| Thread Closed |
Textread of csv-file |
Share Thread | Thread Tools |
| Feb28-07, 09:02 AM | #1 |
I'm sure that this will be a quite simple question, but I will not work for me. I try to read data from a csv-file with matlab(see under post). But is doesn't work... I try to skip the the first 9 ninen lines, because they are useless for the data analyses. I try the following line with matlab:
[data] = textread('data.csv','','delimiter',',','emptyvalue',NaN) Can somebody help me to change this line? Thanks for every help! greetings, Erik 0;63;1;63;500;1000;0;4 0;1;1;150;1000;1500 0;2;2;150;1000;1500 0;3;3;150;1000;1500 0;4;4;150;1000;1500 0;5;5;150;1000;1000 0;6;6;150;1000;1000 0;7;7;150;1000;1000 0;8;8;150;1000;1000 1; 2; 792;2314; Led;-255; 3; 2; 1500; 7; 1; NaN; NaN 2; 2; 892; 892; Led;-255; 6; 1; 1500; 7; 1; NaN; NaN 3; 2; 835; 835; Led;-255; 9; 1; 1500; 7; 1; NaN; NaN 4; 2; 881; 881; Led;-255; 12; 1; 1500; 7; 1; NaN; NaN 5; 2; 560; 560; Led;-255; 15; 1; 1500; 7; 1; NaN; NaN 6; 2; 507; 507; Led;-255; 18; 1; 1500; 7; 1; NaN; NaN 7; 2; 652; 652; Led;-255; 21; 1; 1500; 7; 1; NaN; NaN 8; 2; 704; 704; Led;-255; 24; 1; 1500; 7; 1; NaN; NaN 9; 2; 502; 502; Led;-255; 27; 1; 1500; 7; 1; NaN; NaN 10; 2; 738;1495; Led;-270; 3; 2; 1500; 7; 1; NaN; NaN 11; 2; 901; 901; Led;-270; 6; 1; 1500; 7; 1; NaN; NaN 12; 2; 767; 767; Led;-270; 9; 1; 1500; 7; 1; NaN; NaN 13; 2; 940; 940; Led;-270; 12; 1; 1500; 7; 1; NaN; NaN 14; 2; 852; 852; Led;-270; 15; 1; 1500; 7; 1; NaN; NaN 15; 2; 848; 848; Led;-270; 18; 1; 1500; 7; 1; NaN; NaN 16; 2; 853; 853; Led;-270; 21; 1; 1500; 7; 1; NaN; NaN 17; 2; 546; 546; Led;-270; 24; 1; 1500; 7; 1; NaN; NaN 18; 2; 521; 521; Led;-270; 27; 1; 1500; 7; 1; NaN; NaN 19; 2; 655;1494; Led;-285; 3; 2; 1500; 7; 1; NaN; NaN 20; 2; 661; 661; Led;-285; 6; 1; 1500; 7; 1; NaN; NaN 21; 2; 901; 901; Led;-285; 9; 1; 1500; 7; 1; NaN; NaN 22; 2; 707; 707; Led;-285; 12; 1; 1500; 7; 1; NaN; NaN 23; 2; 569; 569; Led;-285; 15; 1; 1500; 7; 1; NaN; NaN 24; 2; 819; 819; Led;-285; 18; 1; 1500; 7; 1; NaN; NaN 25; 2; 777; 777; Led;-285; 21; 1; 1500; 7; 1; NaN; NaN 26; 2; 886; 886; Led;-285; 24; 1; 1500; 7; 1; NaN; NaN 27; 2; 544; 544; Led;-285; 27; 1; 1500; 7; 1; NaN; NaN 28; 2; 567;1492; Led; 0; 3; 2; 1500; 7; 1; NaN; NaN 29; 2; 893; 893; Led; 0; 6; 1; 1500; 7; 1; NaN; NaN 30; 2; 834; 834; Led; 0; 9; 1; 1500; 7; 1; NaN; NaN 31; 2; 702; 702; Led; 0; 12; 1; 1500; 7; 1; NaN; NaN 32; 2; 942; 942; Led; 0; 15; 1; 1500; 7; 1; NaN; NaN 33; 2; 673; 673; Led; 0; 18; 1; 1500; 7; 1; NaN; NaN 34; 2; 917; 917; Led; 0; 21; 1; 1500; 7; 1; NaN; NaN 35; 2; 767; 767; Led; 0; 24; 1; 1500; 7; 1; NaN; NaN 36; 2; 543; 543; Led; 0; 27; 1; 1500; 7; 1; NaN; NaN 37; 2; 766;1494; Led; 15; 3; 2; 1500; 7; 1; NaN; NaN 38; 2; 603; 603; Led; 15; 6; 1; 1500; 7; 1; NaN; NaN 39; 2; 858; 858; Led; 15; 9; 1; 1500; 7; 1; NaN; NaN 40; 2; 704; 704; Led; 15; 12; 1; 1500; 7; 1; NaN; NaN 41; 2; 840; 840; Led; 15; 15; 1; 1500; 7; 1; NaN; NaN 42; 2; 625; 625; Led; 15; 18; 1; 1500; 7; 1; NaN; NaN 43; 2; 795; 795; Led; 15; 21; 1; 1500; 7; 1; NaN; NaN 44; 2; 649; 649; Led; 15; 24; 1; 1500; 7; 1; NaN; NaN 45; 2; 928; 928; Led; 15; 27; 1; 1500; 7; 1; NaN; NaN 46; 2; 526;1492; Led; 30; 3; 2; 1500; 7; 1; NaN; NaN 47; 2; 793; 793; Led; 30; 6; 1; 1500; 7; 1; NaN; NaN 48; 2; 964; 964; Led; 30; 9; 1; 1500; 7; 1; NaN; NaN 49; 2; 825; 825; Led; 30; 12; 1; 1500; 7; 1; NaN; NaN 50; 2; 513; 513; Led; 30; 15; 1; 1500; 7; 1; NaN; NaN 51; 2; 698; 698; Led; 30; 18; 1; 1500; 7; 1; NaN; NaN 52; 2; 957; 957; Led; 30; 21; 1; 1500; 7; 1; NaN; NaN 53; 2; 817; 817; Led; 30; 24; 1; 1500; 7; 1; NaN; NaN 54; 2; 843; 843; Led; 30; 27; 1; 1500; 7; 1; NaN; NaN 55; 2; 646;1493; Led; 45; 3; 2; 1500; 7; 1; NaN; NaN 56; 2; 742; 742; Led; 45; 6; 1; 1500; 7; 1; NaN; NaN 57; 2; 745; 745; Led; 45; 9; 1; 1500; 7; 1; NaN; NaN 58; 2; 686; 686; Led; 45; 12; 1; 1500; 7; 1; NaN; NaN 59; 2; 790; 790; Led; 45; 15; 1; 1500; 7; 1; NaN; NaN 60; 2; 620; 620; Led; 45; 18; 1; 1500; 7; 1; NaN; NaN 61; 2; 681; 681; Led; 45; 21; 1; 1500; 7; 1; NaN; NaN 62; 2; 667; 667; Led; 45; 24; 1; 1500; 7; 1; NaN; NaN 63; 2; 988; 988; Led; 45; 27; 1; 1500; 7; 1; NaN; NaN |
| Feb28-07, 10:09 AM | #2 |
Is the file actually comma-separated or is it semicolon-delimited as shown in your post?
| Feb28-07, 10:43 AM | #3 |
The file is exactly like this post, I also try to change the comma in textread in an a ;
| Feb28-07, 03:43 PM | #5 |
and why not? It should be a csv-file... and how can I read it in another extension?
| Feb28-07, 05:01 PM | #6 |
Mentor
If it is semi colon delimited then it is NOT comma delimited. CSV stands for comma separated values and implies a comma delimited file.
| Mar1-07, 12:38 AM | #7 |
but how can I read this? :(
| Mar1-07, 01:18 AM | #8 |
Mentor
What are the parameters in the textread command?
Do you have to define your data structure? |
| Mar1-07, 07:09 AM | #9 |
Either strip out the header and change your delimiter to a semi-colon or use C-style syntax to read the file within Matlab.
| Mar1-07, 09:59 AM | #10 |
I have part of the solution. I can use the following line:
[M{1:13}]=textread('ee0100.csv','%d%d%d%d%s%d%d%d%d%d%d%d%d','headerlines',9,'de limiter',';'); Problem is now that I get lines like: |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Textread of csv-file
| Thread | Forum | Replies | ||
| add file | Programming & Comp Sci | 1 | ||
| .tex file won | Computing & Technology | 10 | ||
| Help File | Forum Feedback & Announcements | 17 | ||
| Make a Pdf file into an ordinary web file (html file)? | Computing & Technology | 3 | ||
| My network directory file synch batch file thing :) | Computing & Technology | 2 | ||
