| Thread Closed |
Correct reasoning about direct sums proof? |
Share Thread | Thread Tools |
| Sep18-07, 12:04 PM | #1 |
Howdy everyone. I'm not very good at writing proofs, so I am wondering if someone can tell me if I'm even on the right page with this. I am not sure if I understand the idea correctly. The theorem goes as follows: Suppose V is a finite dim. vector space with subspaces U and W such that V is the direct sum of U and W. Let Z also be a subspace of V. Then Z cannot equal the direct sums of (i) the intersection of Z and U and (ii) the intersection of Z and W unless Z is a subspace of U or W.
Here's my thoughts: Let "C" denote the direct sum of the intersections (i) and (ii) above. Then two conditions must hold: 1) The intersection of the intersections (i) and (ii) must be the zero vector; and 2) The sum of the intersections must equal V. The elements of C are given as {x|x is in Z and x is in U and x is in W}={0v}. Thus every x in Z that intersects U and W is in C. But we have that C={0v} since it is a direct sum. The only way that {0v}=(ZintersectU)intersect(ZintersectW) is if Z contains only the zero vector. Thus Z is the zero subspace, and it follows that Z must be a subspace of U and W. Yeah, let me know if that's right... I'm not sure that I am correct in asserting that Z contains only the zero vector.
| Sep18-07, 06:50 PM | #2 |
Recognitions:
| Sep19-07, 12:19 AM | #3 |
well it sounded reasonable to me... if C is the set of {(Z intersects U) intersects (Z intersects W)}. So for (Z intersects U) we have the set containing {x|x is in Z and x is in U} and similarly for (Z intersects W) we have the set {x|x is in Z and x is in W}.
The direct sum would have all of these x too... wouldn't it? Although looking above it seems that I mixed up an intersection and direct sum. But even so, the intersection of the two intersections has to be the zero vector. |
| Sep19-07, 12:29 AM | #4 |
Recognitions:
| Sep21-07, 04:09 AM | #5 |
Put the statement into a form that'll shed some more light on the different options you have for proving it. The first thing I'd do is get rid of the "unless"; then you'll have a positive statement. It'll be an implication. Move its antecedent into your list of hypotheses (giving you more stuff to work with). Notice the antecedent's a disjunction (which suggests one proof method). Of course, there are other options too. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Correct reasoning about direct sums proof?
| Thread | Forum | Replies | ||
| [SOLVED] Linear Algebra - Direct Sums | Calculus & Beyond Homework | 2 | ||
| Direct Sums | Calculus & Beyond Homework | 10 | ||
| Is my reasoning correct? | Introductory Physics Homework | 8 | ||
| Direct sums | Introductory Physics Homework | 4 | ||
