Calculating Work on a Sliding Block on an Inclined Plane
The problem involves a block of weight w on a frictionless inclined plane at an angle (theta) to the horizontal, being pulled up the incline by a force F while moving at constant speed. The discussion centers on calculating the total work done on the block and the work done by gravity as it moves a certain distance up the incline.
  • Participants discuss the total work done on the block and the contributions from different forces, including gravity. There are attempts to apply the work-energy theorem and clarify the calculations for work done by gravity.
The discussion is ongoing, with participants sharing their attempts and questioning the correctness of their calculations. Some have noted discrepancies in their answers compared to external resources, indicating a productive exploration of the problem.
Participants express confusion over the application of the work-energy theorem and the specific calculations for work done by gravity, with references to external feedback suggesting potential errors in their reasoning.
danni7070
A block of weight w sits on a frictionless inclined plane, which makes an angle (theta) with respect to the horizontal. A force of magnitude F, applied parallel to the incline, pulls the block up the plane at constant speed.
1)The block moves a distance up the incline. The block does not stop after moving this distance but continues to move with constant speed. What is the total work Wtot done on the block by all forces? (Include only the work done after the block has started moving, not the work needed to start the block moving from rest.)
2)What is Wg, the work done on the block by the force of gravity as the block moves a distance up the incline?
Wtot = the sum of all work factors right ? So I have to find the work from the force going up the ramp, the work from gravity. ??
I think the answer to q1 is W-tot = FL + (-wsin(theta))+N (The opposite force of mg = w)
But this is not correct but I don't know why?
Anyone?
For the total work, what does the work energy theorem say?
for work done by gravity, use work = [tex]\vec{F}\cdot\vec{d}[/tex]
love how i got Wgravity wrong...
Wf= -mgcos(theta) * L
(from masteringphysics, your answer is off by a multiplactive factor..)
Wf is work by the force F?
Wf = mgsin(theta)*L
F must be mgsin(theta) acting up the plane.
sorry i meant force done by gravity
work done by gravity is -mgsin(theta)*L
that's exactly what i put...
but masteringphysics says I'm off by a multiplactive factor,,
hmmm... did you put in -wsin(theta)*L exactly?
thank you
my fault ... i input -wgsin(theta)*L
guslergusler said:
thank you
no prob.
  • · Replies 33 ·
