Thread Closed
there exists one number N
Share Thread Thread Tools
Mar27-08, 02:04 PM   #1
The set N of natural numbers = {1, 2, 3, 4, ...}.
But there exists one (1) number N, such that
N = 12345678910111213... (where the unit's place is at infinity).
A good example of an irrational number then would be
1.234567891011121314...
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Mar27-08, 02:06 PM   #2
Quote by arbol View Post
N = 12345678910111213... (where unit's place is at infinity).
Doesn't that make N = infinity?
Mar27-08, 04:09 PM   #3
Recognitions:
Homework Helper Homework Help
so, put a decimal in front of it.
oh he did that.
Mar27-08, 05:13 PM   #4
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
No, there is no such number. All integers have only a finite number of digits. By the way, it is not at all a good idea by using "N" to represent the set of natural numbers and then say that "N" is a number.
Now THAT is a perfectly good irrataional number.
Mar27-08, 06:05 PM   #5
Recognitions:
Are you sure that decimal string actually denotes a number? How can the unit's place be 'at infinity'? What digit is in the unit's place?
Mar27-08, 07:36 PM   #6
Recognitions:
That's 10 times Champernowne constant.
Mar28-08, 06:54 AM   #7
Recognitions:
If it were possible to construct any irrational number by putting a decimal into some positive integer, that would imply that the set of irrational numbers is countable.
Mar28-08, 01:23 PM   #8
Quote by Hurkyl View Post
good question
Mar28-08, 01:24 PM   #9
Quote by HallsofIvy View Post
It is necessary that N is not an interger, but it is one number.
Mar28-08, 01:25 PM   #10
you can call it anything you want
Mar28-08, 01:27 PM   #11
Quote by belliott4488 View Post
lim f(x) (as x approaches infinty) is infinity, but N is a single number (not a variable).
Mar28-08, 01:32 PM   #12
a definition of an irrational number is a number that cannot be expressed in the form m/n, where m and n are intergers and n not equal to zero. such numbers are infinite to right of the decimal point and do not repeat. for example,
1.234567891011...
Mar28-08, 01:57 PM   #13
Recognitions:
Yes, so together with Hallsofivy's statement you know that 123456789101112... is not an integer.
Mar28-08, 06:01 PM   #14
All Numbers must have a meaning such that a rational number can be found to approximate the number within a chosen value, a expression that is an infinite string of numbers without any fixed decimal point does not have any meaning and is not a number.
Mar30-08, 06:39 AM   #15
Recognitions:
good question
Yes it was. Since it was about your post, do you have a good answer?
Okay, what do you mean by "number". And my criticism was simply about using the same symbol, N, with two different meanings.
Thank you. But I do prefer to use standard terminology. If you did that, it might be easier to understand what you are trying to say.
??This is the first time you mentioned "f(x)". Where did that come from. Once again, the N you posit is NOT a "number" by any standard definition.
1.234567891011...
Yes, we know that- it is not necessary to state the obvious.
Mar31-08, 04:53 PM   #16
Yes. I think it does.
If f(x) = x, then
lim (of f(x) as x approaches infinity) = infinity = N. (but the unit's place of N is at infinity.)
Mar31-08, 06:12 PM   #17
Recognitions:
But since "infinity" is not an integer, you know that N isn't an integer.
Thread Closed
Thread Tools
Similar Threads for: there exists one number N
Thread Forum Replies
proving that a real number exists in between a real number, Calculus 19
i need to know if this exists Advanced Physics Homework 2
God exists ?! General Discussion 100
Therefore God Exists General Discussion 2
Does God Exists? General Discussion 40
