Calculating Takeoff Time and Distance for a Plane on a Runway
  • Thread starter Thread starter cool_dude
    Airplane
The discussion revolves around calculating the takeoff time and distance for a plane accelerating from rest on a runway. The problem involves kinematics, specifically the equations of motion under constant acceleration.
  • The original poster attempts to use the equation d = vt + 1/2at to find the time needed for takeoff, expressing uncertainty about its correctness. They also question the realism of the calculated time for takeoff. Other participants suggest corrections to the formula and clarify the interpretation of time intervals for calculating distance traveled in the last second before takeoff.
Participants are actively engaging with the problem, offering corrections and clarifications. Some guidance has been provided regarding the correct formula and the interpretation of time intervals, but there is still some uncertainty about the implications of the required velocity for takeoff and the calculations involved.
The discussion includes assumptions about constant acceleration and the specific conditions of the runway length and acceleration rate. There is also a mention of the need to consider the required takeoff velocity, which has not been explicitly addressed in the calculations.
cool_dude
A plane accelerates from rest at a constant rate of 5.00 m/s^2 along a runway that is 1800 m long. Assume that the plane reaches the required takeoff velocity at the end of the runway. What is the time t_{TO} needed to take off?
i think the formula I'm supposed to use is d = vt + 1/2at
not exactly sure if this is the correct formula but that's what i thought i have to use. we know that d = 1800m and we know that initial velocity = 0 and a = 5 m/s^2 so then we isolate for t. thus we get t = 1800 / 2.5 = 720. however i think this might be wrong because i don't think its realistic for a plane to take 12 minutes on the run way to take off. any ideas?
Also part of the question was What is the distance d_last traveled by the plane in the last second before taking off?
I tried to use the same formula d = vt + 1/2at and since we figured out time from part a we sub (t - 1) into here and get distance traveled in the last second before taking off. not sure if any of this is right. can someone verify?
Thank you
your equation is wrong. it should be:
d = v0*t + (1/2)at^2
you didn't have the t^2...
pluggin in t-1... gives the distance traveled in the first t-1 seconds... not the last 1 second. you're close...
oops you i forgot the square. so then i get 26.8 seconds. does that make sense for a plane to take amount of time for lift of? i think it makes sense to me. not sure. also does this mean that we don't care about the required velocity for takeoff?
hmmm the second part is tricky. i thoght that t - 1 would mean that let's say it took 10 seconds then t = 10 and the second before it is t - 1 = 9. I'm a bit confused on this part.
Your time looks correct.
Suppose you know the distance traveled in the first 10 seconds... and the distance traveled in the first 9 seconds... you can get the distance in the last second by subtracting the two...
Wow thanks for the fast reply. And thank you very much for all your help. i got both answers correct thanks to you. :)
  • · Replies 84 ·
