Same gravitational acceleration of unequal masses
The discussion revolves around the concept of gravitational acceleration and how it relates to objects of different masses in a vacuum. Participants explore the implications of Newton's laws of motion and gravitation, questioning how mass affects acceleration and the nature of gravitational attraction.
  • Some participants assert that objects of different masses accelerate equally in a vacuum due to gravity, as described by F=ma.
  • Others argue that the concept of weight versus mass is crucial, emphasizing that gravity gives weight (a force) rather than mass.
  • A participant suggests that while the acceleration of two objects toward each other is influenced by their total mass, the difference in acceleration is negligible and undetectable.
  • Another participant challenges the idea that mass affects gravitational attraction, stating that the gravitational force is constant for all bodies regardless of mass.
  • Some participants express confusion over the relationship between mass and acceleration, questioning why the mass of one object does not affect the acceleration of the other in gravitational equations.
  • There is a discussion about inertial versus non-inertial reference frames, with some suggesting that the perspective from which one analyzes the situation can change the interpretation of acceleration.
  • One participant acknowledges potential errors in their understanding and invites clarification on their interpretation of gravitational effects.
Participants do not reach a consensus on the relationship between mass and gravitational acceleration. Multiple competing views remain, with some asserting that mass does not affect acceleration while others maintain that it plays a significant role in gravitational interactions.
Participants express uncertainty regarding the definitions of mass and weight, the implications of gravitational equations, and the effects of reference frames on the understanding of acceleration. There are unresolved questions about the nature of gravitational attraction and how it is perceived from different perspectives.
steve102
I understand that objects of different masses will accelerate equally in a vacuum. This is because the force of acceleration from gravity is the same regardless of mass.
I also know I can manipulate the F=ma equation to a=f/m, which also shows the above to the true.
Intuitively, though, I have trouble reconciling this with the notion of gravity "causing" the items to have different masses when sitting still.
I was wondering if anyone had a plain-English explanation. Thank you for considering my question.
Masses? It's weights, be careful which you use. Gravity doesn't give anything mass, it gives it weight, which is a force, think about that;
F = ma, as you can clearly see the thing that gravity is GIVING the mass is force.
Incidentally, the reason why acceleration due to gravity is constant for anybody is due to Newton's equation of gravity;
(Mass of Object 1 x Mass of Object 2 x Gravitational Constant) / Distance between them squared.
Or to find the pull of 1 on the other only use the mass of the one pulling.
As you can see, if you take you to be the first object, the centre of the Earth to be the other, now equal this to F = ma, your mass simply cancels out with the mass in Newton's equation.
http://en.wikipedia.org/wiki/Newton's_law_of_universal_gravitationEdit : If your question is really related to how things have mass, see Higgs Boson etc, much more abstract & I don't think anyone could give you a real answer right now
Here's my way of thinking of it - in plain English, with no equations. Objects accelerate toward each other (toward the center of mass), not just one toward the other. In a vacuum, the Earth and a massive "ordinary" object WILL have a higher acceleration toward each other than would the Earth and a less massive "ordinary" object. But that difference in acceleration cannot be detected because the difference in the combined mass of the Earth and the two "ordinary" objects is too small to be detected. The rate of acceleration of any two objects toward each other depends on the TOTAL mass of both objects combined. So if you have a 1kg object combined with the mass of the Earth and then you double the objects mass to 2kg, how much have you increased the total mass (as a percentage)? It's a very very small number. So that's why all objects appear to accelerate at the same rate.
Edit:
Because of what I have learned in this thread, I now know that the above statement is incorrect. It is true that two free falling objects of different mass will have an extremely small and undetectable difference in acceleration. But it is not the great mass of the Earth that prevents us from detecting this difference. In fact, the Earths mass has nothing to do with it. Only the difference in mass of the two objects and their distance to the center of the Earth affect their difference in acceleration, expressed as G(M1-M2)/r2. I guess sometimes you just have to use a little math to see things as they really are. :)
I'm afraid you're wrong, we don't 'appear' to be attracted more or less, we are all attracted exactly the same, regardless of mass.
You work out the gravitational field (using Newton's law's) to be;
Mass of Object * G / r²
Yes, we also attract the sun as well, but that's entirely separate. As I understand it the force due to gravity is constant (at sea level) for all bodies regardless of mass, another way to look at it is as I said;
[tex]\frac{M1 * M2 * G}{r^2}[/tex] = M1 * A (M1 bieng my mass for example)
The M1's cancel, (our) mass does not affect it.
Yes, my interpretation may indeed be wrong. But I don't think it is. And I welcome anyone who can explain to me why it isn't. The OP asked for a plain English explanation and that was what I gave, stating clearly that it was my way of thinking. I admit that it's not complete because I said that the acceleration of two bodies toward each other depends on the total mass of both bodies. That's true, but I left out that it also depends on the distance between them. Anyway, here's the problem I have with your explanation (which is the one I usually hear):
You're saying that I am wrong because of this:
A = M2 * G / r2 where M2 = mass of Earth
(M1 * M2 * G) / r2 = M1 * A where M1 = my body mass
The M1's cancel, my body mass does not affect it.
If that's true then why isn't this true:
A = M1 * G / r2 where M1 = my body mass
(M1 * M2 * G) / r2 = M2 * A where M2 = mass of Earth
The M2's cancel, Earths mass does not affect it.
The "it" here is the acceleration of the Earth towards you, and yes, the Earth's mass doesn't affect that.
I see your point. have to go right now but will think about this and reply later. Thanks for the input.
Your explanation is looking at things from the perspective of a non-inertial reference frame. If you look at things from the perspective of an inertial frame, all objects, regardless of mass, will undergo exactly the same acceleration.
steve102 said:
I understand that objects of different masses will accelerate equally in a vacuum. This is because the force of acceleration from gravity is the same regardless of mass. .
I'm sorry but that's where you're going wrong. The force is greater for larger masses. [itex]F=GMm/r^2[/itex] So, if you increase m (the mass of the object), then the gravitational force on that object increases too.
I think the phrase "force of acceleration" is too confusing and has led you astray. There is force. And there is acceleration. They are different things, measured in different units.
What do you mean by inertial frame?
Ok, I checked Wikipedia and I don't get how my view is non-inertial. But I'll admit that I am having doubts about my view. Is it completely wrong? Or is it a matter of perspective?
Why is it ok to use these equations and say that one object is accelerating toward the other, but it's not ok to say that both objects are accelerating toward each other (toward the center of mass)? It would appear that by setting A = M1 * G / r2 or A = M2 * G / r2 that you are setting your frame of reference to one or the other object and linking A to only one of the masses. Obviously any changes in the mass not linked to A will have no affect. Isn't it just as true to say that both objects are accelerating toward each other according to (M1 * M2 * G) / r2 and that A depends on both M1 and M2?
Think of it this way, I'm floating in space, about 3,000 kilometres from the sun, wearing an astronaut suit so I don't die.
Now, me and the sun attract each other due to gravity thanks to the equation
[tex]\frac{M1 * M2 * G}{r²}[/tex] = Vector Force
I accept this, now I think 'how fast am I moving?' I can work out the force on me, so now I decide to use another law of Newtons - F = ma, since the above equation gives me the force, i can equal it to MA
[tex]\frac{M1 * M2 *G}{r²}[/tex] = M1 a (M1 bieng my mass)
I can then divide through by M1, meaning my mass is redundant, independent of my acceleration.
I think maybe some of you are getting caught up on the fact that it's an attraction from the two, and not just one, and you'd be right, but you can see them as independent from each other, the effect of our attraction on the sun, and the sun's to us, when working out the acceleration of one (towards the other), it's independent of (the one that's your trying to work out the acceleration for's) mass
Ignore this post. Originally I queried a comment which has now been fixed up in edit, so I am also removing what I quoted. We're all on the same page again.[/size]
Yeah ok, didn't really read it my bad, the gravitational pull is greater for objects with larger mass's, yeah. f = ma with a being constant.
Your view is non-inertial because your reference frame is accelerating. Strictly speaking, Newton's laws of motion are not valid in a non-inertial frame. To make them appear to be valid one must add fictitious forces to the mix.
There is nothing wrong per se with working in a non-inertial frame. Suppose you want to explain some phenomenon. Whether you do your derivations from the perspective of an inertial frame or non-inertial frame in a way is irrelevant. Do the math right and both perspectives will yield the same end result. The choice is very relevant if you take into consideration the difficulty of arriving at the end result. Explaining the weather from the perspective of an accelerating and rotating reference frame (i.e., a frame fixed to the rotating Earth) is rather difficult but doable. Explaining the weather from the perspective of an inertial frame (ignoring very tiny effects, a non-rotating frame with origin at the solar system barycenter) is a lot worse than rather difficult. On the other hand, trying to explain the interactions in some remote star system from the perspective of an Earth-fixed frame, while possible, is downright stupid.
What you have done wrong is to think that because the acceleration of an object toward the Earth does depend on the object's mass somehow falsifies the equivalence principle. It doesn't. The equivalence principle now stands as one of the most precisely verified axioms in all of physics. It has been verified to about 1 part in 1013 (see the Physics World article cited below). Three future (in development or proposed) satellite missions, MICROSCOPE (CNES), Galileo Galilei (ASI) and STEP (NASA), intend to increase this accuracy by two, four, and five orders of magnitude respectively.
References:
Relativity at the centenary, Physics World (2005), http://physicsworld.com/cws/article/print/21148
Microscope: Exploring the limits of the equivalence principle, CNES, (2008), http://www.cnes.fr/web/CNES-en/2847-microscope.php
Galileo Galilei, GG project home page, http://eotvos.dm.unipi.it
STEP, STEP project home page, http://einstein.stanford.edu/STEP
Thanks for all the info. It has provided me with a lot to think about.
Yes, I can see now that it is a matter of perspective and that my view would indeed have to be accelerating (unless both objects were the same mass).
No. I do not think that. Equivalence experiments is one of the things I have read quite a lot about. I am especially interested in equivalence experiments involving active and passive gravitational mass. I've only found one (Lloyd B. Kreuzer 1966). See my first PF post: https://www.physicsforums.com/showthread.php?t=305189
Never mind, I found my error. :)
TurtleMeister said:
It just seems unintuitive to have to set my frame of reference to one or the other objects.
Choose a different reference frame and you can get a vastly different view of things. What's so unintuitive about that?
But it is unintuitive, and in my opinion even deceiving, to say that any two objects will fall at the same rate regardless of their mass. ... Now, will both the 1kg object and the 1/4 mass of the Earth object take the same amount of time to hit the surface? I don't think so.
You're comparing apples to oranges.
The equivalence principle is about the gravitational acceleration as observed by an inertial observer. You are talking about relative acceleration. It's well known that the masses of both objects contribute to relative acceleration. For example, this is one reason why Kepler's laws are only approximately correct. (Kepler's laws implicitly assume planets have negligible mass compared to that of the Sun, and that is not a valid assumption given with the precision with which we can measure orbits.)
D_H, since you quoted something that I deleted I will re-post it here so that other readers can see it in it's entirety.
Yes, I can see now that it is a matter of perspective and that my view would indeed have to be accelerating (unless both objects were the same mass). It just seems unintuitive to have to set my frame of reference to one or the other objects. Let's take the following example: An object in Earth free-fall will accelerate at the same rate regardless of it's mass. That is true. The key word being accelerate. But it is unintuitive, and in my opinion even deceiving, to say that any two objects will fall at the same rate regardless of their mass. And here is the reason I think so: Suppose we have an object (lets say 1kg) which is positioned at a certain distance from the Earths surface. We let the object free-fall and measure the time it takes for it to hit the surface (assuming there is no atmosphere). Now suppose we make the mass of the object 1/4 the mass of the Earth, set it at the same distance and let it free-fall. We once again measure the time it takes it to hit the surface. And keep in mind that regardless of what frame of reference we use to make the measurement (disregarding any minute differences due to relativity), the time lapse will not be affected. Now, will both the 1kg object and the 1/4 mass of the Earth object take the same amount of time to hit the surface? I don't think so. But of course you can get around this by saying that by increasing the mass of the object we increased the Earths acceleration toward the object. But I think you can see by this example how it is deceiving, and unintuitive to say the least, to say that any object, regardless of it's mass will fall at the same rate. It may be technically true to say that increasing an objects mass will not change it's acceleration, but it will indeed change the time it takes for it to reach the surface. The only reason this cannot be proven experimentally is that any object we create will be minute compared to the Earths mass. The difference in elapsed time would be undetectable.
The unit of measure used in my thought experiment is time, not acceleration. And it works the same regardless of whether it's in an inertial or non-inertial frame of reference. Why isn't that more intuitive?
D_H, I am not trying to dispute the equivalence principle. And I do not believe that my thought experiment shown above contradicts it. I have realized my error as far as the inertial frame is concerned. However, I still do not think my thought experiment is incorrect. I am willing to change my mind but I haven't been convinced yet. I have learned something from this thread and feel that I understand gravity better than I did before.
As perceived by whom? Let's ignore the Earth's rotation. Suppose we have two observers with infinitely accurate means of assessing acceleration. One is fixed with respect to this non-rotating Earth and the other is fixed with respect to some inertial frame. Both measure the acceleration of an object falling toward their Earth at the same time with their infinitely accurate sensors. The two will measure different accelerations.
Now suppose we use a different test object whose mass is orders of magnitude greater than that of the first test object. Both observers measure the acceleration of this new test object after placing it at exactly the same position with respect to the Earth as the first test object. While the Earth-based observer will measure a different acceleration than measured for the first test object, the inertial observer will see this new object as undergoing exactly the same acceleration as the first test object.
Another way to look at this: Imagine two cars, a blue one and a red one, in a drag race. From the perspective of someone in the grandstands, the blue car's acceleration is amazingly high. From the perspective of the driver of the red car, the blue car's acceleration is fairly small. In fact, the driver of the red car most fervent wish is that the blue car appears to be accelerating backwards.
The objects mass has no affect.
I'm not sure how to comment on this because I don't know what "some inertial frame" is. If this observer who is at "some inertial frame" measures the acceleration relative to himself then what he measures will depend on what his velocity and acceleration is relative to the objects being measured. However, I can use this to illustrate my point where I say that using A = M2 * G / r2 is unintuitive. If your observer at "some inertial frame" and the Earth observer measured the time lapse of the objects free-falls, wouldn't their results be the same - regardless of the frame of reference of the observer at "some inertial frame"? Your post seems bolster my argument!
Ok, I have a 2D gravity simulator. No, this is not a thought experiment. I actually have a 2D gravity simulator program that I will use to illustrate my point. I start out with the Earth and the Moon at a stand-still in space. In other words their velocity and acceleration relative to each other are zero. We as the observers are also at a stand-still. I start the simulation. The Earth and Moon crash into each other. I record the time lapse and note the acceleration of each body. Now I do another simulation, except this time I increase the mass of the moon by a factor of 20. The Moon is now more massive than the Earth (I had to use an extreme change in order to see the effects in real time). I start the simulation. The Earth and Moon crash into each other. The time lapse is much shorter as would be expected. But the acceleration of the Moon does not change (A = M * G / r2). The Earth however did increase acceleration, thus the shorter time lapse. Just as the equation states, the mass of the moon did not affect it's acceleration. But an observer on Earth would not be able to tell whether the moons acceleration increased or his own acceleration increased. However, all observers would be able to compare the time lapse and be in total agreement.
So, if we do a Galileo drop tower experiment using infinitely accurate instruments (in a vacuum), the more massive object will strike the Earth quicker than the less massive object. Not because the acceleration of the object increased, but because the acceleration of the Earth toward the object increased. And that's the reason I say that A = M * G / r2, even though accurate and true, is unintuitive.
Edit:
Just wanted to add that the reason an objects acceleration does not increase when it's mass is increased is because of inertia. Increasing an objects mass also increases it's resistance to change in motion. But by increasing the objects mass we have also increased the gravitational field that it produces. So any other objects nearby will experience an increase of acceleration toward it.
One last time, that equation is strictly valid in an inertial frame only. Your lack of understanding of the concept of an inertial reference frame is what is getting you in trouble.
I'm going to be blunt: You're posts in this thread make you appear to be a crackpot. That is not a good road to go down.
D_H, thank you for being blunt with me. I appreciate it when someone is honest with me about their oppinions. But I would like to say that I am only trying to improve my understanding of gravity. If my notions are lunatic I would like to know why. You say that I do not understand the concept of an inertial reference frame. It would help me a great deal if you, or anyone else, would read over my previous post #21 and explain to me where I am going wrong in reference to inertial frames. Or, if there happens to be anything that is correct about my post then I certainly wouldn't mind hearing that also :). I currently feel like my understanding of gravity has improved since I've been posting in this thread. But now you are bringing more doubts to my mind. Any input from other members would be great also.
TurtleMeister, if you're in a car and you accelerate you feel it. If you accelerate faster you feel it more. Why wouldn't the people on Earth be able to feel the increased acceleration in your experiment of increasing the mass of the moon by a factor of 20?
Because they would be in free-fall toward the moon. Objects in free-fall do not feel the force, even though they are accelerating.
But that's not the point of my argument. I only used the large masses so that I could get an easy real time animation on the simulator. Read my first post in this thread.
This is neither that hard nor that counterintuitive a concept.
It's all about reference frames.Let's work our way up the derivative hierarchy. Suppose we have two reference frames with collinear axes but different origins. The position of some object will have different representations in the two frames because the origins of the two frames are distinct. Next suppose the distance between the origins is changing with respect to time. Now the velocity of some object will have different representations in the two frames because of the two frames are moving with respect to one another. Finally, suppose the distance between the origins is changing non-linearly with respect to time. Now the acceleration of some object will have different representations in the two frames because of the two frames themselves are accelerating with respect to one another.
Next, suppose we know that no net external force act on this object. Now suppose an observer fixed with respect to one of these frames sees the object as moving at a constant velocity. The object is obeying Newton's first law. This might well be an inertial reference frame! If some other object, also known not to be subject to a null net force and not collinear with the observer first object is also observed to move at a constant velocity, the frame is an inertial frame. Newton's second law also applies, as does Newton's law of gravitation.
What about that other frame? That frame is accelerating with respect to the frame now known to be an inertial frame. Objects with no net force acting on them will not move with a constant velocity. F≠ma, and F≠Gm1m2/r2. Newton's laws are not valid in non-inertial frames.
Two objects with non-zero masses m1 and m2 separated by some distance r will accelerate toward one another because of gravity. Sans any other forces acting on the two objects, a reference frame based on either object is, strictly speaking, a non-inertial frame. An observer fixed with respect to an inertial frame will see object 1 accelerate toward object 2 with acceleration a1=Gm2/r2 and will see object 2 accelerate toward object 1 with acceleration a2=Gm1/r2. An observer fixed with respect to object 1 will see object 1 as non-moving and will see object 2 accelerating toward object 1 with acceleration arel=G(m1+m2)/r2. An observer fixed with respect to object 2 will see object 2 as non-moving and will see object 1 accelerating toward object 2 with acceleration arel=G(m1+m2)/r2.
In short, from the perspective of an inertial observer, the gravitational acceleration of some object toward another depends only on the distance between the objects and the mass of the other object. From the perspective of an observer fixed with respect to one of the objects, the gravitational acceleration of the other object depends on the distance between the objects and the mass of both objects.
D_H, thank you for that detailed description of inertial and non-inertial frames.
I understand, and I am in complete agreement. I actually breezed through this part. Something I probably could not have done at the start of this thread.
I had to read this a couple of times but I think it was because you did not name the objects, but rather called them "some object" and "the other object". But I get it, and I am in complete agreement.
I am in total agreement with this also. And very good that you put "both" in italics. :)
The first part of your post is a little difficult for me to follow. Unless there is something there that I should know in addition to what I have quoted, I will assume that I have the correct concept of inertial and non-inertial frames. To verify, I will use an example from my simulator. If I have my simulator programmed to show the Sun and the four inner planets, and I set the frame of reference to the center of mass (which would be inside the Sun), then I would be at an inertial frame. If however, I set my frame of reference to the Earth (all other bodies revolving around the Earth) then I would be at a non-inertial frame.
I noticed that you did not comment on my post# 21. Does this mean there are no inertial reference frame errors?
Addressing your post #21:
Yes you are right. W.r.t an observer on earth, heavier objects will have a higher acceleration and hence fall down faster than the lighter ones. In the vacuum experiments we don't observe this difference in accelerations of the bodies(w.r.t Earth mind you!) because of the vanishingly small value of G and a considerably high value of r. If the difference is really huge(like the second input of the simulation), then the change in acceleration will definitely be felt. Enough of words,
Difference in acceleration of two bodies at a distance , r from the center of Earth is given by
G(M1-M2)/r2
M1 and M2 refers to the masses of two objects. (for instance the moon with its original mass and the moon that suddenly inflated to 20 times its original mass). Note that Earth's mass does not enter the picture.
TurtleMeister said:
D_HIf I have my simulator programmed to show the Sun and the four inner planets, and I set the frame of reference to the center of mass (which would be inside the Sun), then I would be at an inertial frame. If however, I set my frame of reference to the Earth (all other bodies revolving around the Earth) then I would be at a non-inertial frame.
Forget the electronic simulator. You've a much sophisticated biological one. Let's start.
Imagine you're in a room, such that no part of it has any relative motion w.r.t you. You've all the facilities to observe and record the position, velocity, acceleration and whatnot of other objects. Now you observe an object that is sufficiently isolated from other objects. So we come to a conclusion that it is not subjected to any external forces. How does it move? observe properly. If it has a constant velocity- meaning its speed and direction doesn't change w.r.t time- then you classify YOUR room as an inertial frame. Any other frame that has such a uniform motion w.r.t your room also becomes an inertial frame. If the object doesn't exhibit a uniform motion-it might be forming a circle or accelerating linearly- then you classify YOUR room as a non-inertial one. This frame is not favored by Newton's laws.
P.S: The motion of distant stars in a circle around the north-south axis of the Earth makes us realize that Earth is non-inertial.
  • · Replies 51 ·
