Determine if the following converges or diverges
  • Thread starter Thread starter lovelylila
The discussion revolves around determining the convergence or divergence of the integral of (lnx/(sqrt(x^2-1))) from 1 to infinity, a topic within Calculus II and AP Calculus BC. Participants explore various methods, including the direct comparison test and limit comparison test, to analyze the behavior of the integral as x approaches infinity.
  • Participants discuss the challenges of finding a suitable function for comparison, with some suggesting functions like 1/x and questioning their applicability over the entire interval from 1 to infinity. Others explore the behavior of ln(x) as x approaches infinity and its implications for comparison tests.
The discussion is ongoing, with various participants offering insights and suggestions. Some have proposed potential comparison functions, while others express uncertainty about their effectiveness. There is no explicit consensus on a definitive approach, but several lines of reasoning are being explored.
Participants note the importance of ensuring that comparison functions are valid over the specified interval and raise concerns about the implications of using certain bounds in their comparisons. The original poster expresses frustration with the lack of a clear solution, indicating the complexity of the problem.
lovelylila
Determine if the following converges or diverges as x approaches infinity by either evalutation, the direct comparison test, or the limit comparison test: (It's a Calculus II, AP Calculus BC level of problem)
the integral of (lnx/(square root of (x^2-1))), from 1 to infinity.
* I do not know how to evaluate the integral analytically, so I tried to use either the direct comparison test or limit comparison test. I can't seem to find another function that will "sandwich" that function (and thus prove convergency) or one that will prove it's divergency. I've tried 1/x, 1/(x^2), etc and I'm stuck. Any help on a function to use would be very much appreciated- I'm frustrated beyond belief!
Direct Comparison Test:
0< f(x)< g(x) proves that f(x) converges if g(x) also converges
f(x)> g(x)---proves that f(x) diverges if g(x) diverges
Limit Comparison Test:
if the limit as x approaches infinity of f(x)/g(x) is a finite, non-zero number, then f(x) has the same behavior of convergence as g(x)
0 < Ln x < x-1 for all x > 1. Does this help?
look at ln(x)/Sqrt(x^2-1) its only improper at infinity so if you look at what the function looks like when x --> infinity we get ln(x) /x . From this we can compare it to anything that diverges and is smaller than that...easiest example 1/x. ln(x)/Sqrt(x^2-1) > 1/x for all x > 1
thank you, but don't you have to choose a function that is greater/less than for all numbers from 1 to infinity? I don't understand how you can say for x>1, because one itself is the lower limit of the integral and shouldn't it thus be included? or in this type of problem is it to be assumed that the f(x)> g(x) for x>1, not including one?
That's an easy fix; 0 < Ln x < Sqrt(x-1) for all x > 1. [See edit.]
[Although: "Integral of 1/Sqrt[1+x] does not converge on {1,\[Infinity]}" may be a problem.]
"x > 1" should be replaced with "x > 2.5 (approximately)."
I do not think either of these examples is a solution.
thank you all very much for your help :wink:, but does anyone know what a solution could be? what you're all suggesting makes sense, but nothing works 100%...
On a 2nd thought, 1/x works, but is a little involved.
a. For 1 < x < 2.5, 0 < ln(x)/Sqrt(x^2-1) < 1/x.
b. For x > 2.5, ln(x)/Sqrt(x^2-1) > 1/x.
Fact "a" is inconvenient because it seemingly precludes a direct comparison with 1/x (our hope for a divergence result). So here is the involved part. Below, I will use the expressions "F diverges" and "F = [itex]\infty[/itex]" interchangeably.
[tex]\int_1^\infty f(x) dx = \int_1^{2.5} f(x) dx + \int_{2.5}^\infty f(x) dx.[/tex]
In shorthand, I(1/x) = I1(1/x) + I2(1/x) for f(x) = 1/x.
1/x evaluates to a finite (positive) result over [1, 2.5]. Therefore I1(1/x) is finite (and positive). Let I1(1/x) = J > 0.
Then, I(1/x) = J + I2(1/x). Since I(1/x) diverges, so does I2(1/x): [itex]\infty[/itex] = J + I2(1/x) implies I2(1/x) = [itex]\infty[/itex] - J = [itex]\infty[/itex]. Call this Result 1.
From fact "b," I2(ln(x)/Sqrt(x^2-1)) > I2(1/x) = [itex]\infty[/itex] (from Result 1). Therefore I2(ln(x)/Sqrt(x^2-1)) diverges. Call this Result 2.
Now...
We know we can write I(ln(x)/Sqrt(x^2-1)) = I1(ln(x)/Sqrt(x^2-1)) + I2(ln(x)/Sqrt(x^2-1)). Also, I1(ln(x)/Sqrt(x^2-1)) = K > 0 (positive & finite).
Can you take it from here?
Forum rules prohibit giving out answers "100%." What are your thoughts on the subject?
thanks again for all your help, i think i understand it now.
i wasn't asking for a "100%" answer, i was asking for a hint to a solution that worked 100% for this problem, there is a difference. i'll watch my wording next time.
Good, nice; am glad to help.
there are numerous number of solution to these kind of problems. you asked to show whether it diverges or converges...it diverges if it is larger than something than diverges then it too diverges (remember the converse is not true) 1/(100x) could be an answer that can work all the times but so can 1/(1004x)
Midy1420 is right; that's a much simpler solution.
  • · Replies 16 ·
