High Pressure Quick Connect Fittings
The discussion revolves around high pressure quick connect fittings suitable for applications involving water and air, specifically at pressures up to 400 psi. Participants share their experiences, recommendations, and specifications for connectors, as well as related equipment like hoses.
  • One participant inquires about experiences with high pressure quick connect connectors, specifying requirements such as male to female connections, corrosion resistance, and standard NPT threads.
  • Another participant mentions finding suitable connectors from McMaster, specifically those made by Snap-Tite, and notes their reliability based on frequent use.
  • Additional brands like Parker and Aeroquip are suggested as alternatives for high pressure fittings.
  • There is a light-hearted exchange about launching potatoes and other humorous applications of engineering, which diverges from the main topic but reflects camaraderie among participants.
  • Swagelok is mentioned as another manufacturer of high pressure fittings, indicating a variety of options available in the market.
Participants generally agree on the reliability of certain brands for high pressure fittings, but there is no consensus on a single best option, as multiple brands and models are discussed. The conversation also shifts to humorous engineering ideas, indicating a blend of technical discussion and light-hearted banter.
The discussion includes various assumptions about the suitability of different fittings and hoses for specific applications, but these assumptions are not fully explored or validated within the thread.
Individuals interested in high pressure fluid systems, engineers looking for reliable quick connect fittings, and those involved in experimental or applied engineering projects may find this discussion relevant.
dingpud
Has anyone out there had any successes or failures on high pressure (up to 400 psi) quick connect connectors?
I've done the basics McMasterGoogleGlobalSpec search, and have come up with a few different kinds. There is a large variance in price, so I wanted to see what anyone has had experience with.
Requirements:
Male to Female connection
Corrosion resistance (part will go between water and air possibly once every 10 minutes. Submerged for no more than 2 minutes at a time.
Standard NPT threads are a plus (1/2" or 3/4")
Also, the hose to go with these, any suggestions would be helpful. I found a rubber hose with a wiremesh structure that is intended for high pressure air and/or water application, so will probably go with that.
Thanks all...
I dug deeper into McMaster and found what I was looking for...
The ones you can get from McMaster are made by Snap-Tite. We use them all the time. They are very good fittings. Parker and Aeroquip also make similar products as well.
Here is Snap-Tite's web site:
http://www.snap-tite.com/
Cool, that works. I might be able to find something a little more specific on their sight as well.
I was looking through some threads and came across one where you were posting about your chicken launcher. That sounds sweet. We had made some spud guns where I was before...those things are awesome. We ended up having an actual need for them for launching 2x4's at some structural material...
I am guessing that you were launching them into the intake of an engine?
Thanks again for the link...
Naw, that would be a total waste. It's a barbecue reloading device.
Ha ha ha...
That's hilarious. Since we are cooking things, let's launch a potatoe into a mounted french fry cutter, then have it land in a deep frier... it slices, it dices, it throws scalding hot cooking oil all over the place...
Yup. Birds at engines. Life don't get any better than that.
No prob on the link.
dingpud said:
lets launch a potatoe into a mounted french fry cutter, then have it land in a deep frier... it slices, it dices, it throws scalding hot cooking oil all over the place...
I feel a Rube Goldberg device coming on... :devil:
Since we are cooking engineers, we can somehow incorporate a greasecar...
Swagelok makes excellent high pressure fittings
:smile: I think you just reinvented biodiesel.
yeah, that's kind of what I had in-mind.
it would be a heck of a show at the annual punkin chunkin competition in Delaware...
If you're in attendance at that, we expect pictures.
Yeah, I plan on going this year. Not to compete or demonstrate, but just to observe. I am kind of fortunate, living only about an hour driving distance (or less) from the site.
Will definitely post pictures...
  • · Replies 32 ·
14K
9K
  • · Replies 39 ·
17K
