Thread Closed
urgent help with c++ program for series
Share Thread Thread Tools
Mar25-06, 03:40 PM   #1
i wanna form program 2 sum this
pie=4[1-1/3 +1/5 -1/7+..... 1/n]
int n,z,i;
float x,y,pie;
cin>>n;
i=0;
while (i<=n)
y=1/((2*i)+1);
i=i+2;
for(z=1;z<=n;z=z+2)
x=1/((2*z)+1);
pie=4*(y-x);
cout<<pie;
cant understand wat to do...this is wat i did but its giving 0
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Mar25-06, 03:53 PM   #2
Quote by Isma
y=1/((2*i)+1);
x=1/((2*z)+1);
I don't know much about programming, but shouldn't the two lines above be:
Code:
 y = y + 1/((2*i)+1);
x = x + 1/((2*z)+1);
otherwise, you won't get the sum of the terms, and so y = x, and so you get pie to be 0.
Mar25-06, 03:59 PM   #3
so will i initialize x nd y first?
Mar25-06, 08:25 PM   #4
Yeah, initialize them to zero and make finchie's changes, and it should do what you describe.
Mar26-06, 03:48 AM   #5
#include <iostream.h>
void main()
int n,z,i;
float x,y,pie;
cin>>n;
i=0;
y=0;
while (i<=n)
y=y+1/((2*i)+1);
i=i+2;
x=0;
for(z=1;z<=n;z=z+2)
x=x+1/((2*z)+1);
pie=4*(y-x);
cout<<pie;
it still wont work
Mar26-06, 08:39 AM   #6
Recognitions:
Retired Staff Staff Emeritus
1) You can write the program using 1 for loop. You don't need to separate the task of getting the negative part and the positive parts of the series.
2) You have typecasting issues. While doing your calculations you need to promote your ints to floats.
This is pretty much as tight as you can get it:
Code:
#include <iostream>
using namespace std ;
int main( void ) {
  int n; double pi=0 ;
  cin >> n ;
  for( int i=1, j=0 ; i<n+1; i+=2, j+=1 ) {
    j%2 ? pi-=1.0/i : pi+=1.0/i ;
  cout << 4*pi << endl ;
  return 0 ;
If you don't understand something in the above code, don't hesitate to ask.
Mar26-06, 08:46 AM   #7
Recognitions:
Gold Membership Gold Member
You are having problems with 'int' to 'float' conversions.
These lines are the problem:
y=y+1/((2*i)+1);
x=x+1/((2*z)+1);
y is a float, but i and z are integers. Because they are integers, the whole section 1/((2*i)+1) is treated like an integer, and equal to 0 for any value of i larger than 0.
There are a few ways to get around this. Either create a dummy float 'foo' and then do
foo = i;
y=y+1/((2*foo)+1);
or more cleanly look up what the static_cast command does and change the lines to
y=y+(1/((2*static_cast<float>(i))+1));
EDIT: looks like dduardo beat me to it.
Mar26-06, 08:49 AM   #8
thanks a lot...i do get it now nd i ll try to form less loops now
thanx a lot for the tip
EDIT: plz can u tell wat this statement means
nd y are we doing it?
Mar26-06, 09:02 AM   #9
Recognitions:
is just a shorthand for:
Code:
if(j%2){
  pi-=1.0/i ;
} else {
  pi+=1.0/i ;
The % operator is called the modulus operator. It gives you the remainder. In this case j%2 gives you the remainder of j divided by 2. If the reminder is 0, then you know the number is even, else it is odd.
Also this:
1.0/i
is identical to this:
1/(double)i
This basically promotes the integer to double
Aug10-08, 08:39 PM   #10
Quote by dduardo View Post
Code:
#include <iostream>
int main( void ) {
  cin >> n ;
  return 0 ;
Hi i am new user of c++ language and i didnt get how this loop is working.
Aug10-08, 09:40 PM   #11
Recognitions:
Homework Helper Homework Help
Quote by charu View Post
The for statement is split into three parts with ";"
The first part is only executed once before the start of the loop, this creates variables i and j and sets them to 0.
The second part "i<n+1" is tested each time through the loop, the loop exits when this is false, so in this case when i is greater or equal to n
The third part is executed each time through the loop, it increments i and j for each iteration
Aug13-08, 02:35 AM   #12
# include <iostream>
using namespace std;
int main(){
int num;
cout <<"enter the desired num";
cin >>num ;
cout <<"*"<<endl;
for (int j=1;j<=num;j++)
for (int i =1;i <=j;i++)
if (i%2==0)
cout <<" ";
else
cout <<i<<"*"<<" ";
cout<<endl;
return 0;
this is the program and giving the result :
1*
1*3*
1*3* 5*
But the desired result is :
1*
1*3*
1*3*
1*3*7*
1*3*7*11*
PLease help in getting desired result.
Aug13-08, 03:04 AM   #13
Recognitions:
You mean to say you want to produce a series of integers which increments by 2,4,4 then after that it how does it increment? 2,4,4,6,6,6,8,8,8,8...?
1*3*
1*3*
There is a repeated line here, is that intentional?
Aug13-08, 07:13 AM   #14
Quote by Defennder View Post
no i want series should be produce in 2,4,4,4,4,4,4,4, increment...............
and result should be,,,,,,,,,,,1,3,7,11,15and so on,,,,,,,,,,,,,
Aug13-08, 07:14 AM   #15
plz reply me soon.................
Aug14-08, 12:40 AM   #16
Recognitions:
Well then that isn't too hard. You need an encompassing for loop for loop to print out all the sequences and within it, you need a cout statement to print out the initial +2 increment and then another for loop to print out the rest, incrementing the variable by +4 each time.
Sep3-08, 11:15 PM   #17
Hi tomorrow i have a test and i need your help........
please helo me in calling a two dimensional array
I want two store two values that is height and weight of 10 person in the system by using array array and using switch.As this is a long ques i need help only in this,Please reply me with correct program as soon as possible.
void Array ( int height[],int weight[],int size){
for (int i =0;i<10;i++)
cout <<"enter the height";
cin >> height [i];
cout <<"enter the weight";
cin>>weight[i];
double abc(int choice)
switch (choice)
case 1:
Array(int height[],int weight[],10);
int main(){
int choice;
cin>>choice;
cout <<abc(choice);
cout <<endl;
return 0;
Thread Closed
Thread Tools
Similar Threads for: urgent help with c++ program for series
Thread Forum Replies
running a Fortran 77 program in a C++ enviorment/program Programming & Comp Sci 2
forces problem(urgent urgent help needed) Introductory Physics Homework 3
URGENT - Please help - easy series Calculus & Beyond Homework 6
Quantum Mechanics Homework Help(Urgent Urgent Urgent)! Advanced Physics Homework 3
Astro simulation program problem - program bugs? Astrophysics 4
