| Thread Closed |
Riemann integration |
Share Thread | Thread Tools |
| Feb18-08, 11:35 AM | #1 |
Riemann integration
1. The problem statement, all variables and given/known data
Prove that the function specified below is Riemann integrable and that its integral is equal to zero. 2. Relevant equations f(x)=1 for x=1/n (n is a natural number) and 0 elsewhere on the interval [0,1]. 3. The attempt at a solution I have divided the partition into two subintervals, the first with tags different from x=1/n and the second with tags at x=1/n. But, given an epsilon>0, I am not sure how to choose my delta (the norm of the partition) such that the points where the function is not zero doesn't make a contribution. Or, is my approach all wrong? Thanks! |
| Feb18-08, 12:19 PM | #2 |
Maybe not all wrong, but I would say overly complicated. :)
Consider any partition of [0,1]. Note that every subinterval from your partition contains a point not of the form 1/n. |
| Feb18-08, 12:26 PM | #3 |
Yeah, it is sometimes like that if you study independently. :P
So, considering any partition of [0,1]. I should then tag the points different from 1/n, then making all the contributions zero. Right? |
| Feb18-08, 12:51 PM | #4 |
Riemann integration
Wait, a sec, have you seen the result that if a function is discontinuous at a countable number of points then it is integrable?
| Feb18-08, 12:53 PM | #5 |
No, i have not. But I will definetly look for it now.
Thanks! |
| Feb18-08, 01:06 PM | #6 |
Well, if your book hasn't covered this yet, try to do without it.
You want to show that the lower and upper integrals are 0. Prove that the lower riemann sums s(f;P) are 0 for any partition P of [0,1]. This will of course imply that the lower integral is 0. For the upper integral, you want to show that the inf over every P partition of [0,1] of the upper riemann sums S(f,P) is 0. Show that for every epsilon>0, you can always find a partition P' such that S(f;P')<epsilon. |
| Feb18-08, 01:14 PM | #7 |
What you are describing now feels much better, the squeeze theorem. :)
But I don't understand at all, how to deal with the upper integral...? When finding the inf over every partition. I would like to do it in the same way as i treat the lower integral. :S |
| Feb18-08, 04:32 PM | #8 |
And I don't understand your question. :P
| Feb18-08, 04:34 PM | #9 |
Ok. :)
| Feb18-08, 04:51 PM | #10 |
Now, I understand. (I hope so anyway)
When you wrote 'inf' I thought you meant infimum... so I thought that I was really lost since I have never heard of infimum in the context as Riemann integrals. But you must have meant int as in integral, right? And, yes! I am an analysis-rookie. ;) |
| Feb18-08, 05:03 PM | #11 |
I sure meant infimum.
How do you define the upper integral? For me, the upper integral is defined as [tex]\inf_{P\in \mathcal{P}[0,1]}S(f;P)[/tex] where [tex]\mathcal{P}[0,1][/tex] is the set of all partitions of [0,1] and [tex]S(f;P)=\sum_{x_i\in P}\max_{x\in[x_i-1,x_i]}f(x)[/tex] |
| Feb18-08, 05:08 PM | #12 |
Sorry!
I don't define the 'upper integral' at all. For me the 'Riemann integral' is defined as a limit of the Riemann sums as the norm tend to zero. That is why I am talking about the partitions and their tags. I can't find any section with upper Riemann sums either. It is only the Riemann sum. |
| Feb18-08, 05:50 PM | #13 |
I see!
Well in that case it's even simpler! Consider epsilon>0, then for any delta>0, we have that any Riemann sum associated with a partition whose norm is lesser than delta is 0 because in every subinterval of [0,1], there is a point not of the form 1/n! |
| Feb18-08, 09:57 PM | #14 |
Recognitions:
I would procede thusly
clearly the lower integral is 0 take any partition and choose taggeg point where f=0 consider the upper integral suppose the norm is h where 1>h>0 The idea is we want to make a large sum f1h1+f2h2+f3h3+...+fNhN f=0,1 so we choose f=1 whenever possible to take maximum advantage consiger our taggged partition 0=x0=<x*1=<x1=<x*2=<...=<x*N-1=<xN-1=<x*N=<xN=1 we would like n for our tagged partition to include points where f=1 when possible so we begin 1>1-h>...>h+1/2>1/2>-h+1/2>...>h+1/3>1/3>-h+1/3>... however at some point intervals chosen in this way begin to intersect and an adjustment is needed we need to know when 1/n-1/(n+1)<2h elementary algebra tells us this happens when n>N=floor(-1+sqrt(1+1/(2h)))/2 thus the upper integral UI<1/(N+1)+2hN we want something in h alone I leave that to you |
| Feb19-08, 03:02 AM | #15 |
Finally, I understand! Thank you so much! :)
| Thread Closed |
| Thread Tools | |
Similar Threads for: Riemann integration
| Thread | Forum | Replies | ||
| Area - Riemann Sum/Integration problem | Calculus & Beyond Homework | 8 | ||
| Integration vs. Riemann Sums | Calculus & Beyond Homework | 5 | ||
| Fractional Integration and the Riemann Zeta function | Calculus | 0 | ||
| Elements of multiple riemann integration | Calculus | 6 | ||
| Re: Riemann (was: Reimann) Integration | General Physics | 0 | ||
