| Thread Closed |
Hollow Earth, Hollow Gravity |
Share Thread |
| Sep18-07, 05:51 PM | #1 |
I have just finished reading a very detailed book that has half convinced me that the earth (and other planetary bodies) are hollow. I know this sounds ridiculous, and if someone here gives a good answer why not, I’ll change my mind, (and get very annoyed that I read a 500 page page book that can be disproved!) but I can’t think of a good reason to disprove it.
I read the previous topic on this site on the hollow earth theory, but no-one raised the points that were in this book so I’ll have a go. You can see the book at: http://www.amazon.com/gp/reader/0620...15#reader-link , its written by Jan Lamprecht who says the book is a Lateral Thinking exercise along the lines advocated by Kurt Godel. When I started reading I had three problems I could see with the hollow earth concept; 1. Gravity 2. Seismology 3. The origin of volcanoes I found his rebuttals to these points hard to flaw, which he answered in the very first section: 1. Newton's Law of Gravity; one of the most useful mathematical formulae ever devised. This little formula has made space travel and the exploration of the Solar System possible. It made satellites possible. . . . Scientists use this little formula to gain an understanding of galaxies far away, and indeed the behaviour of the universe as a whole. It is now more than 300 years since Newton devised this little formula; and we still do now know what causes gravity. Newtonian gravity is accurately measured and proven with the bounds of the solar system. However, Newtonian gravity remains untested in other areas. All we have is a formula. This formula has been used to determine the mass of the Earth. This is based on the concept that for each mass of M inside the Earth, it exerts and attractive force of F. We do not know the valid range for Newtonian gravity. Inside Newton's formula is G. G is the "universal gravitational constant". It is assumed, and assumed is the correct word here, that each mass of M exerts the same force of F regardless of where in the universe it may be placed. It is also assumed that each mass of M exerts the same force F whether it lies on the surface of the Earth or whether it be deep inside the Earth. When using the Cavendish balance to determine the mass of the Earth, it is assumed that each particle exerts a fixed force upon all others. This assumption rules out the very real possibility that particles near the surface of a planet might exert a force greater than those deep down. The key to all of our gravity is the mass of the Earth. If the mass of the Earth is wrong, then so are our estimates for those of other bodies. If the mass of the Earth has been overstated, then it follows that the masses of all other bodies in the solar system have also been overstated. If the Earth is hollow, then so too is every other planet in the solar system. How can we be sure that the Earth really has the mass accorded it by Newtonian gravity? As gravity is so unbelievably weak, is an experiment using two lead balls really representative of the entire Earth? No, of course not. There is electrical charge to account for, and also magnetic forces and electromagnetic forces, that are a lot stonger than gravity, that the current theory does not take into account. [He then proceeds to go into detail about Newton’s shell theorem, which is too mathematically complex for me to understand, but I think proves that gravity is always 0 at the centre of any spherical body] ..then seismology 2. The only "reliable" method we have of knowing what goes on in the Earth beneath our feet comes from the science of Seismology. However, there are many examples of actual findings being different from what was predicted. The science of seismology contains two very broad assumptions which no one has ever been able to verify: 1. The speed of seismic waves beneath the Earth is ultimately inferred from our understanding of the structure of the Earth based on Newtonian Gravity. We have no way of being certain that these waves really are reaching these depths or travelling at these speeds. 2. We cannot be sure that speed changes are due to the changing constitution of the Earth. Our view of the inner Earth might be very skewed. Much of the predicted structure changes have never turned out to be real. If we find such errors at depths of just a few kilometres, how much less can we trust our ideas when dealing with rock which is hundreds and perhaps thousands of miles beneath the surface? The fact that the deepest man has ever gone into the earths crust is 25 miles, theres still hundreds of miles to go until we can have any sort of proof. ..then geology 3. What do we really know about the Earth's interior? And how trustworthy is our knowledge of it? Many people (mistakenly) think that the lava which pours out of volcanoes comes from a large reservoir of molten material which makes up the greater part of the Earth. Scientists have discovered that lava comes from within the Earth's crust. The lava comes from approximately 20 miles down. The existence of lava does not affect the passage of earthquake (seismic) waves. This indicates to scientists that the crust is largely solid. So where does the heat come from which melts the rock locally? Scientists have advanced two theories. Some say that the melting is due to high concentrations of radioactive elements in a particular area. These decaying radioactive elements generate enough heat to melt rock. Much lava is slightly radioactive and that lends support to this theory. Other geologists have argued that shearing and faulting are adequate heat generating mechanisms via friction. The evidence supports both theories. Lava cannot possibly be rising from the centre of the Earth as some may be tempted to think. It would cool down and become solid on its long, slow journey upwards. Lava is therefore a surface phenomenon and does not in any way reflect what the Earth is like 50 or 100 or more miles down. The author then gives some reasons to believe the earth may be hollow. He mentioned what seismologists call the 'shadow zone' which is the large area in the centre of the earth that no P or S waves ever penetrate, and he has concluded that it is more likely that they cannot penetrate that because there is nothing there to penetrate (seismology does not work in gas). He also explains the earth’s magnetic field with a counter rotating dynamo effect which involves a burning hydrogen core. He postulates that as Hydrogen is the lightest element, due to Newton’s shell theorem making g = 0 at the centre, it would naturally diffuse to the centre and would burn in a reaction similar to the suns. I was surprised to read a review of the book from Dr Tom Van Flandern (astronomer, formerly U.S. Naval Observatory) who said: “For merely showing us all that the inferred density profile of Earth's interior is not a unique solution of seismic data -- an important constraint for all theoreticians working in that area -- the book had already made itself worthwhile.” And also a review from Richard Baum (Director Mercury & Venus Sections, British Astronomical Association) which said: “I must say you have stored your book with an enormous amount of information; much quite surprising, all stimulating. Essentially you are not only obliging us to take a fresh look at things but to observe from an unsuspected different position - the presumed impossible.” It all sounded quite scientifically sound to me, so I decided to put it in this debunking section, as I can’t debunk it, especially the points 1, 2, 3 he makes. Is there anything that really puts a nail in all this theory? i'd be eager to hear it. some diagrams: http://www.bibliotecapleyades.net/ti...ra_hueca_9.htm |
| Sep18-07, 06:32 PM | #2 |
How did the earth come to be hollow then? It is rather implausible that the earth was somehow formed that it is, or has been, or will be hollow.
| Sep18-07, 06:46 PM | #3 |
You would have the centripetal force from the spin, and he says magnetism from pole to pole may affect the interior formation. There is also Electrical current which have been proven to flow through the earth which may affet the interior. The current theory, of gradual accumulation of mass from asteroids and dust, does not really explain how the huge reaction at the centre started in the first place, or how it is sustained. He says that over time as the earth accumulated more mass it grew more circular as the strength of gravity increased, and when bodies form into circular bodies, as Newtons shell theorem says (http://en.wikipedia.org/wiki/Shell_theorem), gravity starts to cancel out directly in the centre, and the planet forms into a hollow structure. Architects havce already proven the structure is sustainable, like a Dyson Sphere (http://en.wikipedia.org/wiki/Dyson_sphere) or a Globus Cassus (http://en.wikipedia.org/wiki/Globus_Cassus) |
| Sep18-07, 07:29 PM | #4 |
| Sep18-07, 07:51 PM | #5 |
i dont think he is saying we need to challenge translational symmetry at all, he is pointing out that there are other forces that affect particles apart from gravity and all of these forces are infact much stronger than gravity, so they may infact play a much bigger role than gravity does in planetary formation. In other words its not just the mass of particles that affect their formation, its also the charge and other local electromagnetic forces.
He also suggests that gravity may invert, which would put the center of gravity as a ring around the crust, and objects inside the cavity will be attracted out to the crust aswell as objects outside the crust. i'm not so sure about 'inverting gravity', i can see gravity cancelling at the centre, but not fully inverting like he suggests. |
| Sep18-07, 08:21 PM | #6 |
Mentor
If the earth was hollow, then wouldn't that hugely affect the orbit of the earth around the sun, and the moon around the earth?
What ever happened to Occams Razor? Given what we know about planet formation, it is a lot more likely that the earth has matter inside it than it is hollow. |
| Sep18-07, 08:32 PM | #7 |
Mentor
We also have the density of rocks and the size of the Earth which serve as a very good check on the Earth's mass as deduced by satellite orbits and the moon's orbits. If the Earth ws hollow, it would have to be made of something much denser than rock to account for orbits. The Earth is very, very small compared to the sun. The Earth's mass contributes almost nothing to the orbits of the other planets. Their orbits are independent checks against the value of the universal gravitational constant based on observations of the moon and satellites. Finally, the gravitational attraction inside the supposed hollow earth would be zero. Supposed inhabitants inside the hollow earth would live in a near zero-g environment. |
| Sep18-07, 08:49 PM | #8 |
Mentor
Regarding his other issues with gravity: I love self-debunking crackpots! |
| Sep18-07, 11:48 PM | #9 |
References: Lord Rayleigh, Proc. London Math. Soc. 17, 4 (1887) K. Sezawa and K. Kanai, Bull. Earthquake Res. Hist. 17, (1939) J. G. Scholte, Proc. Acad. Sci. Amsterdam 45, 20 (1942) R. A. Phinney, Bull. Seismol. Soc. Am. 51, 527 (1961) W. Pilant, Bull. Seismol. Soc. Am. 62, 285 (1972) I. V. Ponomarev and A. L. Efros, Phys. Rev. B 63, 165305 (2001) See: Very low mass stars, black dwarfs and planets |
| Sep19-07, 05:10 AM | #10 |
He's right that there isn't (much) melted material in the deep earth, but this should surprise no one (I'll forgive the fact that he called it lava, when the correct term is magma. Lava is an eruptive product and is only called that on the surface). The mantle is a plastically deforming solid (think silly putty) and does not melt due to the extreme pressure on it. I don't know where he gets his ideas of what scientists say* causes lava melt, but he's fairly far off the mark. For the major causes, firstly, yes heating is an option, but not from localised radioactive decay or faults, but from convecting material upwelling from the core-mantle boundary. Secondly, decompression of material at ocean ridges, continental rifts etc allows melting. Thirdly, addition of volatiles like at subduction zones can lower the melting point of the mantle. Let's think about his claim that lava (magma!) rising from the core would cool and set. Firstly, barring perhaps some amount of magma at the ultra low velocity zone next to the outer core, as I've already said the mantle is largely solid and deforms as a plastic. This material setting is irrelevant. If it were a liquid, S-waves would be unable to penetrate it, and yet they do. Again, he doesn't know what he's talking about. As for a hot plastically deforming solid rising, that is plausible. The earth is a very poor conductor of heat, and it so conduction is a very slow method of removing heat from the core. Since the mantle can behave as a fluid, convection therefore is the major way in which heat is transferred. Seismology, by the way can in fact pick up columns of low density material rising up through the mantle... I'm not at all sure how he feels this is evidence for a hollow earth anyway... What does it have to do with it? *There's nothing that screams bulls*** more than the phrase "scientists have discovered" followed by no citations of any kind. |
| Sep19-07, 08:24 AM | #11 |
http://www.bibliotecapleyades.net/ti...ra_hueca_9.htm The only other method to map the underground is using HAARP technology, but thats military owned and not publicly available data. He also suggests that this is why not many other countries have successful space programs! I fail to see what multilayered semiconductor materials has to do with proving seismology, could you explain please. also there are very genuine doubts about how much seismology can actually tell us about the inside of the earth. references: http://www.pubmedcentral.nih.gov/art...?artid=1084633 Problems of Seismology (Structural Review) http://www.cosis.net/abstracts/EAE03...03-J-07580.pdf http://sciencelinks.jp/j-east/articl...00A0603470.php British Geological Survey, West Mains Road, Edinburgh, EH9 3LA, UK He resolved the thermonuclear reaction by using some of the latest tests in plasma cosmology, which is largely ignored by mainstream cosmologists, because it says that the Sun is a charged body that acts electrically. It also proposes that the Sun is surrounded by a plasma cell that stretches far out - many times the radius of Pluto, and that the sun may be fuelled externally by ionised plasma provided by the inaptly named 'solar wind' ( it should be called an 'ionized gas' the solar wind is actaully constituted of very fast moving ionized particles), and he quoted some questions from Lewis E. Franks, PhD, Stanford University, that i could not answer: So one of the most basic questions that ought to arise in any discussion of the Sun is: Why does our Sun have a corona? Why is it there? It serves no purpose in a fusion-only model nor can such models explain its existence? and why is it millions of degrees hotter than the surface of the sun? This is highly unexpected for a body thats heat should raidiate uniformly from the core. Its not as if we can set up accurate seismological experiments on another planet to test the accuracy of seismology, so seismology apparently works well now, and is allegedly matematically provable, but the math could very well be based on wrong assumptions about the internal constituation. please read: http://www.springerlink.com/content/w3x6306p42674728/ |
| Sep19-07, 09:35 AM | #12 |
Mentor
Just out of curiosity, is there a reason you are giving this crackpot that much credibility (not to mention, time and effort) when compared with other reputable sources?
Zz. |
| Sep19-07, 10:20 AM | #13 |
This is, as so many other crackpot theories, undebunkable. If you put everything one knows in doubt, if you put everything that is said in doubt, for a variety of reasons, then you can always come to a self-consistent, or at least undebunkable set of statements.
This is in fact a philosophical truth that there is no ultimate truth that you can demonstrate. You always need to start *somewhere* to show something. So if, from the start, about everything we (think to) know is put in doubt, every attempt at debunking will consistently be put in doubt too. As such, I think that "can we show you to be wrong" not the right way to tackle these statements, because this will be an endless chase of argument-building followed by putting in doubt the premises. The creationists follow in fact the same path. The scientific question is: can that hollow-earth guy make a falsifiable prediction with his hollow-earth theory that is in contradiction with the standard view and where an experiment will show his theory right and the standard view wrong ? Or has he set up a hollow-earth-that-looks-as-if-it-were-filled theory, where all our knowledge is modified in such a way as to accomodate for a hollow-earth-that-is-not-to-be-detected-to-be-hollow-in-our-paradigm ? In that case, he might just have invented a peculiar world view which is scientifically equivalent to the standard view. In that case, his theory is a fun philosophical game, which doesn't have any advantage (or disadvantage) over the standard view. But the problem with this kind of games is that one usually has an "expanding frontier of necessary new theories" when one tracks them logically, and that the inventor of the theory has limited himself to only a small domain where his system seems not self-contradictory. |
| Sep19-07, 10:31 AM | #14 |
I've had a more thorough look at the guy's alternative explanations, and looking at these diagrams, things don't seem to add up.
conventional model: http://www.bibliotecapleyades.net/im...ahueca/P_6.gif Hollow earth: http://www.bibliotecapleyades.net/im...ahueca/P_7.jpg A novel explanation for the wavepaths and distribution, but do the travel times match? In the hollow earth model, the waves arriving in the shadow zone take a much shorter path than those emerging close to 180 degrees from the epicentre, and they also avoid the hypothesised zone where density decreases with depth and thus should arrive much sooner than those that emerge further from the epicentre as well as being considerably stronger. Also note how in the conventional model has an area where both PKP and PKIKP waves arrive. That means two separate arrival times for waves, which again isn't accounted for in the hollow earth model. Also, isn't it possible to identify boundaries by reflection seismology as well as refraction? If we can pick up the inner core with reflected waves, that would pretty much can his whole idea. |
| Sep19-07, 11:45 AM | #15 |
Mentor
And let's not forget the results from the geophysical neutrinos that was detected by KamLAND back in 2005[1]. I'd like to see this crackpot accounts for that.
Zz. [1] T. Araki et al., Nature v.436, p.499 (2005). |
| Sep19-07, 03:35 PM | #16 |
Gravity is only attractive, so it adds continually when more and more mass is added. Strong and weak interactions are even stronger than electromagnetism, but the vanish so fast with increasing distance that they are only active in the interior of atomic nuclei. There is no mystery at all that gravity is the dominant force in the universe. About the burning core, there is no mystery either. The responsible is gravity. You must have seen the experience in high school of the rise of temperature when you compress a gas. When a cloud of gas and dust is compressed by gravity to form a star or a planet, its temperature rises. If the mass is big enough, the temperature is sufficient to start fusion reactions and you have a star. If the mass is lesser you have a planet and the temperature may be enough to fuse rocks. Smaller bodies, like asteroids have not enough mass to be stable under the weak gravitational force, so they are subject mainly by electromagnetic interactions. |
| Sep19-07, 06:11 PM | #17 |
look at this official page at the stanford site of this experiment. They are clearly not claiming to measure the internal constitution of the earth, they are detecting electron antineutrinos produced by natural radioactivity in the Earth. They say on that page, "The Earth can be split into 5 basic regions according to the seismic data", which shows they are using seismology as if it is a proven fact, and are obviously never going to conclude anything about the structure of the earth as all they are just measuring the radiogenic power of particles coming from the earth. they also say on that site, "The deepest borehole is ~12km, 1/500 of the Earth's radius. ", so if theres still over five thousand miles to explore, i'd say being confident that seismology is accurate to predict the exact constitution, temparature, pressure and density of the Earth is naive. No-one has pointed out an alternative way of measuring the earths interior apart from (potentially flawed) seismology. (they even have a picture of a hollow earth on their site, if you look at the left sphere.) i'm glad you brought up that paper, as it clearly demonstrates matthyaouw wrong when he says "The radioactive isotopes inside the Earth generate heat. In particular, decays of the daughter nuclei in the decay chains of 238U and 232Th, and 40K generate most of the radiogenic heat produced. According to some of the mantle convection models, these two numbers, 44TW (or 31TW) for the total heat dissipation rate from the Earth, and 19TW for radiogenic heat production rate should be similar. As these radioactive isotopes beta-decay, they produce antineutrinos. So, measuring these antineutrinos may serve as a crosscheck of the radiogenic heat production-rate" so actually Jan is quite near the mark when he says heat is produced from radioactive isotopes in the earths crust. I know that the srong nuclear force and the weak force are too strong to work on a scale as large as planets as they only effect the subatomic level, but he didn't mention the weak or strong force. He specifically mentioned magnetism, charge and electricity. We all know what happens when you apply an electric field to, for example, an electron, it will experience a force in a certain direction, ( F = Ee ) or similarly with a magnet. If you are using a magnet to pick something up, the WHOLE of the earth is pulling down on it, yet you are able to overcome this with something in your hand. I think it is actually quite logical to assume that magnetism and charge play a part in planetary formation since they are so much stronger and dominant in the universe we observe. is there a relationship between pressure and gravity inside planets? or are they completely independant variables? it seems odd they are independant as the alleged reason the pressure is so high at the centre is due to gravity, but gravity = 0 at the centre. |
| Thread Closed |
Similar discussions for: Hollow Earth, Hollow Gravity
| Thread | Forum | Replies | ||
| Gravity on the surface of a Hollow Earth | General Physics | 14 | ||
| Hollow earth???? | Earth | 4 | ||
| Someone said that the earth is hollow. Is this possible? | General Physics | 12 | ||
