Gravitational acceleration in GR
The discussion revolves around the concept of gravitational acceleration in the context of General Relativity (GR) compared to Newtonian mechanics. Participants explore the equations that describe gravitational acceleration in GR and the implications of these equations, particularly near black holes.
  • One participant questions whether the Newtonian equation for gravitational acceleration applies in GR and seeks an equivalent in GR.
  • Another participant states that there is no simple equivalent in GR and mentions the gravitation tensor and metric tensor as key components in determining gravitational effects.
  • A specific equation for gravitational acceleration in GR is presented, but it is clarified that the variable r does not represent a measurable radius near a black hole.
  • There is a discussion about whether the presented formula gives acceleration as measured by local or distant clocks, with a participant asserting it is measured by local clocks of an observer at position r.
  • Concerns are raised about the proper distance calculations in the Schwarzschild solution, with references to different definitions of proper distance and their implications for simultaneity.
  • Another participant provides integrals for calculating Fermi normal distance for both stationary and free-falling observers, indicating a mathematical approach to the discussion.
Participants express differing views on the interpretation of gravitational acceleration in GR, the meaning of the variable r in the equations, and the definitions of proper distance. No consensus is reached on these points.
There are limitations regarding the definitions of terms like "proper distance" and the assumptions underlying the calculations presented. The discussion highlights the complexity of measuring gravitational effects in the context of GR, particularly near black holes.
kvantti
I tried to search everywhere but couldn't find an answer, so here it goes.
In Newtonian mechanics, the gravitational acceleration g at a distance r from the gravitating object is given by
Does this equation apply in general relativity aswel? If not, what is the equivalent in GR, ie. how do you calculate the acceleration due to gravity in GR?
No, not precisely. There is no simple version of that equation in General Relativity. In relativity, there is an equation involving the "Gravitation tensor" which depends upon the metric tensor of the space. From that, you can (theoretically!) find the metric tensor and use that to find the Geodesics in 4-space. All free falling objects move along geodesics with constant "4- speed" which, if you try to force it to a flat 3-space, appears as an acceleration.
There is an equation in GR
[tex]g = - \frac{Gm}{r^2 \sqrt{1 - 2Gm/rc^2}}[/tex]​
However, the r in that equation is not "radius" in the sense of something you could measure with a stationary ruler next to a black hole. In fact you can't measure such a radius, because any ruler that approached the hole would fall to pieces. r is the circumference of an orbiting circle divided by [itex]2 \pi[/itex], which in GR is not the same thing a ruler-measured radius.
Actually proving the formula is no easy thing.
Reference: Woodhouse, N M J (2007), General Relativity, Springer, London, ISBN 978-1-84628-486-1, page 99
And would this formula give the acceleration as measured by a local clock, or a distant clock in flat space-time?
This is the acceleration as measured by the local clocks and rulers of an observer hovering at position r. If such an observer dropped a stone, the observer would measure this (initial) acceleration for the stone.
Note that in the limit Gm/rc^2 is small compared to 1, this acceleration is the same as the Newtonian value.
Thanks!
However the proper distance can be calculated in the Schwarzschild solution for any observer.
The graph below shows the proper distance to the singularity for both a free falling (from infinity) observer and a stationary observer (but note that passed the event horizon there cannot be any stationary observers, but we can still calculate the proper distance passed the event horizon):
[PLAIN]http://img40.imageshack.us/img40/4162/distancestationaryandfr.jpg
[PLAIN]http://img40.imageshack.us/img40/4162/distancestationaryandfr.jpg[/QUOTE]
Note that Pasionflower's notion of "the proper distance" appears to be something that he defined and calculated himself (at least I've never seen him quote a reference deriving it or defining it), and it doesn't appear to agree with, for instance, the Fermi normal distance.
The apparent reason for the disagreement is that the notion of simultaneity for the Fermi normal distance is different than Passionflowers.
On the plus side, the numbers are a lot easier to crunch using Passionflower's definition, it's not a particularly bad approach to measuring distance, it's just not unique. The other big drawback is that it's not computed via a Born-rigid set of observers.
What integral do you use for Fermi normal distance?
My integrals are for 'stationary':
[tex]\int _{{\it ri}}^{{\it ro}}\!{\frac {1}{\sqrt { \left| 1-{\frac {{\it <br /> rs}}{r}} \right| }}}{dr}[/tex]
And free falling (from infinity)
[tex]\int _{{\it ri}}^{{\it ro}}\!\sqrt { \left| 1-{\frac {{\it rs}}{r}}<br /> \right| }{\frac {1}{\sqrt { \left| 1-{\frac {{\it rs}}{{\it r}}}<br /> \right| }}}{dr}[/tex]
which obviously becomes: ro-ri
  • · Replies 35 ·
  • · Replies 90 ·
  • · Replies 18 ·
  • · Replies 40 ·
  • · Replies 16 ·
  • · Replies 37 ·
