get plate tectonics going?
Any large collision that an iron core could have had with the Earth to cause the moon to form would have had to have taken place more than 3 billion years ago (water has been on Earth for 3 billion years) or else we would expect there to be a lot of water removed from the Earth on the moon and floating around in the path of Earth's orbit as blocks of ice.There is not and the core is only 2.5 billion years old.Also there is the unlikeliness of a precise angle of attack by a large projectile (to stop the Earth going out of orbit of the sun),so I suspect the Earth and moon formed side by side in space.
Further evidence against a core colliding with Earth is that we would expect
water to have been ejected from the oceans into space,and this would mean that the ratio of deuterium/ normal hydrogen would be bigger in the sea than is
observed (deuterium is heavier than normal hydrogen and so less water containing it would get the velocity required to escape from the Earth).
Or it might have collected on the moon, in fact there are people who believe that the record of some of Earth's larger impacts might be preserved on the moon (which itself is generally thought to be the record of a very large impact), this is an interesting prospect indeed as a lot of the evidence on our own planet of past impacting events has been lost by resurfacing processes.
Is it? I didn't know that, can you please back that statement up.
The energy from the moon forming impact is thought to have been converted into the angular momentum that the Earth moon system has as a whole as well as providing energy for the Earth's rotation -which is why we have days! Again, this statement seems rather bold, did you come up with that off the top of your head or have you seen some kind of study which comes to this conclusion.
verdigris said:
Further evidence against a core colliding with Earth is that we would expect water to have been ejected from the oceans into space,and this would mean that the ratio of deuterium/ normal hydrogen would be bigger in the sea than is observed (deuterium is heavier than normal hydrogen and so less water containing it would get the velocity required to escape from the Earth).
Again I didn't know that, have you got a reference?
The amount of energy needed to lift the Earth out of the solar system would have vaporized both objects. And to direct the Earth into the sun, the impact would have to be at a precise angle. I would have expected a major collision to result in a strongly elliptical orbit.
I get your point though, that we might expect a major collision to alter the orbit in some dramatic way. But astronomers do think the moon was formed by collision. I don't understand the mechanics either. I know our orbit is slightly elliptical, but not by much.
Here are my first 4 hits on a Google search for "formation of the moon"
http://csep10.phys.utk.edu/astr161/lect/moon/moon_formation.html
http://www.psi.edu/projects/moon/moon.html
http://www.windows.ucar.edu/tour/link=/earth/moon/moon_evolution_overview.html
http://starchild.gsfc.nasa.gov/docs/StarChild/questions/question38.html
[/url]
Our orbit was altered in a dramatic way, we now orbit the moon as well as the Sun.
That's a great answer Mr B! It ducks the question though I think. Or maybe not. I guess what I'm really talking about is the orbit of the Earth-moon pair as the resultant momentum vector of the collision. Doesn't it have to be radically different from the pre-collision vector of the Earth alone? Not that we would know what that was, but I still don't get why the orbit is so well behaved.
I know I'm missing something and I suspect it has to do with rotational momentum . . . ? Or maybe the momentum of the orbiting Earth is so great that the impact had less effect than I imagine.
  • · Replies 42 ·
9K
  • · Replies 0 ·
10K
9K
