How Do You Calculate Tension in Two Ropes Holding a Suspended Object?
  • Thread starter Thread starter k1point618
    Force Tension
The problem involves calculating the tension in two ropes holding a suspended object with a mass of 5 kg. The ropes are of different lengths (3m and 5m) and are fastened at different heights, making angles of 52 degrees and 40 degrees with the horizontal.
  • Mixed
  • Participants discuss the relationship between the tensions in the ropes and the gravitational force acting on the object. There are attempts to express the vertical and horizontal components of the tensions and how they relate to the mass and angles involved.
Some participants have provided guidance on drawing force diagrams and applying Newton's second law. There is an ongoing exploration of the implications of the angles and the lengths of the ropes, with questions about the relevance of the heights at which the ropes are fastened.
There is some confusion regarding the phrasing of the problem, specifically about the suspended object being "over a ceiling" and the significance of the heights of the ropes. Participants are questioning whether this information is necessary for solving the problem.
k1point618
Ropes 3m and 5m in length are fastened to an object that is suspended over a cieling. the object has a mass of 5kg. the ropes, fastened at different heights, make angles of 52 degree and 40 degree with the horizontal. Find the tension in each wire, and the magnitude of each tention.
I kno that the tension on one rope, A and the tension on the other rope, B equal to the mass times gravity.
so AT+BT = mg
and i want to find the a equation for AT and BT
Just wondering, since i kno the angle and length of the rope, i know the vertical component of the rope. But then i don't kno where to go after that
What you need to do is draw a force diagram and write down all the horizontal and vertical components of tension as a result of the mass.
Next, you need to use Newton's second Law and find the net force in both horizontal and vertical directions.
Just remember that net force (vector sum of components) = ma, and if the object is not moving, then the net force is zero.
Hi k1point618! :smile:
k1point618 said:
so AT+BT = mg
No, that's wrong … that only works if both ropes are vertical.
As jaseh86 says, you must treat the horizontal and vertical components separately.
The vertical ones will add to mg, and the horizontal ones to … ? :smile:
Horizontal adds to Zero!
Well, then i have
ATsin52 + BTsin40 = mg, and also
ATcos52 + BTcos40 = 0 ?
Well, then i have
Yes! :smile:
So i was wondering, why does the problem give the length of the ropes? and how does the high difference of the cieling affects the problem?
hmm … it's a weird question, because you suspend things under a ceiling, not over it. :confused:
Are you sure you have given us the full correct question?
Sorry, Over a ceiling, but the ropes are fastened at different heights.
Then I've no idea why they give you that information. :redface:
so the different hieghts of the ceiling does not matter to the problem?
No!
K, THANK YOU!:smile:
11K
  • · Replies 39 ·
