Does the movement of protons create a magnetic field?
The discussion centers on whether the movement of protons creates a magnetic field, particularly in the context of protons moving through conductive materials and in particle accelerators like synchrotrons. Participants explore the implications of proton movement on electric and magnetic fields, as well as the principles governing these phenomena.
  • One participant questions whether protons moving through an ionically conductive material would create a magnetic field similar to that of electrons, suggesting uncertainty about the behavior of protons.
  • Another participant asserts that protons circulating in a proton synchrotron produce both electric and magnetic fields, which can be used to determine the number and position of proton bunches.
  • A later reply expresses surprise at the assertion that protons produce fields, indicating a belief that the synchrotron itself generates these fields to circulate protons.
  • Another participant clarifies that a DC magnetic field and focusing magnets are necessary to keep protons in the vacuum chamber, noting that the Lorentz force affects the direction of protons without changing their speed.
  • It is mentioned that there are areas without coils in the synchrotron where beam current can be measured, suggesting a method for sensitive measurement using current comparators.
  • One participant explains the hand rules for determining the direction of the magnetic field produced by moving charged particles, emphasizing the distinction between positive and negative charges.
  • Another participant elaborates on the complexities of measuring fields in counter-rotating beams of protons and antiprotons, mentioning the use of directional couplers to distinguish between the fields produced by the different beams.
Participants express differing views on the role of protons in generating magnetic fields, with some asserting that protons do create fields while others question this assertion. The discussion remains unresolved regarding the specifics of how protons interact with electric and magnetic fields in various contexts.
There are limitations regarding the assumptions made about the behavior of protons in different environments, as well as the dependence on definitions of electric and magnetic fields in particle accelerators. The discussion does not resolve the mathematical or conceptual nuances involved.
Topher925
Stupid question (or maybe stupid asker), but I'm having a hard time finding an answer. Of course the movement of electrons (- charge particle) creates a magnetic field when moving steadily through a conductor but what about protons (+ charge particle)? Let's just imagine you have protons passing through an ionically conductive material, would it create a magnetic field the same as electrons would but opposite poles? My science-sense says no, but I'm often wrong.
Protons circulating in a proton synchrotron produce both an electric field, and a magnetic field. Either or both of these fields can be used to determine the number and position of bunches of protons. Same for antiprotons.
Really? I always thought the synchrotron produced electric and magnetic fields to circulate the protons? Back to the books for me...:rolleyes:
You need a DC magnetic field (dipoles) with focusing magnets (quadrupoles) to keep the protons in the vacuum chamber, and they will coast around and around for hours. The Lorentz force bends the protons' direction, but because the Lorentz force is perpendicular to the protons' velocity, there is no increase or decrease in the protons' speed.
Fields ared used to contain the protons; but there are places where there are no coils and this is where the beam current can be measured using e.g a current comparator (this can be done using SQUIDs meaning the measurement is very sensitive).
You know the hand rules to determine the direction of the magnetic field (vector B) produced by a current?
If you have charged particles moving in a straight line, stick out your thumb like you're hitching a ride, point the thumb in the direction of the charge motion, and the curled fingers point will point in the direction of the circular magnetic field caused by the current. For positive charges use your right hand, and for negative charges use your left hand.
For charged particles moving in a circular path, like a loop or coil, point the curled fingers in the direction of charge motion, and then the thumb will point in the direction of the magnetic field caused by the current. Just as in the first case, for positive charges use your right hand, and for negative charges use your left hand.
mikelepore said:
. For charged particles moving in a circular path, like a loop or coil, point the curled fingers in the direction of charge motion, and then the thumb will point in the direction of the magnetic field caused by the current. Just as in the first case, for positive charges use your right hand, and for negative charges use your left hand.
For simultaneously counter-rotating 900-GeV beams of protons and antiprotons in the Fermilab Tevatron, it is not quite so simple. Directional couplers, which measure BOTH the radial electric field AND the azimuthal magnetic field, can distinguish between simultaneous clockwise and counterclockwise rotating beams. Recall that the Poynting vector P = E x H uniquely determines direction.
  • · Replies 22 ·
  • · Replies 22 ·
