Does a relativistic rolling ball wobble?
  • #51
JesseM said:
I think it is the equation for the sphere's surface at a given instant when it is centered at the origin and moving on the x'-axis. The equation describes an ellipsoid with radius r along the y' and z' axis, but Lorentz-contracted radius r/\gamma along the x'-axis...is this not correct?
"moving" was key in my answer.
His equation is the snapshot for t=0, so we agree.
The correct equation is:
\frac{\gamma^2 (x'-vt')^2}{r^2}+\frac{y'^2}{r^2}+\frac{z'^2}{r^2}=1
  • #52
Ah, OK. But one point that occurred to me is that if we're just looking at the total set of points occupied by the surface at any given instant, rather than trying to track an individual point on its surface, then in the rest frame of the sphere's center the coordinates of the surface won't be changing with time, so it will always occupy exactly the same coordinates as a certain nonrotating sphere centered at the same position. And if the surface of the nonrotating sphere occupies the same set of coordinates in this frame, its surface must occupy the same set of coordinates as the rotating sphere in every frame. So, this is one way of seeing that the rolling ball won't "wobble". The difficulty is just in figuring out how a given point on the rotating sphere will move around this ellipsoid surface in a frame where it's in motion.
  • #53
I think that we can do the "tracking" by converting the problem to cylindrical coordinates and by describing the angle \phi=\phi(t) as a function of time.
  • #54
kev said:
I am aware that that there is no length contraction perpendicular to the linear motion of the rolling sphere. I can guarantee that if the centre of mass is in the centre of the ball in its rest frame then it is not in the geometrical centre of the ball when it is rolling with respect to the observer. The centre of mass is further away from the point of rolling contact than the geometrical midpoint between the top of the rolling ball and the point of contact.
I think you need to have a look at http://www.spacetimetravel.org/filme/radv_t_0.93/radv_t_0.93-xe-320x240.mpg , there is no wobble. You can see more of the same.
  • #55
Antenna Guy said:
Are you aware that this relativistic 'ball' does not necessarily have an instantaneous circumference (per se) in the frame of the observer?
I'm afraid I haven't been clear. The ball rolls without slipping. Therefore it spins was well as translates.
In the inertial frame of the ball's center of mass the circumference is contracted from it's length at rest. The various radii are not contracted, because their extent is perpendicular to the instantaneous velocity develped by rotation.
Knowing this, the ball cannot be considered a rigid object. In fact relativity and rigid objects are contradictory in principle. This is why most answers given to pushing a long, relativistic stick down a short hole are flawed.
Until anyone trying to answer the original question addresses the shape the ball in a given, non-translating inerital frame, and what parts of the ball remain invariant under rotation, they're blowin' smoke.
  • #56
First of all, when discussing relativity we normally discount purely visual effects to get objective measurements. The links you provided have animations that include the visual effect of Terrell rotatation that obscure the physics as far a relativity is concerned unless of course we were specifically investigating Terrell rotation.
Having said that, I have taken the liberty of modifying an image from one of the pages you linked to, to illustrate the point I was making in the post you responded to. The white blobs on the rims of the attached image are equal masses placed at the end of each spoke. (Assume the spokes, hub and perimeter have insignificant mass compared to the white test masses). The red wheel is not rotating and joining opposite pairs of masses shows the centre of mass is at the physical axle of the wheel. Joining opposite pairs of test masses on the green wheel, which is moving at relativistic speed to the observer, shows that the centre of mass (the light blue dot) is now much higher than the physical axle of the wheel. I think you will agree that this vertical shift of the centre of mass is not significantly affected by the Terrell rotation that causes an optical horizontal shift of parts of the object.
If you look at the bold part of my statement above my guarantee was that the centre of mass is not in the geometrical centre of the ball or wheel. I did not guarantee that the centre of mass wobbles. However, I will try and show later that is some wobble of the centre of mass, using geometrical software. I suspect this wobble is corrected by a counter rotating torque, generated by torque reactions that are result of force not always being parallel to the acceleration, in a transformed reference frame.
  • #57
OK, I am not working today so I decided to start this. Here is an equation for the worldline of a particle on a rotating hoop in the reference frame where the axis of rotation is stationary.
s=(t,\cos (\phi +t \omega ),\sin (\phi +t \omega ),0)
in units where c=1 and r=1
Which can be differentiated to obtain the four-velocity
u=\left(\frac{1}{\sqrt{1-\omega ^2}},-\frac{\omega \sin (\phi +t<br /> \omega )}{\sqrt{1-\omega ^2}},\frac{\omega \cos (\phi +t \omega<br /> )}{\sqrt{1-\omega ^2}},0\right)
Which can be differentiated to obtain the four-acceleration
a=\left(0,-\frac{\omega ^2 \cos (\phi +t \omega )}{1-\omega<br /> ^2},-\frac{\omega ^2 \sin (\phi +t \omega )}{1-\omega ^2},0\right)
A quick check shows u.u=1 and u.a=0
I then transformed the hoop into the frame where it rolls without friction
s&#039;=L.s=\left(\frac{t+\omega \cos (\phi +t \omega )}{\sqrt{1-\omega<br /> ^2}},\frac{t \omega +\cos (\phi +t \omega )}{\sqrt{1-\omega<br /> ^2}},\sin (\phi +t \omega ),0\right)
and then differentiated to obtain u' and a'. I verified that u'=L.u and a'=L.a and that u'.u'=1 and u'.a'=0. So, kinematically everything works out just fine. I didn't actually work out the four-forces nor the tension on a differential element.
So then, to answer the question about the shape of the hoop in the primed frame I need to look at all of the points for a single value of t'.
t&#039;=\frac{t+\omega \cos (\phi +t \omega )}{\sqrt{1-\omega<br /> ^2}}
I could not solve this equation for t as described above, but I could solve it for phi to obtain
\phi =-t \omega \pm \cos ^{-1}\left(\frac{t&#039; \sqrt{-(\omega -1)<br /> (\omega +1)}-t}{\omega }\right)
Substituting this back into the expression for s' gives an expression for the shape of the hoop at a given t' in the frame where it is rolling
\left(t&#039;,\frac{t&#039;-t \sqrt{1-\omega ^2}}{\omega<br /> },\pm \sqrt{1-\frac{\left(t-t&#039; \sqrt{1-\omega<br /> ^2}\right)^2}{\omega ^2}},0\right)
I plotted this for a couple of different values of t' and it appears to be a "grape" that does not wobble.
  • #58
In the inertial frame of the ball's center of mass the circumference is contracted from it's length at rest. The various radii are not contracted, because their extent is perpendicular to the instantaneous velocity develped by rotation...
The simple assumption that the spokes of rotating wheel without linear translation are not length contracted is in fact an over simplification because the principle of equivalence tells us that the acceleration due to rotation is similar to being in a gravitational field and there will be length contraction of all the spokes, with the greatest radial length contraction of the spokes occurring near the rim because that is where the acceleration is greatest. That is drifting into GR teritory and we probably don't need to go to that extent at this point.
We should be clear that the radii parallel to the linear translation of the rotating ball will be length contracted due to the linear motion superimposed on the rotation.
  • #59
Very nice, thank you !
  • #60
The shape of the Lorentz transformed hoop (rotating or not) is simply and formally a geometrical ellipse. (I can show you that the theory of relativity is falsified if that is not the case). I think we are agreed that the transformed outline of the hoop or ball does not change with time. The question, I think is more about the location of the centre of mass. If it does not remain constant over time, then you would expect the hoop or ball to "bounce" or wobble with an oscillating centre of mass rather than move in a straight line. The simplest way to analyse this, is to take just two test "point masses "on opposite sides of the hoop and find their combined centre of mass at any instant in the transformed frame.
  • #61
This is not correct. The animations provided use the exact equations (very similar to the ones just derived by DaleSpam). They use rays of light with simultaneous arrival time in order to answer the question "how does the perimeter of the sphere (or spoke wheel, arbitrary object, etc.) look in the observer 's frame at the same time t'?" .
So, contrary to what you think, in this particular application the Terrell effect is not just an illusion, it is the mechanism of determining the dimensions of a moving object by marking its extremities simultaneously. It so happens that the raytracing programs are using rays of light for this purpose.
  • #62
Yes, you seem to have proven that (at least your images seem to indicate that to be the case since the spokes appear to be bent upwards). Since the spokes appear permanently bent upwards you will also note that the distance between the center of gravity and the rail doesn't change, so, there is no reason for wobbling.
In addition to the above, the fact is that the center of rotation (the wheel axle) remains at constant distance from the supporting rail. So, the wheel will not wobble. This is supported by all the linked animations where the wheel remains in permanent contact with the rail. So, again, no reason for any wobble.
  • #63
1effect said:
This is not correct. The animations provided (please note that they are done by professional phycists) use the exact equations (very similar to the ones just derived by DaleSpam). They use rays of light that arrive simultaneously in order to answer the question "how does the perimeter of the sphere (spoke wheel, arbitrary object, etc.) look in the observer frame at the same time t'?" .
So, contrary to what you think, the Terrell effect is not just an illusion, it is the mechanism of determining the dimensions of a moving object by marking its extremities simultaneously. It so happens that the raytracing programs are using rays of light for this purpose.
I'm not sure what you mean by "determining the dimensions of a moving object"--the Terrell effect will distort the length of objects from their "correct" length in the observer's coordinate system, making the visual length longer than the Lorentz-contracted length the object actually has in the observer's coordinate system (see this thread). And the animations you show are about visual appearance, not about the spatial coordinates occupied by different points on the object at a single coordinate time.
  • #64
JesseM said:
I'm not sure what you mean by "determining the dimensions of a moving object"--the Terrell effect will distort the length of objects from their "correct" length in the observer's coordinate system, making the visual length longer than the Lorentz-contracted length the object actually has in the observer's coordinate system (see this thread). .
What I mean is that this is raytracing , using only the rays of light that arrive simultaneously from the object endpoints. Thus, these rays act as the standard way of marking the object endpoints. The Terrell effect is just a byproduct of the method used for rendering (collecting simultaneously arriving rays). It is intereresting to read the notes and the paper included in the website. In fact, the authors are giving a superset of the Terrell paper.
I think that in these particular cases, the two coincide, the rays of light act as ways of marking the points on the object's periphery simultaneously, exacly like in DaleSpam's equations posted here.
  • #65
The ray tracing program uses rays of light to show what one one observer would visually see. A reference frame has an infinty of observers and there would be one observer at the back of the wheel/ball and one at the front of the ball to elliminate light travel times and take meaurements with previously syncronised clocks and compare notes later to get the measurements of the moving ball or wheel.
They might well be using exact equations, but the image is the point of view of an observer to one side and slightly above the table with a bit of distance perspective thrown in which is not good for us to make exact measurements from. The vertical displacement of the centre of mass is so great it is obvious despite the optical embelishments.
A rod with constant velocity relative to an observer appears to be longer when it is approaching a single observer and shorter as it goes away from the observer which is what a ray tracing program would show, but that obscures the fact that the length contraction is constant whether the rod is approaching or receding. Ray tracing is not a good method for objectively analysing Lorentz transformations.
[EDIT] Anyway, is anyone is interested here is a sketch of a beach ball progressively rolling faster with respect to the observer.
  • #66
Yes, that's what the Terrell effect is about too. But just because they arrive simultaneously doesn't mean they were emitted simultaneously. Again, see the thread I linked to--when you calculate the visual size of an object based on rays from different ends that reach the observer's eyes simultaneously, she will actually see the object as being no different than its visual size at rest when at the same distance, despite the fact that the object is "really" Lorentz-contracted in her frame.
  • #67
True. You don't want them emitted simultaneously. You want them simultaneous in the observer's frame (you want to mark the object's ends simultaneously in the observer's frame, the same way DaleSpam did it) . This is exactly what the authors do.
  • #68
True. You keep missing the point that both the center of mass and the center of rotation do not change their distance to the supporting rail, therefore there is no reason for any wobbling. This is what the OP is all about :-)
  • #69
I am not going to specifically address the issue of wobble until someone can give an exact equation for the height of the centre of mass of a rolling wheel (without slipping) with a linear velocity of say 0.8c and two opposite point masses of 1M each at any point point during the rotation. I am not going to base the argument on a ray tracing program designed to entertain the masses, rather than come to any analytical conclusions.
  • #70
Visually it certainly looked like an ellipse, but I didn't go through the effort to prove it so I thought it best to just call it a "grape".
I didn't cover that in my analysis. I don't think you can simply find the center of mass of two opposing points, I think you will need to integrate around the whole hoop.
I would know how to do this easily if I could have solved for t instead of phi, but as it is I am not sure how to proceed. I would have to think about this a bit.
  • #71
kev said:
The shape of the Lorentz transformed hoop (rotating or not) is simply and formally a geometrical ellipse. ... The simplest way to analyse this, is to take just two test "point masses "on opposite sides of the hoop and find their combined centre of mass at any instant in the transformed frame.
If it helps, I think you can use the following for two points directly opposite on the ellipse:
r&#039;=\frac{r(1-e^2)}{1 \mp e sin(\phi)}
where
e=\sqrt{1-\frac{1}{\gamma^2}}
and \phi follows DaleSpam's convention.
I quickly adapted the above from some relations I derived for gregorian reflector systems (once upon a time), so check to make sure that x' (r&#039;cos(\phi)) and y' (r&#039;sin(\phi)) do in fact follow an appropriate ellipse before devoting much time to them.
Regards,
Bill
  • #72
Your response is very confusing. When you say "you want them simultaneous in the observer's frame", what does "them" refer to? Does it refer to the events of the back and front ends emitting photons which arrive at the observer's eyes at the same time? If so, then in this case they are emitted simultaneously in the observer's frame, so your comment "you don't want them emitted simultaneously" doesn't make sense, unless you are talking about simultaneity in some frame other than the observer's (though you never mentioned any other frame). And if it refers to some different pair of events which are simultaneous in the observer's frame, then what are those events exactly?
  • #73
You want the rays arriving simultaneously in the observer's frame.
You don't want the rays emitted simultaneously in the moving object frame. I am sorry, I thought I was quite clear .
  • #74
You never said anything about the moving object's frame, and neither did I. My point was that if the rays arriving simultaneously at the observer's eyes were emitted at different moments in the observer's frame then the visual length will be different from the length in the observer's frame.
  • #75
Errata
Thinking again, maybe not.
The equations were adapted from a focal point relation (phi about a focus), so the phi adaptation I made is incorrect.
Anyhoo, if someone would find it useful to express r' relative to a foci, I could re-work it.
Regards,
Bill
  • #76
The argument is not based on raytracing, it is based on the fact that in the frame comoving with the sphere center there is no wobble. In this particular frame we know that the center of mass coincides with the center of rotation and the sphere (or wheel) doesn't wobble.
So, in the observer frame, the sphere (or wheel) cannot wobble either. You can't have physically different results in the two frames.
The raytracing program simply gives a visual confirmation for the above.
  • #77
Your argument is what bwr6 called a principled argument. We know relativity predicts that the rolling ball does not wobble in the comoving frame, but that tells us little about the physics that is going on and you are not necessarily correct to jump to the conclusion that the centre of mass stays in one place as the ball rolls with constant velocity.
It is possible that centripetal forces of the masses on the rim cause accelerations that are not parallel to the the force vectors and do not act through the instaneous centre of mass. In fact I believe the centre of mass has to move to compensate for the anisotropic centripetal forces, to prevent the "wobble".
I have attached a screendump from geometrical software that I used to simulate the motion of the particles under transformation. A line joining the red and blue particle shows the instantaneous centre of gravity and the two parallel black lines in the lower part of the diagram show the heights of the centre of mass at different points during the rotation of the ball. I have taken reasonable care to ensure an accurate simulation but I can not deny that the time dependent vertical harmonic motion of the centre of mass of the horizontally moving ball, may be an artifact of the resolution and accuracy of the geometrical software.
  • #78
The results of your simulation depend on the equations you used. I would be very interested in seeing them.
  • #79
Since the point-trails follow elliptical paths, they seem to be "rotating" about two centers of mass displaced in time. By "rotating", I mean a string of length \frac{2r}{\gamma} tied off to two foci (centers of mass) displaced in time by 2r\sqrt{1-\frac{1}{\gamma^2 }} seconds should transcribe an ellipse (when held taut while rotating about the midpoint of the two foci) half the size of your point trails (analogous to the 2r radius hoops in the non-relativistic case).
For the time displacement, I rotated what I calculated for the focal point separation of the Lorentz-contracted ellipsoid 90 deg.
Regards,
Bill
P.S. I'm having a heck of a time with LaTeX today...
  • #80
Well, I couldn't figure out how to determine the center of mass, but I did figure out how to color my Mathematica plots according to phi. So, if you look at the attached plot this is
plotted for w=0.9c with t'=0 on the left and t'=1 on the right. In the coloring, each repetition of a given color represents a 30º chunk of hoop in the frame where the axis of rotation is stationary. So, for example, look at the left picture where the amount of hoop between the two blue spots next to the positive y-axis is equal in mass to the amount of hoop between the two blue spots closest to the negative y axis. This is despite the fact that the distance is much greater on the bottom in this frame. In other words, the hoop is more "dense" on the top than the bottom.
This picture doesn't give you an analytical equation for the center of mass, but visually you can see that the center of mass will be somewhere on the positive y-axis for both hoops. I cannot guarantee or prove it, but it looks to me like the center of mass doesn't change it's y-coordinate, although the y-coordinate of the center of mass is not 0.
  • #81
Easy. The particles in the edge of ball are rotating. At angular speed C*R (Hoping R<1 because if not Einstein gets mad). Then the contraction it's in the direction of the velocity (whicks keeps changin beacuse of the rotation). Then there's another movement seen form the center of the mass also at speed C. Using analytical mechanics for rigid bodies with the realtivistic vectorial sum of speeds theorem you'll get the right awnser. (So ofrcourse it won't roll as a grape, thinking that is just a consequence of treating the rigid body as a point particle)..
Hope it hepls. :)
  • #82
I think there's a video around http://www.tubepolis.com of a numerical simulation of this. Look for rolling relativistic ball. :)
  • #83
It is not very difficult to show that , indeed, the y coordinate of the center of mass is constant. So, the hoop doesn't wobble.
  • #84
Since the result you claim is important to the the whole point of this thread please show this explicitly.
  • #85
It is not clear to me how Dalespam was able to plot the last equation that contains both t' and t when he has stated it is not possible to solve for t in terms of t'.
Let's take the equation he derived that equation from and insert some numerical values.
Say time = 0 in both frames and and R=1 and w=0.8c in the rest frame.
We take the the positions of 4 elements a,b,c and d at the 4 points of the compass where phi = 0, 90, 180 and 270 degrees. Now insert these values into the equation for the rest frame (s):
and we get (x,y) coordinates a=(1,0), b=(0,1), c=(-1,0) and d=(0-1) in frame s.
Now if we insert the same values into the transformed equation:
s \single-quote=L.s=\left(\frac{t+\omega \cos (\phi +t \omega )}{\sqrt{1-\omega ^2}},\frac{t \omega +\cos (\phi +t \omega )}{\sqrt{1-\omega ^2}},\sin (\phi +t \omega ),0\right)
we get (x',y') coordinates a'=(1.67,0), b'=(0,1), c'=(-1.67,0) and d'=(0,-1) in frame s'.
It can be seen that the transformed ball is wider than it is high by this equation which is a false result. This is due to the "catch 22" situation of not being able to calculate phi without knowing how the proper time of each element transforms and it is not possible to calculate how the the proper time of each element transforms without knowing how phi transforms. On the face of it, the equation is not taking the simultanity issues into account between the transformed frames.
This can be seen when we do the calculations for the transformed time and space coordinates (t',x',y') to get a'=(1.33,1.67,0), b'=(0,0,1), c'=(-1.33,-1.67,0) and d'=(0,0,-1) in frame s'. The time t' is not simultaneous in the s' frame. I do not think Dalespams equation are wrong, but it does not seem that they resolved the issues of how the dimensions of the ball would be measured simultaneously in the transformed frame without doing numerical aproximations.
  • #86
Imagine we have a rotating wheel with the axis of rotation stationary if frame S with a pen attached to the rim of the wheel and a moving paper chart behind the wheel on which the pen draws a graph. The path of the the pen in this frame is a circle and the graph is a cycloid. The equation for the circle and cycloid (in parametric form) are well known. In frame S' the observer is co-moving with the paper chart.The paper chart was length contracted in frame S because it was moving in that frame, so in frame S' the paper (and graph) is "stretched" in the direction parallel to the relative motions of the frames, so the equation for the transformed cycloid is the conventional parametric equation with x*gamma substituted for x. The transformed circle path is simply an ellipse with semi-minor axis (b) and semi-major axis (a) with the relationship b=a/gamma. The exact location of the pen at any time t' in the transformed frame is the intersection of the elliptical path and stretched cyloid graph. Finding the intersection mathematically is very difficult (although it might be possible using the Lambert W function which I think is implemented in Mathematica). Fortunately the free geometrical software I use, called "CaR" for Compass and Ruler can compute the intersection of two locii but I am pretty sure it uses numerical techniques to achieve this. Most commercial geometrical software is unable to find the intersection of two locii.
  • #87
So, do you have any equations to drive your drawings or not ?
  • #88
Isn't your "stretched cycloid" an elliptical path twice the size of the transformed circle (albeit rotated 90deg, and translated such that its' center lies on the x-axis)?
Regards,
Bill
  • #89
Unless I'm not reading your picture correctly, the "chunks of hoop" appear to be rotating in the wrong direction.
Regards,
Bill
  • #90
Hmm, I should have numbered my equations to make talking about them easier. There are 7 equations in total, so eq1 is the first equation and eq7 is the last.
It was not possible to solve eq5 for t. But I could determine the range of t directly from eq7, I just left it out for brevity, but here it is explicitly:
The y-coordinate in eq7 is imaginary unless
1-\frac{\left(t-t&#039; \sqrt{1-\omega ^2}\right)^2}{\omega ^2}\geq 0 eq8
which gives:
t&#039; \sqrt{1-\omega ^2}-\omega \leq t\leq t&#039; \sqrt{1-\omega ^2}<br /> +\omega eq9
Actually, that is correct. If you take a set of events which are simultaneous in the axis frame then they are not simultaneous in the rolling frame, and their transformed locations are "smeared" out such that it is wider than it is high.
Eq5 takes simultaneity into account in the rolling frame, and therefore eq7 describes events which are simultaneous in the rolling frame.
Of course your events are not simultaneous in the rolling frame, they are simultaneous in the axis frame! That is why I went to the bother of obtaining eq7 instead of just stopping with eq4.
  • #91
Regards,
Bill
Hi Bill,
I tend to agree with your observation. There appears to be a small mistake in DaleSpam's original equation that has the ball rotating counter clockwise while translating from left to right in the positive x direction which does not agree with the contact point being at the bottom. This is a non fatal error that is easily corrected by reversing the sign of the y coordinates.
which gives:
Hi Dalespam,
Of course I agree that events that are simultaneous in one frame are not simultaneous in the other. The point I was trying to make is that using eq7 we are still required to determine t for a given t' in eq7 by numerical aproximation using eq5. Do you agree?
By reversing the signs of the y coordinates (see above comment to Bill) to get the ball rotating in the same direction as the linear motion and by using the solve function of a spreadsheet to determine t in eq7 I get the following results for t'=0 in frame S' for four particles on the rim of the hoop with coordinates expressed as (t,x',y') where t is the proper time of each particle. (Assume w = v =0.8c where v is the relative velocity of frame S and S')
a' = -0.683390604 0.512542953 0.519881721
b' = 0.000000000 0.000000000 -1.000000000
c' = 0.683390604 -0.512542953 0.519881721
d' = 0.000000000 0.000000000 1.000000000
where in the frame at rest with axis of rotation the (x,y) coordinates for the particles are a = (1.0), b = (0,-1), c = (-1,0) and d = (0,1).
It can be seen that the y' coordinates of particles a and c are the same and above the centre of the axis rotation by a distance of 0.519881721 so we can assume the centre of mass for this pair of particles is at (x',y') = (0,0.519881721)
Now if we look at the pair of particles at the top and bottom of the ball (b and d), the particle at the contact point has a momentary velocity of zero in frame S' and the particle at the top has a velocity of 0.975609756c by velocity addition. If we assign a value of 1 to the rest mass of the particles then the particle b at the contact point has a inertial mass of 1.00000 and particle d has an inertial mass of 4.55555. The centre of mass of these two particles assuming radius (R=1) is found from 2*R*mb/(mb+md)-R = 0.64R or (x',y') = (0, 0.64) in terms of coordinates.
From the above it can be seen that the centre of mass when the particles are vertically alligned in S' is at y'=0.64 and moves to y'=0.519881721 after the particles on the hoop have completed a quarter rotation. Therefore the height of the centre of mass does not remain constant in time for a rolling object with constant linear and rotational velocity in the transformed frame. That is something we have to live with and it necessary to find a compensating factor such as stress in the connecting rod or hoop joining the test masses, or a counter rotating ghost torque to sort things out (to justify no wobble observed in the rest frame of the rotation axis).
P.S. DAleSpam, I am not being critical of your work (I think it very good and the most positive and technical contribution to this thread so far ;)
  • #92
kev said:
By reversing the signs of the y coordinates ... and by using the solve function of a spreadsheet to determine t in eq7 I get the following results for t'=0 in frame S' for four particles on the rim of the hoop with coordinates expressed as (t,x',y') where t is the proper time of each particle. (Assume w = v =0.8c where v is the relative velocity of frame S and S')
I don't think that your conclusion follows from your analysis. It seems to me that, according to your analysis, when pair bd has center .64 pair ac has center .52 for an overall center of .58. Then, after a "quarter rotation" pair bd will have center .52 and pair ac will have center .64 for an overall center of .58. So the overall center of mass of all four points will be the same every "quarter rotation".
The hoop has more than two (or even four) particles. I think you need to integrate around the hoop, or at least do a numerical approximation to the integral.
  • #93
kev said:
Hi Bill,
Another way to correct it would be to start over with:
<br /> s=(t,\cos (\phi -t \omega ),\sin (\phi -t \omega ),0)<br />
Regards,
Bill
  • #94
I wondered if someone would raise that argument. The counter argument is this. A wheel with just two significant masses on opposite sides of the rotation axis will be balanced in the reference frame that is stationary with respect to the rotation axis. Therefore we should not have to rely on 4 masses to negate any wobble. In normal (Newtonian) physics a barbell with two main weights of equal mass on the ends of a bar when thrown through the air will rotate about its centre of mass. Relativity should be able to predict that the rotating barbell will not wobble when moving linearly and rotating at the same time without requiring four or more masses or a hoop to prevent wobble of the centre of mass.
  • #95
That's a good argument, although it really doesn't apply for the hoop geometry described by my equations. For a hoop I think the best conclusion is that the center of mass is stationary.
I would not recommend using my hoop equations to draw conclusions for the barbell geometry.
  • #96
You started out with a single point on a given trajectory - why would that not hold for any number of points along the same trajectory?
Regards,
Bill
  • #97
You have to get rid of the variable phi and add a variable r.
I think it is an interesting problem, but it is a different problem than the one I worked.
  • #98
Forgive me I just deleted this post and have to retype it so I am bound miss something I put before.
I have been studying the Dale's attachments on post 80 and they have been bothering me for some reason. Last night I think I finally realized why. To begin with some basic information about the drawings as I understand them.
1) The rings are in the roads view.
2) The colors represent 30 degrees in the starionary axis view.
3) c=1
4) r=1
5) v = .9c
I looked at the velocity of a particle in the roads view. Using the basic equation for velocity:
V = \frac{D}{T}​
I asked what if the wheel rolled forward pi/4. This yields the equation:
.9c = \frac{pi/4}{T}​
Then I looked at the distance the left most particle on the wheel would have traveled. To do this I first noticed that because of length contraction the bottem half of the wheel only contains 90 degrees. There for when the wheel turns pi/4 the left most particle will travel to the very bottem of the wheel. This is a distance of at least r (just look in the Y direction only). So using the same time as a pi/4 roll T, by particle has moved with velocity:
V' = \frac{1}{T}​
Dividing the V' equation by the V equation I get:
V'/.9c = \frac{1}{pi/4}​
Which yields the particles velocity V' to be 1.15c.
This obviously can not be correct though. I assume I am missing something. Can anyone help me understand what I did wrong?
  • #99
You can't draw any reasonable conclusion by using point particles attached to the circumference, you need to use the correct calculations, based on integrals.
In the frame S, comoving with the object, the center of mass (y-coordinate) is:
y_M=\frac{\int y \rho dV}{\int \rho dV}=\frac{\int y dV}{\int dV}
The center of mass coincides with the center of rotation because of the radial symmetry.
In the observer's frame S':y&#039;_M=\frac{\int y&#039; \rho&#039; dV&#039;}{\int \rho&#039; dV&#039;}=\frac{\int y \gamma dV}{\int \gamma dV}= y_M
  • #100
Hi 1effect,
I am not sure how you got to your conclusions because you have not provided much detail. For example what is V? Is it volume? Anyway, you seem to conclude that y coordinate of the centre of mass in the S' frame is at same height as the centre of mass in the S frame. Dalespam reached the opposite conclusion that the height of the centre of mass of the rolling ball is higher in S' than in S and his conclusion is in agreement with the fairly well known fact that the centre of mass of a rotating object is not invariant under Lorentz transformation. It seems you have reached a false conclusion.
