New Reply
Effort to get us all on the same page (balloon analogy)
Share Thread Thread Tools
Nov28-08, 08:48 PM   #52
Recognitions:
Gold Membership Gold Member
Here's an outstanding set of 77 slides. They are for Ned Wright's 28 October 2008 UCLA Faculty Research Lecture, an annual event. It's a great introduction to cosmology.
http://www.astro.ucla.edu/~wright/CM...Oct08clean.pdf
Also not to be missed, Smoot's 20-minute TED talk given May 2008
http://video.ted.com/talks/podcast/G..._2008P_480.mp4
Smoot's talk was illustrated by some remarkable animations of early universe structure formation, by Kravtsov
http://cosmicweb.uchicago.edu/filaments.html
http://cosmicweb.uchicago.edu/group.html
thx to Orion for pointing out Smoot's talk.
Dec8-08, 09:02 PM   #53
Recognitions:
A famous Einstein quote about an important feature of General Relativity known as general covariance.
“Dadurch verlieren Zeit & Raum den letzter Rest von physikalischer Realität."
“Thereby time and space lose the last vestige of physical reality”.
source links here:
http://www.physicsforums.com/archive.../t-166997.html
also see page 43 of
http://www.tc.umn.edu/~janss011/pdf%...Besso-memo.pdf
==quote==
In a letter to Schlick, he again wrote about general covariance that
“thereby time and space lose the last vestige of physical reality” (“Dadurch verlieren Zeit & Raum den letzter Rest von physikalischer Realität.” Einstein to Moritz Schlick, 14 December 1915 [CPAE 8, Doc. 165]).
==endquote==
Dec9-08, 03:02 AM   #54
Recognitions:
Quote by TalonD View Post
not sure if this question belongs in this thread but.... the expansion is just a pattern of increasing distance between us and distant galaxies, so there is no space/time substance that is stretching right? so in GR gravitation, what is it that is curved?
Spacetime (4D) is curved. However, there are usually "special" ways to split spacetime into "space" (3D) and "time" (1D). These are "special" splits because they don't simply pick an arbitrary coordinate as "time", but among other things they also ensure that the "time" direction at every "spatial location" points to the future and is the potential worldline of an observer. If you do this split in empty flat spacetime, two observers at "rest" in "space" don't find that the distance between them increases with "time". But when you do it in the matter-containing curved spacetime used to model our universe, two observers at "rest" in "space" do find that the "spatial distance" between them increases with "time". (Actually, you can do split flat spacetime so that "space" expands with "time", but then observers have to be massless and energyless, so that's not realistic. But it shows that one should remember that the description of curved 4D spacetime as expanding or being a pattern of distances that increases with time depends on a choice of 3+1D split that is permissible and convenient, but not unique.)
Also, curvature is the distance between objects at different locations. If we use a piece of string and a protractor to measure distances between objects on a football, we will find the pythagorean theorem doesn't hold, so the football is curved. If we replace the football with spacetime, the piece of string with a ray of light, spatial distance with spacetime interval, and objects with events, we can find out if spacetime is curved.
Dec9-08, 09:00 AM   #55
Quote by marcus View Post
source links here:
also see page 43 of
==quote==
==endquote==
Quote by atyy View Post
Marcus, on the other hand... cogito ergo sum --Descartes
Atyy, as a non physisist layman, I find that kind of hard to follow, can you restate that in a simpler easier to understand way? I understand the football analogy but the previous paragraph was a little confusing.
Dec9-08, 10:09 AM   #56
I was just thinking that it is interesting that the baloon or flat rubber sheet analogy when used to explain gravity to the lay public would lead one to an obvious common sense conclusion that pressure has an effect on gravity. Yet without the analogy, for a physisist using mathmatics it might seem unexpected. I realise the analogy is not reality and that it's the math that counts (excuse the pun) but still, I thought that was interesting.
:P
Dec9-08, 12:51 PM   #57
Recognitions:
On the football (the spherical sort), if two observers start out at the north pole and follow straight lines of longitude, they find that the latitudinal distance between them increases, so their universe is "expanding". After they pass the equator, their universe starts to "contract".
Dec9-08, 01:52 PM   #58
ok, I'm going to expose some of my ignorance in this question but here goes...
Thanks for the clarification. I still have some confusion though, maybe because I am trying to take the analogy too far. on a globe if you move along the lines of longitude it depends on whether you are moving toward or away from the equator as to whether you converge or diverge. So if our universe has a positve curvature rather than being flat. then would two objects traveling in paralel eventually converge no matter what direction they are traveling, but in an open universe they would eventually diverge right? The only problem I have with that concept is that it is easy enough to draw two paralel lines on a globe and make them stay paralel all the way around. but presumably in a univere with positive curvature you couldnt keep them paralel right? So since we know that on a large scale everything in our universe is diverging does that mean we are headed towards some kind of cosmic equator and when we pass it, everything will start to converge towards a big crunch? Could the question of continued expansion vs. a big cruch have to do with the ovearall geometry of the universe in adition to the critical density? well of course the geometry of the universe is dependent on the density so I guess that answers my own question.
Then there is gravity. I can understand that two objects traveling near each other in space would follow the curvature and converge. but why do to objects that are initially at rest relative to each other spontaneously start moving together?
Dec9-08, 02:57 PM   #59
Recognitions:
Yes, you've answered your question. But let me comment on not taking the analogy too far. On the spherical football, it is 2D spacetime which is curved. However, it does not make sense to say that each spatial slice has intrinsic curvature, because the spatial slices are 1D lines of latitude. In contrast, for the universe, each spatial slice is 3D, for which it does make sense to ask if it has intrinsic curvature. So one should distinguish between the curvature of 4D spacetime, and the curvature of 3D spatial slices.
The objects themselves produce spacetime curvature. It is not possible to be at rest in time, so it is not possible to be at rest in spacetime, so the objects move together.
Dec12-08, 05:27 AM   #60
First of all, sincere apologies to everyone who feels offended by my post. But couldn't help posting, I had to!
I have come across the information that what we see(visible matter ) is just 4% of the mass of the universe. Rest is some DARK matter and energy.
I have a doubt. We have studied that light comes in the packets(quanta) and so does other forms of energy. Could it be possible that its like a sprinkler, which constantly changes its direction and comes to same direction after some time, hence causing temporary lack of water(or light, for that reason). So, matter is always there, only we can't see it due to lack of continuous radiation. Could it be logical by any means?
Just a point i want to make. Hope I haven't offended anyone. :)
Dec19-08, 06:19 PM   #61
Recognitions:
Navneet, you might enjoy this 20-minute talk by Nobelist George Smoot. Links here:
http://physicsforums.com/showthread.php?t=274265
This mp4 version is slow to download but higher resolution, I think.
You click on it and go away and do something else for 5 or 10 minutes and then come back and start it.
Thanks also for these! The Kravtsov computer simulations are excellent. I like this especially:
I see that Smoot used Kravtsov's movies in his TED talk.
This was a good one too:
I watched the halfsize MP4 version of the movie because it is very easy to download, only about 2.4 MB.
Dec19-08, 11:09 PM   #62
I was just wondering, if the galaxies are like coins on a balloon -- accelerating away from each other -- then how is the Milky Way-Andromeda Galaxy Collision possible?
Dec19-08, 11:19 PM   #63
Recognitions:
Quote by Polter View Post
That's another bad thing about the analogy.
Galaxies come in clusters. Galaxies within the same cluster interact, orbit each other, are bound together by their common gravity.
The balloon can't show this. It is a schematic oversimplified cartoon.
It is only widely separated galaxies---those not bound---that obey Hubble law, and act like the pennies of the model
Dec21-08, 06:04 AM   #64
If it is to be asserted that the Big-Bang was not of "point" origin then how is it justified in terms of -everything- expanding away from other items .. as though it were simply an outward expansion .
IF as positioned earlier the bigbang is not to be seen as a point radiation but as a whole universe instantaneous? radiation then stuff should be flying in all directions equally .. yes or no ?
And just because the claim is that there is no point origin of the big bang .. how can it be asserted logically that this means there is no center point to the universe ?
Maybe it would make more sense as a hypothesis that matter is shrinking lol .. sometimes feels that way mumble mumble .. .. :)
Dec25-08, 06:28 AM   #65
Having ditched the balloon analogy as being too simplistic, I am visualising the mechanism as more like expanding gap-filling foam. This allows me a more realistic three dimensional picture and allows variations in local expansion caused by chaotic quantum anomalies, causing "lumpiness" on whatever scale you like. This model also allows the "bubble" to assume a non-regular shape eventually.
As for the singularity point of origin, this also becomes unecesary and indeed as a result of uneven expansion would not be definable.
I am becoming increasingly drawn to cyclic universe notions in which any debris from one cycle would affect the expansion and "lumpiness" of the next, or each expansion drives through the ghost of its predecessor. This in turn could mean that unexplained cosmological anomalies may not be caused by our present cycle on its own.
I could ramble on at length and dig myself into a hole because this model suggests to me many interesting scenarios. ( including a way to reconcile string and quantum theories) So I wont.
Perhaps Marcus would care to comment?
Merry Christmas to all.
Dec28-08, 03:06 AM   #66
On the balloon analogy and the Cosmic Microwave Background radiation ...
If a particle radiates from location A in the direction of location B, once it leaves location A it is no longer there, although A may remain the particle's apparent location from any number of viewing perspectives over time. What I don't understand in the balloon analogy is where are the "A" locations that are null of radiation? Does the CMB radiation just continuously criss-cross itself? If yes, why is the radiation still uniform? If no, where are CMB radiation source locations in the model?
Kind regards
Dec28-08, 10:57 AM   #67
Recognitions:
Quote by geronimo View Post
Having ditched the balloon analogy as being too simplistic, I am visualising the mechanism as more like expanding gap-filling foam...
No special comment needed, I think. Neither balloon nor foam represent a mechanism.
The balloon image is intended to aid visualizing how distances between stationary points increase. And how they increase at a percentage rate, so that longer distances increase more. Meanwhile (if you recall Ned Wright's animations) wriggles of light slowly travel from one stationary point to another. So this says nothing about how the universe works, it is an key exercise in picturing changing distance relations---in visualizing Hubble law. If foam helps you assimilate Hubble law better than balloon, go with it! Of course neither provide a physical analog to the Friedmann equations, so neither teaches you any understanding of how geometry and matter actually work. Once you can visualize the pattern, if you want to explore the mechanism one way is to experiment with the online calculators which embody the Friedmann equations. I don't know any physical analog (like a balloon or whatnot) but the calculators are fun to play around with.
Quote by Chilli View Post
Kind regards
Chilli, think of it this way: Everybody in the universe is currently receiving CMB radiation which was emitted by matter which is currently at a distance of 46 billion lightyears from them. And that matter has gone thru a lot of changes since it emitted the light that's now arriving.
In line with your example pick spots A and B on the balloon surface.
At a certain time (380,000 y) space is more or less uniformly filled with hot glowing stuff and it is turning transparent for the first time, as it cools below 3000 kelvin.
The balloon is small and A and B are close together (only 42 million ly)
All points including A and B send out light uniformly in all directions. Some of A's light heads towards B, some of B's light heads towards A.
The light doesn't get there right away, or any time soon, because of expansion of distances. The original distance of 42 million ly increases a thousand-fold while the light is traveling. More exactly by a factor of 1090. So today the distance between A and B is 46 billion ly, and this light has traveled 13.7 billion y and is just now arriving.
The balloon is 1090 times bigger now than it was. Some of A's light is arriving at B and some of B's (that didn't go in other directions) is arriving at A.
By now both A and B have matured in the sense that they are no longer hot glowing gas---the gas has condensed into stars and galaxies and some stars have planets and some planets may have life and so on. So each of A and B could have creatures that construct antennas and receive the light----whose wavelengths are now longer by a factor of 1090.
I'm not sure what you have in mind by continuously criss-crossing, but I think yes it does because there is uniform radiation going in all directions at every spot at all times. It is almost perfectly uniform because the whole shebang that emitted it was approximately uniform---all space filled about evenly with hot partly ionized hydrogen etc. all at about the same temperature and all turning transparent at the same time. There is no way that a lot of non-uniformity could arise. Some perhaps, but not a lot.
Remember that in the balloon analogy, all existence is concentrated in the 2D surface of the balloon and there are no directions off the surface. So if radiation starts out uniform it will always remain so.
BTW Chilli is an excellent choice of name---reminds me of a favorite comic gangster movie. Looks like the above was your first post: welcome to the forums!
Dec28-08, 07:03 PM   #68
Marcus, thank you for your explanation and for your kind welcome!
Let’s see if I’m getting any closer … Setting aside post-inflationary expansion (because I really don’t have the math), say I am at location B, and it’s 13.7 billion years o’clock. I am receiving CMB radiation that was emitted in the year 380,000 from a location A that is presently 46 billion lightyears away. Location A was only 42 million lightyears away in the early universe, but a particular wriggle of light didn’t take the whole 46 billion years to reach me at location B because the expansion itself carried (stretched?) A’s particle wave to within 13.4 billion lightyears of B (yes/no?).
With my question about whether the CMB radiation criss-crosses itself, I meant to ask: when individual light waves hit each other, might they cancel or strengthen each other?
Given this thread is to identify things that help or hinder intuition with regard to the balloon analogy, for what it’s worth, here’s some feedback from a clueless newbie.
When you say the balloon is now 1090 times bigger than it was, I reflexively picture the expansion as a slow and steady inflation, analogous to me blowing up a party balloon. And this lets me picture how the ‘coins on the surface of the balloon’ get further away from each other, and also lets me picture the timeline of the balloon, equating small to young, large to old (with us being old). But, assuming the Inflationary Model is correct, the balloon became pretty large when it was still very young, which goes to the uniformity of the CMB in the first place. And this is where the powerful balloon analogy becomes intuitively confusing to me.
For me, picturing all the coins on the surface of the balloon as radiating wriggling cosmic microwaves turns the surface of the balloon into a seething mass of tiny worms. Which might actually work in imagining a uniform distribution, but a spherical balloon also conjures some less helpful tangents.
* Firstly, if a wriggle of light keeps travelling around a sphere, it’s going to end up back where it started. Given the Earth is a sphere, it feels perfectly logical to imagine that the universe is also spherical, and thus a layman like myself automatically connects the balloon analogy with the shape of the universe. Of course, what we really need is a good homespun image to grab onto for the shape of space-time. (Pringles just don’t cut it.) If there was a big bang from a high-pressured source with no particular obstacles to free motion, then intuition says the universe is a big round thing with a definite (if empty) centre. Without an alternative, the balloon analogy is the best ‘big round thing’ image on offer from Cosmology, so, it is destined to be used in—creative—ways.
* Secondly, since the coins themselves stopped emitting their original CMB radiation long ago, then I expect the timeline of a given location A to include periods in which there is no CMB. Ie, the time period after emission and before reception of the first waves of radiation from other sources, and the time period after all radiation waves have passed by. But this idea isn’t compatible with the balloon analogy because the radiation simply circles around the balloon forever.
I greatly appreciate your efforts to try to help beginners such as myself receive the analogy more correctly, Marcus!
New Reply
Thread Tools
Similar Threads for: Effort to get us all on the same page (balloon analogy)
Thread Forum Replies
the balloon analogy (please critique) Cosmology 64
update to the BALLOON ANALOGY web page Cosmology 2
Balloon Analogy Cosmology 1
Charge movement in a magnetic field along the z-axis (into page/out of page) Introductory Physics Homework 16
