| Thread Closed |
A projectile problem (Olympiad) |
Share Thread | Thread Tools |
| Sep21-08, 03:55 AM | #1 |
A rock is launched vertically. During the last second of the flight, the rock covers one-half of the entire distance covered during the flight. What is the maximum possible duration of the flight? (Hint: answer is not 2 seconds.)
I've tried to use integration to solve an equation of motion which includes air resistance but failed. Anyone can help me? |
| Sep21-08, 04:44 AM | #2 |
![]() i] ignore air resistance (this is a standard uniform-acceleration problem) ii] you have noticed the question doesn't say the rock returns? ![]() ii] show us what you've tried, and where you're stuck, and then we'll know how to help.
| Sep21-08, 06:27 AM | #3 |
Thank you.
Well, you're right. Since the conditions aren't clearly stated, factors like air-resistance can be ignored so as to simplify the problem. And indeed, the rock would not necessarily return. But I am not sure where the rock would be if i doesn't fall back. If it follows a simple projectile trajectory (in which it falls back to the ground) without resistance and assuming constant acceleration, the answer would be 2 seconds, which isn't the desired answer. Then I considered air drag and formed and solved the differential equation m*dv/dt=mg-Dv^2, which gave me very complicated results. I knew it wasn't the right way then. If the rock doesn't fall back, where would it go? |
| Sep21-08, 06:38 AM | #4 |
A projectile problem (Olympiad)"flight" doesn't include landing …
| Thread Closed |
| Thread Tools | |
Similar Threads for: A projectile problem (Olympiad)
| Thread | Forum | Replies | ||
| numeral value of this Sin(1)*Sin(2)*Sin(3)*...*Sin(89) | General Math | 16 | ||
| Physics olympiad | Academic Guidance | 2 | ||
| Astronomy Olympiad | General Astronomy | 6 | ||
| Math olympiad problem | General Math | 3 | ||
| Maths Olympiad Problem | General Math | 16 | ||
