Thread Closed
Equation Evaluation Problem in Mathematica
Share Thread Thread Tools
Jul14-09, 04:00 PM   #1
Hello,
I have the following line in Mathematica:
Code:
Print[Pout = (2^-Q*E^(A/2))/SNR \!\(
\*UnderoverscriptBox[\(\[Sum]\), \(q = 0\), \(Q\)]Binomial[Q, q] \(
\*UnderoverscriptBox[\(\[Sum]\), \(n = 0\), \(Ne + q\)]
FractionBox[
SuperscriptBox[\((\(-1\))\), \(n\)], \(a[n]\)] Re[
\*FractionBox[\(Meq[\(-
\*FractionBox[\(A + \((2*Pi*I*n)\)\), \(2*SNR\)]\)]\),
FractionBox[\(A + \((2*Pi*I*n)\)\), \(2*SNR\)]]]\)\)]
But the problem is that for different values of SNR, the result will be the same all the time. Why is that happening? A, Q, and Ne are all constants.
Thanks in advance
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Jul14-09, 11:16 PM   #2
Recognitions:
Gold Membership Gold Member
What are some examples of what A Q and Ne are so i can try it?
and what is meq?
Jul14-09, 11:22 PM   #3
Quote by Hepth View Post
and what is meq?
Try these expressions:
Code:
A=23
Q=15
Ne=21
Meq[s_]:=1/(1-s)
Regards
Jul15-09, 12:07 AM   #4
Recognitions:
and also, the a[n] function or array?
but before that make sure youre clearing any variables youre reusing.
restarting the kernel does that.
Jul15-09, 12:14 AM   #5
Assume
Code:
a[n]=1
How clear all variables? I have many of them.
Regards
Jul15-09, 10:49 AM   #6
I have the same problem again in the following code:
Code:
gA = 10;
M = 1;
Ne = 1;
If[M >= 1, m = M, m = 0];
For[SNRdB = 0, SNRdB <= 10, SNRdB++,
 SNR = 10^(SNRdB/10);
 Print[F1 = \!\(
\*UnderoverscriptBox[\(\[Sum]\), \(r = m\), \(M\)]\(
\*UnderoverscriptBox[\(\[Sum]\), \(i = 0\), \(M - r\)]\(
\*UnderoverscriptBox[\(\[Sum]\), \(j = 0\), \(r + i\)]\(
\*UnderoverscriptBox[\(\[Sum]\), \(k = 0\), \(j*\((Ne - 1)\)\)]
\*SuperscriptBox[\((\(-1\))\), \(i + j\)]*Binomial[M, r]*
        Binomial[M - r, i]*Binomial[r + i, j]*
\*SuperscriptBox[\(E\),
FractionBox[\(\(-j\)*SNR\), \(gA\)]]*
\*FractionBox[\(SNR\), \(g\)])\), \(k\)]\)\)\)\)]]
 Print[F2 = 1 - \!\(
\*UnderoverscriptBox[\(\[Sum]\), \(r1 = m\), \(M - 1\)]\(
\*UnderoverscriptBox[\(\[Sum]\), \(i1 = 1\), \(M - r1\)]\(
\*UnderoverscriptBox[\(\[Sum]\), \(j1 = 1\), \(r1 + i1\)]\(
\*UnderoverscriptBox[\(\[Sum]\), \(k1 = 0\), \(j1*\((Ne - 1)\)\)]
\*SuperscriptBox[\((\(-1\))\), \(i1 + j1\)]*Binomial[M, r1]*
         Binomial[M - r1, i1]*Binomial[r1 + i1, j1]*
FractionBox[\(\(-j1\)*SNR\), \(gA\)]]*
\*FractionBox[\(SNR\), \(g\)])\), \(k1\)]\)\)\)\)]]
1-1/\[ExponentialE]^(1/10)
1-\[ExponentialE]^-1/10^(9/10)
1-\[ExponentialE]^-1/10^(4/5)
1-\[ExponentialE]^-1/10^(7/10)
1-\[ExponentialE]^-1/10^(3/5)
1-\[ExponentialE]^-1/Sqrt[10]
1-\[ExponentialE]^-1/10^(2/5)
1-\[ExponentialE]^-1/10^(3/10)
1-\[ExponentialE]^-1/10^(1/5)
1-\[ExponentialE]^-1/10^(1/10)
1-1/\[ExponentialE]
Why is the second part constant, even though it is a dependent on SNR?
Regards
Jul15-09, 11:21 AM   #7
Recognitions:
Because of your sums and their indices. To fix this, add:
If[M > 1, m = M, m = 0];
before the second For loop. It changes the greater than equal to to just a greater than. That way the second sum in the second for loop doesn't go from 1 to 0 (1 to M-r1 == M-m==0)
Jul15-09, 11:34 AM   #8
Recognitions:
As for your first question, I DO get something different each time I change SNR.
Jul15-09, 11:42 AM   #9
Really? How is that? Try to put the SNR in a For[] loop, and tell me what will happen. Because I am using a For[] loop actually.
Regarding your previous post, I have doubts that I have something wrong in the mathematical equations. So, I will double check them and see what happen then.
Thank you
Jul15-09, 04:23 PM   #10
Recognitions:
FOR:
Code:
A = 23;
Q = 15;
Ne = 21;
Meq[s_] := 1/(1 - s)
a[n_] = 1;
Print[
   Pout =
          Refine[(1.0) (2^-Q*E^(A/2))/SNR
[tex]
\left.\left.\left.\sum _{q=0}^Q \text{Binomial}[Q,q]\sum _{n=0}^{\text{Ne}+q} \frac{(-1)^n}{a[n]}\text{Re}\left[\frac{\text{Meq}\left[-\frac{A+(2*\text{Pi}*I*n)}{2*\text{SNR}}\right]}{\frac{A+(2*\text{Pi}*I*n)}{2*\text{SNR}}}\right]\right]\right]\right]
[/tex]
The changes I made were adding the Refine to simplify the complex stuff, and multiplying by 1.0 to give me a real value.
I also added the SNR changing in the for loop. Looks like it changes when SNR does. Or did I do something wrong?
EDIT: oops, heres my output:
343.991
424.207
520.658
635.431
770.336
926.63
1104.7
1303.75
1521.56
1754.43
1997.27
Jul15-09, 04:28 PM   #11
Recognitions:
Quote by S_David View Post
Thank you
What I mean is that for your given values, you have a sum over
[tex]
\sum _{\text{r1}=m}^{M-1} \sum _{\text{i1}=1}^{M-\text{r1}} \sum _{\text{j1}=1}^{\text{r1}+\text{i1}} \sum _{\text{k1}=0}^{\text{j1}*(\text{Ne}-1)}
[/tex]
but you have defined :
and M IS 1, so m=M=1;
Then in your sum
[tex]
[/tex]
you have:
r1 from {m to M-1} which is r1 from {1 to (1-1)} or {1 to 0}
then you have i1 from {1 to M-r1} which is {1 to (1-1)} or {1 to 0}
So it doesnt sum anything.
see :
[tex]
M=1;m=1;\sum _{\text{r1}=m}^{M-1} \sum _{\text{i1}=1}^{M-\text{r1}} 1==0
[/tex]
Jul16-09, 02:42 AM   #12
Yes, now the fake code is working. I said fake because I gave you fake parameters, so the values you got are not the expected one, because there are not in the range between 0 and 1 as it must be by definition. When I did a slight change toward the real parameters I got the expected results as following:
Code:
A = 23;
Q = 15;
Ne = 21;
Meq[s_] := 1/(1 - 0.5 s)^4 ;
a[n_] = If[n == 0, 2, 1];
 Print[Pout = Refine[(1.0) (2^-Q*E^(A/2))/SNR \!\(
FractionBox[
FractionBox[\(A + \((2*Pi*I*n)\)\), \(2*SNR\)]]]\)\)]]]
0.142877
0.246246
0.390748
0.564677
0.738295
0.875494
0.956523
0.989842
0.998584
0.999898
0.999997
But when I turn my attention to my real, relatively long code, I faced with the same problem again, although I used the same procedure as you described. I don't know why.
Best Regards
Thread Closed
Thread Tools
Similar Threads for: Equation Evaluation Problem in Mathematica
Thread Forum Replies
Write this Equation using Mathematica Math & Science Software 9
Maple 12 problem: long evaluation General Math 0
Evaluation of Strike and the 3 point problem.... Biology, Chemistry & Other Homework 1
Differential Equation and Mathematica Math & Science Software 4
Mathematica Evaluation Time Math & Science Software 4
