What affects the stability of equilibrium in a truss with no thickness?
  • Thread starter Thread starter camino
    Equilibrium
The stability of equilibrium in a truss with no thickness is critically influenced by the position of the center of mass. Specifically, for stable equilibrium, the center of mass must be positioned below the midpoint M of the line segment AC. The potential energy of the truss must be computed as a function of the angle or the lengths AB and BC, demonstrating a minimum at the stable angle of 0 or when AB equals BC. If the center of mass is not between points A and C, the equilibrium becomes unstable, complicating the calculations significantly.
  • Understanding of equilibrium equations in physics
  • Knowledge of potential energy concepts
  • Familiarity with truss structures and their properties
  • Proficiency in applying the cosine rule in geometry
  • Explore the principles of potential energy minimization in mechanical systems
  • Study the effects of center of mass on stability in structural engineering
  • Learn about the mathematical modeling of truss systems
  • Investigate the implications of thickness in truss design and stability
Students in structural engineering, physics enthusiasts, and professionals involved in mechanical design and analysis of truss systems will benefit from this discussion.
camino
http://img121.imageshack.us/img121/9765/equilibrium.jpg
Equation of Equilibrium: Sum of all forces = 0
I'm just wondering how you guys would go about this question. I just need to answer this as a reasoning answer and have an idea of what to say but I'm just looking for your input.
That equation of Equilibrium you gave isn't the only thing you need. The question asks for a
stable equilibrium, so you have to show that the potential energy of the truss has a minimum if you place the truss in a tipped position.
I'd compute the potential energy of the truss as a function of the angle that the truss makes, or maybe as a function of the length AB, and show that there is a minimum if the angle is 0 or AB=BC.
you have to show this for all possible lengths of the truss and distances AC
It appears that the equilibrium is actually unstable if the truss doesn't have any thickness, so the center of mass is in the middle of the line segment AC. (call this point M)
Only if the center of mass of the truss is somewhat below M can the equilibrium be stable. The computation gets really hard if the center of mass isn't between A and C anymore, because this means that M need not be on the same vertical line as B.
If the center of mass is in the middle of the line segment at the point M, this means M will be exactly below B and a minimum of the potential energy of the truss is a maximum of m.
it isn't too hard to find BM as a function of x, if the lengths of AB and BC are l+x and l-x
(the length of the string is 2l). I hope you know the cosine rule.
  • · Replies 18 ·
