| Thread Closed |
[qm]find the angular opertor given total angular momentum wavefunction |
Share Thread | Thread Tools |
| Sep5-09, 03:44 AM | #1 |
1. The problem statement, all variables and given/known data
consider a system with total angular momentum, l=1 in the state |[tex]\psi[/tex]>=[tex]\frac{1}{\sqrt{2}}|1>-\frac{1}{2}|0>+\frac{1}{2}|-1>[/tex] find |[tex]^{^}L_{\psi}>[/tex] 2. Relevant equations [tex]^{^}L_{z}|\psi>=\hbar m|\psi>[/tex] 3. The attempt at a solution the basis in the wavefunction given are|1> , |0>, |-1> and there are orthogonal. but i'm not sure what the question is really asking. anyone care to shed some light on this question.thanks it shoud be L subsript y not psi. just couldnt read the handwriting |
| Sep5-09, 05:23 AM | #2 |
I cannot interpret what | Ly> might mean. The symbol for an operator is not normally placed inside a ket. Since there is handwriting involved, is it possible that you are asked to find the expectation value < Ly>? That makes more sense.
| Sep5-09, 10:33 AM | #3 |
i've done no work in like four months for summer but am going back soon so can somebody tell me if ive done this correctly please.
say we wanted to find [latex]<L_y=1>[/latex], we would do: [latex]<L_y=1>=\int_{-\infty}^{\infty} \psi^{\star} \cdot 1 \cdot \psi dx=\int_{-1}^{1} \frac{1}{2}+\frac{1}{4}+\frac{1}{4} dx[/latex] where i have used the orthogonality of the kets. and so [latex]<L_y=1>=\int_{-1}^{1} dx = \frac{x^2}{2} |_{x=-1}^{x=1}=0[/latex] well that's definitely wrong. im pretty sure i can't just change the limits from infinity to 1 etc in this case. jeez i need to get some work done in the next couple of weeks to get back up to speed lol. |
| Sep5-09, 11:30 AM | #4 |
I do not understand what you mean by
[tex]\left\langle L_{y} } = 1 \right\rangle [/tex] An expectation value is usually written as [tex]\left\langle \psi | L_{y} | \psi \right\rangle [/tex] an abbreviated form of which is [tex]\left\langle L_{y} \right\rangle [/tex] You have to "sandwich" Ly between the bra and the ket of the wavefunction |ψ> that you have then distribute it among all nine possibilities of bra-kets. |
| Sep5-09, 11:35 AM | #5 |
bleh...it's going to be a long road back.
ok try this: [latex]<\psi^{\star}|L_y|\psi>=\int_{-\infty}^{\infty} \psi^{\star} L_y \psi dx[/latex] when we dot product [latex]\psi^{\star}[/latex] and [latex]\psi[/latex] we get 1 though due to ket orthogonality. what value do I use for [latex]L_y[/latex]? do the limits change due to the allowed values for [latex]L_y[/latex]? thanks for your help. |
| Sep5-09, 01:05 PM | #6 |
| Sep5-09, 04:41 PM | #7 |
Now that makes sense.
| Sep5-09, 06:45 PM | #8 |
[tex]\left(\begin{array}{ccc} 1/\sqrt{2} & -1/2 & 1/2 \end{array}\right) \left(\begin{array}{ccc} ... & ... & ...\\ ... & ... & ...\\ ... & ... & ...\end{array}\right)\left(\begin{array}{c} 1/\sqrt{2}\\ -1/2\\ 1/2 \end{array}\right)[/tex] where the matrix is that of L_y in the 3x3 representation (spin 1). Otherwise, don't know what you meant. |
| Sep6-09, 04:10 AM | #9 |
alright here is my solution, please comment.
[tex]L_{\pm}=L_{x}+iL_{y}[/tex] [tex]L_{\pm}|l,m>=\hbar\sqrt{(l_{\mp}m)(l_{\pm}m+1)}|l,m_{\pm}1>[/tex] [tex]L_{y}=(L_{+}-L{-})/2i[/tex] [tex]L_{y}=<\psi|L_{y}|\psi>=\frac{1}{2i}[<\psi|L_{+}|\psi>-<\psi|L_{-}|\psi>][/tex] [tex]=\frac{1}{2i}[\hbar\sqrt{(l_{\mp}m)(l_{\pm}m+1)}(\frac{1}{\sqrt{2}}[<1|L_{+}|1>-\frac{1}{2}<0|L_{+}|0>+\frac{1}{2}<-1|L_{+}|-1> -\hbar\sqrt{(l_{\mp}m)(l_{\pm}m+1)}(\frac{1}{\sqrt{2}]<1|L_{-}|1>- \frac{1}{2}<0|L_{-}|0>+\frac{1}{2}<-1|L_{-}|-1>]] [/tex] [tex]=\frac{1}{2i}[\frac{1}{\sqrt{2}}<1|2>-\frac{1}{2}<0|1>+\frac{1}{2}<-1|0>][/tex] [tex]-\frac{1}{\sqrt{2}}[<1|0>+\frac{1}{2}<0|-1>-\frac{1}{2}<-1|-2>]=0[/tex] |
| Sep6-09, 04:36 AM | #10 |
| Sep6-09, 05:45 AM | #11 |
Recognitions:
[tex]L_{\pm}|l,m\rangle=\hbar\sqrt{(l\mp m)(l \pm m+1)}|l,m \pm 1\rangle[/tex] Right? Secondly, why are you calculating the expectation value? I thought you said the problem asked you to calculate [itex]L_y\vert\psi\rangle[/tex].... [tex]L_+\vert0\rangle=\hbar\sqrt{(1-0)(1+ 0+1)}|1,0+1\rangle=\sqrt{2}\hbar|1,1\rangle[/tex] while [tex]L_+\vert1\rangle=\hbar\sqrt{(1-1)(1+ 1+1)}|1,1+1\rangle=0[/tex]. You also need to operate on the state [itex]|\psi\rangle[/itex] with [itex]L_y[/itex], before you multiply by [itex]\langle\psi|=\frac{1}{\sqrt{2}}\langle1|-\frac{1}{2}\langle0|+\frac{1}{2}\langle-1|[/itex] and distribute the different inner products. For example, [tex]\left(\langle0|+\langle1|\right)L_{-}\left(|0\rangle+|1\rangle\right)=\langle0|L_{-}|0\rangle+\langle0|L_{-}|1\rangle+\langle1|L_{-}|0\rangle+\langle1|L_{-}|1\rangle\neq\langle0|L_{-}|0\rangle+\langle1|L_{-}|1\rangle[/tex] |
| Sep6-09, 05:53 AM | #12 |
Recognitions:
Second, [itex]L_y[/itex] operates on [itex]\psi(x)[/itex] before you take the product with [itex]\psi^*[/itex], so unless the effect of the operator is to simply multiply by a scalar (say,[itex]\alpha[/itex] ), you can't say that [itex]\oint\psi^*(x)L_y\psi(x)dx=\alpha\oint \psi^*(x)\psi(x)dx[/itex]. |
| Sep6-09, 06:21 AM | #13 |
to answer part 1, the +/- at RHS is not a subscript, the latex formatted it that, it doesn't meant to be. after reading your code, i understand how to format it already. part II, i am calculating the expectation value, not the [itex]L_y\vert\psi\rangle[/itex]. as i read the question wrongly (it was a handwritten one) part III, the operation is distributive.Noted. thanks for the good effort ;) |
| Sep6-09, 11:51 AM | #14 |
thanks a lot. had a look over some notes from last year as well as your reply - helped a lot!
| Thread Closed |
| Thread Tools | |
Similar Threads for: [qm]find the angular opertor given total angular momentum wavefunction
| Thread | Forum | Replies | ||
| total angular momentum | Advanced Physics Homework | 6 | ||
| Find angular velocity using angular momentum | Introductory Physics Homework | 3 | ||
| Total angular momentum Q | Introductory Physics Homework | 1 | ||
| Total Angular Momentum | Introductory Physics Homework | 1 | ||
| eigenvalues of total angular momentum | Quantum Physics | 5 | ||
