Can Abstract Math Prove a 15-Pair Relation Non-Transitive?
  • Context: Undergrad
  • Thread starter Thread starter H2Pendragon
    Abstract Abstract math
The discussion revolves around proving that a relation R on a set A with 15 ordered pairs is not transitive. Participants are also addressing a second problem related to injective functions and set differences, seeking clarity in wording proofs.
  • Homework-related
  • One participant expresses difficulty in proving that a relation R on the set {1,2,3,4} with 15 ordered pairs is not transitive.
  • Another suggests that since there are 16 possible ordered pairs, omitting one pair implies the existence of pairs that could lead to a violation of transitivity.
  • Several participants propose examples with smaller sets, such as {1,2} and {1,2,3}, to illustrate the concept of non-transitivity.
  • One participant questions how to articulate the reasoning behind the non-transitive nature of the relation when a specific pair is omitted.
  • Another participant discusses the implications of removing a pair and how it affects the transitive property, suggesting that the reasoning applies to any three elements.
  • There is a mention of the challenges posed by the textbook being used, with one participant expressing suspicion that it may lack important information.
  • A later reply confirms a participant's proposed wording for the proof, indicating it is satisfactory.
Participants generally agree on the approach to demonstrate non-transitivity through examples and reasoning, but there is no consensus on the clarity of the wording for the proofs or the completeness of the textbook information.
Some participants express uncertainty regarding the implications of omitting a pair and how it affects the transitive property. There are also concerns about the adequacy of the textbook used for reference.
Students working on homework related to relations in set theory, particularly those studying properties like transitivity and injective functions.
H2Pendragon
Man I've become desperate. I just signed up needing help on this homework. Can anyone help me with these two problems?
Let A be the set {1,2,3,4}. Prove that a relation R on A with 15 ordered pairs is not transitive.
I've got no clue on that one.
And this second one, which I know the proof, but I need some help wording it correctly:
If f is injective (one-to-one) and C subset D are any subsets of A, then f(D-C) = f(D) - f(C).
I know the proof, but every time I try and word it, it just sounds wrong.
Since there are 16 possible ordered pairs, if 15 are in the relation only 1 is omited. Show that there exist a pair of pairs that implicate the omited pair.
hint can you do
Let A be the set {1,2,3}. Prove that a relation R on A with 8 ordered pairs is not transitive.
or
Let A be the set {1,2}. Prove that a relation R on A with 3 ordered pairs is not transitive.
Since the function is injective you can work with f(x) instead of x.
if f(x) is in f(D-C) what can we say about x.
if f(x) is in f(D)-f(C) what can we say about x.
What about {(1,1), (1,2), (2,2)}?
EDIT: Sorry, I'm just being nit-picky. The general case and idea is sound. It works for 3 elements and above.
My mistake darn combinatorics.
hint can you do
or
See I really have no idea on this. I know I'm only omitting one but I have no idea why that would cause a problem. The book we're using is pretty bad and I suspect it's not telling me something important.
{(1,1) (1,2) (1,3) (1,4) (2,1) (2,2) (2,3) (2,4) (3,1) (3,2) (3,3) (3,4) (4,1) (4,2) (4,3) (4,4)}
If you pick one ordered pair and remove it from that relation you have listed, can you find an example of ordered pairs such that (a,b) and (b,c) is in the relation but (a,c) isn't? I.e. the relation isn't transitive.
At first pick an actual pair. You should then see that the case is the same whichever pair you remove, which answers your question.
Ok, I see the problem at least. I couldn't visualize with symmetric originally. But if you have (4,3) and (3,4) but not (4,4) you aren't transitive. Well at least that group isn't, but it's supposed to be for any a,b,c right?
Now the problem is... how do I put that in words?
If you remove (a,b) then since you have four elements you can pick an element c which isn't equal to a or b. Try going from there.
This is the condition which doesn't hold with only two elements.
So does this seem sufficient?:
A relation R on A has 16 possible ordered pairs. Let R be a relation on A with 15 ordered pairs excluding aRc. Since all the other remaining pairs are in R, then aRb and bRc. However, since a does not relate to c, R is not transitive.
Yes, that is perfectly good.
By the way, this should have been posted in the "homework and coursework" section.
  • · Replies 35 ·
  • · Replies 25 ·
  • · Replies 66 ·
