Thread Closed
Symmetric Matrices to Jordan Blocks
Share Thread
Feb12-09, 01:53 PM   #1
I've been working through the Linear Algebra course at MITOCW. Strang doesn't go into the Jordan form much.
When a matrix A is diagonalizable then
[latex]
A= S \Lambda S^{-1}
[/latex]
and the matrix S can be formed from eigenvectors that correspond to the eigenvalues in \Lambda
Question:
how do I form S when A is not diagonalizable?
ie.
[latex]
\left[
\begin{array}{rr}
5&1\\
-1&3\\
\end{array}
\right]
=S \left[
\begin{array}{rr}
4&1\\
0&4\\
\end{array}
\right]
S^{-1}
[/latex]
PhysOrg.com science news on PhysOrg.com
>> Leading 3-D printer firms to merge in $403M deal (Update)
>> LA to give every student an iPad; $30M order
>> CIA faulted for choosing Amazon over IBM on cloud contract
Feb12-09, 03:01 PM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
The fact that A is NOT diagonalizable means that it does NOT have a complete set of eigenvectors. You need to form S from eigenvectors as much as possible and use "generalized" eigenvectors to fill out S.
In your example, the eigenvalue equation is
[tex]\left|\begin{array}{cc} 5-\lambda & 1 \\ -1 & 3-\lambda\end{array}\right|[/tex]
[tex]= \lambda^2- 8\lambda+ 16= (\lambda- 4)^2= 0[/itex]
so 4 is a double eigenvalue (which you knew).
An eigenvector corresponding to eigenvalue 4 must satisfy
[tex]\left[\begin{array}{cc}5 & 1 \\ -1 & 3\end{array}\right]\left[\begin{array}{c}x \\ y\end{array}\right]= \left[\begin{array}{c}4x \\ 4y\end{array}\right][/tex]
and so must satisfy 5x+ y= 4x and -x+ 3y= 4y, both of which reduce to y= -x. Any vector of the form <x, -x>= x<1, -1> is an eigenvector. But that's only one eigenvector which is why we cannot diagonalize this matrix.
Now, every matrix satisfies it own characteristic equation: (A- 4I)^2= 0 which means (A- 4I)^2v= 0 for every vector v. Obviously, if v is an eigenvector with eigenvalue 4, (A- 4I)v= 0 so (A- 4I)(A- 4I)v= (A- 4I)0= 0. But it might also be possible that (A-4I)v is not 0 but (A- 4I)((A-4I)v)= 0. Such a vector is a "generalized" eigenvector In that case, (A-4I)v must be an eigenvector! To find another vector such that (A- 4I)^2v= 0, we must find a vector such that (A-4I)v= <1, -1>. That gives the equation
[tex]\left[\begin{array}{cc}5- 4 & 1 \\ -1 & 3- 5\end{array}\right]\left[\begin{array}{c}x \\ y\end{array}\right]= \left[\begin{array}{cc}1 & 1 \\ -1 & -2\end{array}\right]\left[\begin{array}{c}x \\ y\end{array}\right]= \left[\begin{array}{c}1 \\ -1\end{array}\right][/tex]
which gives the two equations x+ y= 1 and -x- 2y= -1. Adding the two equations, -y= 0 so y= 0. Then x= 1. A "generalized" eigenvector is <1, 0>
Take
[tex]S= \left[\begin{array}{cc} 1 & 1 \\ -1 & 0\end{array}\right][/tex]
taking the eigenvector and "generalized" eigenvector as columns. Then
[tex]S^{-1}= \left[\begin{array}{cc} 0 & -1 \\ 1 & 1\end{array}\right][/tex]
and
[tex]S^{-1}AS= \left[\begin{array}{cc} 0 & -1 \\ 1 & 1\end{array}\right]\left[\begin{array}{cc}5 & 1 \\ -1 & 3\end{array}\right]\left[\begin{array}{cc} 1 & 1 \\ -1 & 0\end{array}\right][/tex]
[tex]= \left[\begin{array}{cc}1 & -3 \\ 4 & 4\end{array}\right]\left[\begin{array}{cc} 1 & 1 \\ -1 & 0\end{array}\right]= \left[\begin{array}{cc} 4 & 1 \\ 0 & 4\end{array}\right][/tex]
If your matrix, A, had [itex]\lambda[/itex] as a triple eigenvalue but only one eigenvector corresponding to that eigenvalue, say, [itex]v_1[/itex], then you would look for a vector [itex]v_2[/itex] such that [itex](A-\lambda I)v_2= v_1[/itex] and a vector [itex]v_3[/itex] such that [itex](A- \lambda I)v_3= v_2[/itex].
By the way, your title "Symmetric Matrices to Jordan Blocks" puzzled me. All symmetric (real) matrices are diagonalizable so the question of Jordan Blocks doesn't arize with them. And, of course, your example is not a symmetric matrix.
Feb12-09, 03:24 PM   #3
Sry meant to write "Similar matrices and Jordan Blocks", thought one thing and wrote another. Is there a way to change the name of the thread?
Thanks for answering my question, it makes sense. I'll have to go look up generalized eigenvectors now and see what they are all about.
Feb13-09, 10:11 PM   #4
Hey! I recognize the matrix [latex]
\left[
\begin{array}{rr}
4&1\\
0&4\\
\end{array}
\right]
[/latex] is a Jordan Block.
Thread Closed
Tags
diagonalizable, eigenvalues, eigenvectors, jodan form, similar matrices
Similar discussions for: Symmetric Matrices to Jordan Blocks
Thread Forum Replies
Symmetric matrices Linear & Abstract Algebra 7
A short one on symmetric matrices Precalculus Mathematics Homework 1
Help on showing matrices are symmetric Introductory Physics Homework 2
Symmetric Tensors and Matrices Differential Geometry 10
theorem about symmetric matrices? Linear & Abstract Algebra 7
