Does the Ratio Test Guarantee Divergence? Proving with Bernoulli's Inequality
The discussion revolves around the application of the Ratio Test in determining the behavior of a sequence defined by the limit of the ratio of its terms. The original poster seeks to show that if the limit of the ratio of consecutive terms is greater than 1, then the sequence diverges to infinity. The problem also involves deducing that the terms of the sequence do not approach zero.
  • Participants discuss the possibility of using induction to prove the inequality between consecutive terms of the sequence. Questions arise regarding the validity of certain assumptions and the implications of the limit being greater than or less than 1. There is also mention of using Bernoulli's Inequality to support the argument.
Participants are exploring various interpretations of the problem, particularly focusing on the implications of the limit being greater than or less than 1. Some guidance has been offered regarding the use of Bernoulli's Inequality and the need for a structured approach to induction, but no consensus has been reached on the specific steps to take.
There are discussions about the constraints of the problem, including the requirement to show certain inequalities for indices greater than a specified N. Participants also express confusion about the application of mathematical concepts and notation, indicating a need for clarification on these points.
dtl42
Show that if [tex]Lim|\frac{a_{n+1}}{a_{n}}| = L > 1,[/tex] then [tex]{a_{n}\rightarrow \infty[/tex] as [tex]n\rightarrow\infty[/tex]
Also, from that, deduce that [tex]a_{n}[/tex] does not approach 0 as [tex]n \rightarrow \infty[/tex].
The book suggests showing some number r>1 such that for some number N, [tex]|a_{n+1}|> r|a_{n}|[/tex] for all n >N.
Okay, and what have you done on this problem? Have you shown, perhaps by induction on n, that [itex]|a_{n+1}|> r|a_n|[/itex]? Once you've done that, you might consider the "comparison test".
How would I start that proof by induction? How can I verify that [itex] |a_{2}|> r|a_{1}|[/itex]. Also, for the second part, once I show that [tex]|a_{n}|[/tex] tends to [tex]\infty[/tex] isn't it basic logic that [tex]a_{n}[/tex] cannot approach 0?
You can't. It's not necessarily true. However, since the limit [itex]a_{n+1}/a_n[/itex] is less than 1, it must be true for some N. Start your induction from that.
Yes, it is. Just state the basic logic.
Do you mean greater than 1, or am I really missing something? And how would I start the induction? Just that for some N, [itex]|a_{2}|>r|a_{1}|[/itex]?
If L>1, then is the sequence [tex]{a_{n}}[/tex] bounded or unbounded?
Suppose not, If L<1, then what happens when [tex]{\lim }\limits_{n \to \infty } a_{n}[/tex]?
If L>1 then the sequence would be unbounded right? Because the next larger term is always of a greater magnitude than the previous. If L is less than 1, then the sequence is bounded, and the limit goes to 0?
Correct.
Now, since book suggested: show that [tex]|a_{n+1}|> r|a_{n}|[/tex] for all indices [tex]n\geq N[/tex], you can use the Binomial formula to show that the sequences is unbounded. Hope that's clear.
REALLY IRRELEVANT but...
i've always wondered this, but how do you guys get all those math symbols in there? like the absolute value symbol, or the greater than equal to sign?
It's LaTeX https://www.physicsforums.com/showthread.php?t=8997
konthelion said:
Correct.
What do you mean by the Binomial Formula? I'm still kind of confused after taking several days away.
Well, you can use Bernoulli's Inequality, which is [tex](1+b)^n \geq 1 +nb[/tex]
Suppose that [tex]L>1[/tex], then define [tex]b=\frac{L+1}{2}[/tex] since b<L. There exists a natural number N such that
[tex]\frac{a_{n+1}}{a_{n}} \geq b[/tex] for all indices [tex]n \geq N[/tex] (just a reiteration of the problem)
From here, use the Bernoulli's inequality to show that for some k and let r = [tex]b^k[/tex], then [tex]|a_{N+k}| \geq r|a_{N}|[/tex] which implies that the sequence [tex]a_{n}[/tex](the hint that your book gave) is unbounded.
