Thread Closed
How to get inverse Lorentz tranformation from "direct" Lorentz transformation
Share Thread Thread Tools
Oct1-07, 05:40 PM   #1
Hello, I am having trouble on deriving the inverse Lorentz transformation from the direct Lorentz transformation. I looked at some threads here and I found in here (http://www.physicsforums.com/showthread.php?t=183057) that all I need to do is to "combine" the equation for x and t and I will get the inverse equation...but I don't really know what does it mean to "combine" the equation...? I also found in textbooks that to get the inverse transformation I just need to solve for x in the direct transformation. However, when I do it...it doesn't give the inverse transform equation. Can anybody give me some help here? I'll greatly appreciate it.
Thanks!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Oct1-07, 05:58 PM   #2
Recognitions:
Quote by Odyssey View Post
It's just algebra, it means solving those two equations (a combined system of equations) for x and t. You have:
x'=gamma*(x - vt) and t'=gamma*(t - vx/c^2)
So, with the first one you can do:
x' = gamma*x - gamma*vt
x' + gamma*vt = gamma*x
x'/gamma + vt = x
And with the second one:
t' = gamma*t - gamma*vx/c^2
t' + gamma*vx/c^2 = gamma*t
t'/gamma + vx/c^2 = t
Then substitute this expression for t into the earlier equation x = x'/gamma + vt, which gives you:
x = x'/gamma + v(t'/gamma + vx/c^2) = x'/gamma + vt'/gamma + xv^2/c^2
and if you subtract xv^2/c^2 from both sides, you get:
x(1 - v^2/c^2) = x'/gamma + vt'/gamma
Now since gamma = [tex]\frac{1}{(1 - v^2/c^2)^{1/2}}[/tex] this is the same as:
[tex]x * (1 - v^2/c^2)^1 = (1 - v^2/c^2)^{1/2} * (x' + vt')[/tex]
So if you divide both sides by (1 - v^2/c^2) you get:
[tex]x = (1 - v^2/c^2)^{-1/2} * (x' + vt')[/tex]
which is just x = gamma*(x' + vt'), the reverse transformation for x in terms of x' and t'. Then you can plug this into t = t'/gamma + vx/c^2 and get the reverse transformation for t in terms of x' and t', which should work out to t = gamma*(t' + vx'/c^2).
Oct1-07, 06:10 PM   #3
Quote by JesseM View Post
which should work out to t = gamma*(t' - vx'/c^2).
I think it should be
The direct and inverse transformations should differ only by the sign of velocity v.
Direct:
x'=gamma*(x - vt)
Inverse:
x=gamma*(x' + vt')
t=gamma*(t' + vx'/c^2)
Eugene.
Oct1-07, 06:22 PM   #4
Thanks guys. It was very clear. Now I get the problem! :)
Oct1-07, 06:45 PM   #5
Recognitions:
Quote by meopemuk View Post
Yes, sorry, I mistyped.
Oct6-07, 07:43 AM   #6
I've been following this, and I can see how to get to x, but am having trouble with t...I've got up to t = t'/gamma + (gamma*x'v)/c^2 + (gamma*t'v^2)/c^2
I just can't see where to go from there!
Oct6-07, 08:30 AM   #7
Thanks!
That's a lot of work just to say - Switch the sign on the velocity in the Lorentz transformation and you end up with the inverse Lorentz transformation.
Pete
Oct6-07, 08:44 AM   #8
Quote by pmb_phy View Post
Pete
Yes but then again you can't always do that - I'm working on inverting it mathematically, so we're not allowed to just say that! Unfortunately...!
Oct6-07, 09:52 AM   #9
Quote by Ayame17 View Post
Why not?
Oct6-07, 10:03 AM   #10
Why not?
Because the question I'm working on says "Mathematically invert equations (1) and (2) [ie, x' and t'] to obtain the inverse transformation"
Which means you can't just look at it from a physics point of view, you have to show it through the method that JesseM said above.
Oct6-07, 11:19 AM   #11
Like I said above (sorry for reposting,, feared that it got lost in the much quoting above):
I've been following this method, and I can see how to get to x, but am having trouble with t...I've got up to t = t'/gamma + (gamma*x'v)/c^2 + (gamma*t'v^2)/c^2
I can't see how to make it into the inverse Lorentz from there! Have tried rearranging but just can't make it look right...!
Oct6-07, 11:25 AM   #12
Mentor
Express v^2/c^2 in terms of gamma.
Oct6-07, 11:33 AM   #13
Quote by Doc Al View Post
It wouldn't have occurred to me to do that, thankyou!
Oct6-07, 02:18 PM   #14
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
If you use rapidity, your Euclidean trigonometric intuition would have guided you.
Thread Closed
Thread Tools
Similar Threads for: How to get inverse Lorentz tranformation from "direct" Lorentz transformation
Thread Forum Replies
direct and inverse Lorentz transformation Special & General Relativity 14
inverse lorentz transformation question Introductory Physics Homework 5
when is a derivation of the Lorentz transformation "good" Special & General Relativity 13
The distance-dependent nature behind lorentz "time-transformation"... Special & General Relativity 5
"Planck scale Lorentz-symmetry test theories" Amelino-Camelia Beyond the Standard Model 2
