Struggling to Focus with New Telescope? Here Are Some Tips!
  • Context: Stargazing
  • Thread starter Thread starter Sheneron
    Telescope
The discussion revolves around the challenges and techniques associated with using a new 8-inch Dobsonian telescope, particularly focusing issues with different eyepieces and the impact of environmental conditions on viewing celestial objects. Participants share their experiences and suggestions for optimizing the telescope's performance and enhancing the observing experience.
  • Experimental/applied
  • One participant notes that the focus point for the 30mm eyepiece is at the maximum retraction, leading to questions about whether this is normal and how to correct it.
  • Another suggests that lack of sufficient focus travel is common and recommends using extension tubes or a diagonal to increase focus distance.
  • Concerns are raised about the clarity of Saturn compared to the Orion Nebula, with some attributing the difference to atmospheric distortion and magnification levels.
  • Participants discuss the importance of allowing the telescope to acclimate to temperature and the effects of light pollution on observing faint objects.
  • Advice is given on collimating the telescope, with one participant sharing their personal experience and preference for using a laser collimator.
  • Suggestions for observing Messier objects and other celestial phenomena are mentioned, with inquiries about specific targets for the current season.
  • Participants share tips on dressing warmly for winter observing sessions and discuss the cleaning of optics, emphasizing that minimal cleaning is generally advisable to avoid damaging coatings.
Participants generally agree on the importance of collimation and acclimation, as well as the challenges posed by environmental factors. However, there are differing opinions on the necessity and frequency of cleaning the optics, as well as the best methods for achieving optimal focus with different eyepieces.
Some participants mention limitations in the guides provided with their telescopes, which may affect their ability to collimate properly. Additionally, the discussion reflects varying personal experiences with temperature and light conditions that may influence observing quality.
Astronomy enthusiasts, particularly those using Dobsonian telescopes, may find this discussion helpful for troubleshooting focusing issues and improving their observing techniques.
Sheneron
Hi,
I have just recently gotten a 8 inch dobsonian telescope. I have two lenses, a 9mm and a 30mm. I really enjoy going out and seeing the sky and I have a few questions to make my outings a little more successful.
The way I focus the telescope is my adjusting how far out/in the eyepiece is. Whenever I have the 30mm eyepiece in, the point where it focuses is when the eyepiece is as far back as it can possibly be and its almost a little shy. Lately I have been not completely putting the lense in the eyepiece holder so that I can better focus it. So is there a reason why the focus point is as far back as possible and is there anyway to correct that? When I use the 9mm it is not like that.
Also, I have been having trouble viewing and focusing some objects. For instance, last night I went out to view Saturn in the eastern sky. I located and began observing, but the object was very blurry and I couldn't hardly make anything out. Exchanging the 30mm for the 9mm only made things worse. The thing is that when I looked at the orion nebula in the top of the sky, it looked so good. Not blurry or anything. So I don't feel justified blaming it on the sky.
I have read that you should leave your telescope outside for an hour to acclimate to the temperature. And I didn't do that, so perhaps that was it. Also I am doing this around lights, but I am not in direct view of the lights so maybe that could be a large effect.
Sorry this is so long. If someone could tell me how to fix my 30mm focus or if that is normal, and maybe just general advice on to how to better optimize my viewing I would appreciate it. Thanks.
Astronomy news on Phys.org
Lack of sufficient focus travel is not uncommon - You can buy extension tubes for that. http://www.telescope.com/control/product/~category_id=optical_aids/~product_id=05123
Or, if you have a diagnoal, that will give you extra focus distance.
Well, what's the difference? With the Orion nebula, you used lower magnification and the nebula was higher in the sky: both decrease atmospheric distortion (or how noticeable it is). Saturn will be much better later iin the winter when you can view it higher in the sky.
It helps, but it is probably not a big factor at the magnifications you are using.
That affects your ability to see contrast and dim objects, but does not affect the resolution.
Congrats on the new scope!
Tell more about it so I can have the proper amount of envy. :-p
You might also try this on the 30mm.
http://www.optcorp.com/product.aspx?pid=9177
A parfocalizing ring will let you match the focus of your 30mm to the 9mm if they are different by at least the thickness of the ring.
I have never bought anything from the seller so I can't recommend.
Another thing you may consider is collimating your scope. I have a 10 inch Newtonian reflector and I collimate it about every 4th viewing session. It helps with planetary and basically overall observation.
I prefer a laser collimator, however that is only personal preference.
Yes, it is a good idea to let your scope (mirror) adjust to the ambient temperature. Some Newtonian’s have a small battery operated fan mounted on the mirror to expedite the temperature balance.
A lot of these ‘little’ things will not show much of an improvement at low magnification but will certainly kick in a higher powers.
Yes, light pollution is certainly detrimental, especially in deep sky observation.
Have fun with it and enjoy your observations.
See how many Messier objects you can observe, also comets, large asteroids. The skies are full of interesting 'stuff'.
A basic tutorial site on collimating;
http://www.andysshotglass.com/Collimating.html
Congratulations on the scope. Lack of in-focus or out-focus travel is a common problem. You can withdraw the EP from the focuser slightly before clamping it with the set-screw, or buy extension tubes as suggested above. You have a good ratio with the 9mm and 30mm EPs. If you buy a 2x Barlow, that will give you the equivalent of a 4.5mm, 9mm, 15mm, and 30mm.
Thank you for all the advice so far. I am going to go out again tonight to do some more observing. Id really like to see Jupiter tonight but I don't think it will happen given my horizon.
My scope came with a laser collimator and I have been trying to collimate every time before I go out; However, the guide that came with my scope was very incomplete. In fact, the guide was actually for a previous version of the scope which was a fair bit different so that is a little bit frustrating. I am going to try to collimate again using a different guide.
Part of my problem is that it is so cold when I go out that its hard to fiddle around with the scope because my fingers are freezing and I am also in a rush to see what I want to because my body is also cold.
Yeah I have been looking for some messier objects. Any particular suggestions for this time of year? I have been really wanting to see some good galaxies and globular clusters.
Oh a couple other things...
How often do you clean your scope, what parts do you clean, and what with?
Sheneron, if you are going to observe in winter-time you must dress in many layers. My rule of thumb in northern climates is to dress like you are going to spend a day ice-fishing, then add at least another layer because of the relative inactivity involved in peering through a telescope.
As for cleaning, unless your scope somehow gets exposed to lots of dirt and dust, you should just leave it alone. A bit of dust on the primary or secondary mirror is not going to degrade the image, and you can easily damage the coatings of the mirrors with improper cleaning.
Yes, dress warm. When you are observing there is not much actual physical effort, so one can get cold rather quick (been there got the tee shirt).
If you plan being out for some time you can purchase foot and hand warmer pouches. I find they are not the best but better than nothing.
As for cleaning the optics, I totally agree with turbo-1. It is best to leave it alone. A certain amount of dust will not cause an observing problem.
The aluminum coating on the optics in only in the order of 90nm ±10nm thick. It takes very little to damage the surface.
Even the mirrors with SiO2 coating on the aluminum have their tolerable limits.
We have a 18 inch Newtonian at our observatory. It has been in a rural unattended, unheated building now for several years and with the amount of normal usage the dust accumulation has really not affected the quality of observing.
If however it becomes absolutely essential for one reason or another to clean the optics. The best solution is 50% distilled H2O and 50% alcohol using cotton swab material.
The actual cleaning done very, very lightly.
It is amazing how easy it is to mar the surface.
Clear skies
Ron
Alright, I will forget about cleaning the telescope.
I am trying to collimate the scope right now, and I only have a laser collimator. I have been reading online and it seems a lot of people like to use a collimator cap versus a laser. Well I also read I should collimate my collimator, which seemed like a good idea so I did. Here is a picture of how far off the laser is when I rotate it by 90 degrees:
http://img234.imageshack.us/my.php?image=scanhq9.jpg
The markings on the bottom are inch markings, so that is quite small; however, there still is some error there. Will that little bit make a noticible difference in not quite correctly aligning my mirror? Would it be wise to invest in a different collimation device other than a laser?
Unfortunately, I cannot see you jpg for some reason or another.
Yes, I have used collimator caps and I find them great.
I only use the laser primarily because it's fast. Thing is, if the scope is kept in good 'alignment' it only takes a short time to 'fine tuning' when observing. This can be done on only a couple of minutes.
Yes, some people will use nothing but a collimator cap, some like the Cheshire sight tube.
Personally I think it it very good.
Will that little bit make a noticeable difference in not quite correctly aligning my mirror?
This may be an argumentative point, but Yes.
I have found with mine, they can be just ever so slightly off and they will not perform as well as their potential.
As the magnification goes up the performance can drop of almost exponentially.
I apologize if I sound 'sticky or critical ' here, but anyone observing should have the very best views they can get. It keeps the interest and enjoyment up.
LOL, it's like the guitar.
If I play, the instrument has to be in true tune. If it's just a bit off, the same amount of enjoyment and sound is just not there.
Thanks for the advice so far Waveform I appreciate it.
So would you recommend getting a collimation cap or Cheshire sight tube? I would like to have the best collimated scope as possible and if that little uncollimated bit of the laser will make a difference then perhaps it would be better to use a more reliable method. It seems hard to get the laser collimator perfectly collimated, so I think I will look into both of those in order to get the best seeing possible.
I used that guide and spent sometime collimating my scope yesterday. My instruction manual left out the part about adjusting the tilt of the secondary in order to reflect the light into the center of the primary. The manual only told me to get the laser collimator to reflect back onto itself properly by adjusting the tilt of the primary, but it said nothing about centering the primary with the secondary. I mean how could it leave that part out? So I did those steps and I looked at Venus and it was the best I have seen yet, and the difference of having a properly collimated scope made a huge difference with my 9mm, it was great. I am going out again tonight.
Clear skies!
Just a personal preference, I would use the Cheshire sight tube. Easy to use, inexpensive and quite accurate.
Yes absolutely agreed, sometimes instruction manuals leave a lot to be desired.
In fact I think some technical writers don't seem to have a good grasp on communication.
Yes, It seem to be a relatively good price. Similar to the one I have.
The thing with accessories such as this, if and when you ever get the aperture fever and decide to get to a larger scope, theses thing will work.
Adapters such a 'T' rings for cameras, 1.25" to 2.00" eyepiece adapters and such are readily available and not expensive by any means.
Just slightly off topic for a moment. I had the 10" Newtonian out last night. The moon and Orion nebula were awesome. I found the transparency quite good last night before it clouded over. However, it was a dress warm night.
Yup, I did a collimation before I took it out.
Collimation for low power observing can be done adequately with a device like that, but I would suggest collimating with a star for high power observing or at the very least as a double-check of the laser collimation method. Some info:
STAR COLLIMATON
A star test is required as a verification of whatever method you use. That means a star test for collimation. The best site I have found that explains how to star collimate is here. If the collimation method you use proves accurate via a star test, then you should stick with that. One word of caution: a precise star collimation check must be done in the best of seeing conditions. Simply defocusing on a star and evaluating the concentricity of the diffraction rings is good enough to get in the ballpark, but won't tell you if you're gnat's *** on. That requires an in focus star with a steady airy disc and that requires very good seeing. Don't be lulled into a false sense of security by those apparently perfect out of focus diffraction rings. They are not precise enough to get that final tweak for perfection.
WHY BOTHER?
So, really, how important is collimation? In my experience with my XT10, it is critical. With a slower f/6 or f/8 telescope, it is still critical, you just don't have to be as accurate as with the f/4.7 XT10. I can say for certain that 1/30th of a turn on one of the collimation knobs will mean the difference between seeing 4 craterletes in Plato and 9 craterletes. It could make the difference in spying the Enke division in Saturn's rings. More often than not, though, poor seeing will mask any errors that may exist in your collimation. If the seeing is bad, you might not see any craterletes in Plato or even the Cassini division in Saturn's rings no matter how accurately you are collimated. But why miss an opportunity to see such detail because of something you have complete control over?
http://www.tomhole.com/Barlowed%20Laser.htm
Note that they suggest using a barlow with the laser.
Here's more on the star test: http://legault.club.fr/collim.html
It's a good idea to avoid moisture condensation on the optics, which can happen when you bring a telescope indoors after spending time out in the cold. What do people do about this?
My approach (in my limited observing experience) was to cap/cover the telescope and all eyepieces before bringing them back inside. My thinking is that will keep the indoor moist warm air from contacting the optics.
That's about the best thing you can do. Beyond that - don't use a humidifier inside.
Yes, this really tends to be a problem when moving a scope between temps, humidity, and dew points.
Personally I also cap the optics if I have move the scopes. However, I primarily leave the scope out.
I have it well covered and protected.
This is why a lot of people will build small observatories (shed's, small out building and such with sliding roofs). It minimizes moving the telescopes and also the wide swings in temperature.
Even the 80mm refractor, I try to leave it out, much as possible.
However, if circumstances warrant the scope must be brought in, then I agree with russ_watters unless you want to start playing around with 12volt Dew Heaters.
Another technique is to put the scope inside a garbage bag and close the end while outside. The scope is then packed in dry air before you bring it indoors.
Well - depending on where you live and what equipment you use, they may be a requirement. They are for me.
Thanks for the advice, and thanks for telling me about covering the scope to prevent dew; I didn't know that should be done.
Hi again
I am trying to collimate my telescope for tonight, but I am having some problems. I am stuck on the first step... I am using a cheshire eyepiece which I just bought.
The first step reads: Insert eh Collimation eyepiece into the focuser far enough that the bottom edge of the barrel appears slightly larger than the outer edge of the secondary mirror when looking through the site hole.
The problem that I am having is that I can not even see the edge of my secondary mirror. The secondary mirror fills up the entire barrel, and then just a little bit more. What should I do? Is that normal?
Wait, nevermind
Ok, new problem. I can see the edge of the secondary mirror as well as the secondary mirror holder. However, I can't see the bottom edge. What I need to do is adjust that upwards from the perspective of looking through the focuser. I know that turning the screw in the center adjusts is left and right, but how do I adjust it up and down?
Yes, the secondary mirror is not centered with the primary when looking down the OTA. I need to figure out how to adjust the spider vanes so that I can center it. I was hoping to go out tonight, so if anyone know anything you know where to find me. Thanks.
I called the company to make sure I could turn those screws, and yes I can. So I think I am getting it! Can't wait to go out tonight with a perfectly collimated scope. I will also try the star collimation.
  • · Replies 25 ·
  • · Replies 226 ·
18K
  • · Replies 27 ·
  • · Replies 54 ·
9K
  • · Replies 26 ·
