Does a Wave Function with l=0 Satisfy L\varphi=0?
The discussion revolves around the properties of a wave function \varphi for a particle in three dimensions, specifically focusing on the total angular momentum quantum number l=0. Participants are tasked with demonstrating that the operator L acting on \varphi results in zero, expressed as L\varphi=0.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the commutation relations involving the angular momentum operators and their implications for the wave function. There are attempts to calculate specific commutators and to express the wave function in terms of eigenstates. Some participants question the clarity and readability of the mathematical expressions presented.
The discussion is ongoing, with various approaches being explored. Some participants have provided calculations of commutators, while others are questioning the steps and reasoning behind the calculations. There is no explicit consensus on the next steps or the validity of the approaches being discussed.
Participants are navigating issues related to the clarity of mathematical notation and the assumptions underlying the problem. There is a focus on ensuring that the expressions used are readable and correctly formatted, which has led to some confusion in the discussion.
noblegas
Consider a particle that moves in three dimensions with wave function [tex]\varphi[/tex] . Use operator methods to show that if [tex]\varphi[/tex] has total angular momentm quantum number l=0 , then [tex]\varphi[/tex] satifies
[tex]L\varphi=0[/tex]
for all three components [tex]L_\alpha[/tex] of the total angular momentum L
[tex][L^2,L_\alpha][/tex]?
[tex]L^2=L_x^2+L_y^2+L_z^2[/tex]?
[tex]L^2=\hbar*l(l+1)[/tex] , l=0,1/2,1,3/2,... ?
[tex]L_z=m\hbar[/tex] , m=-l, -l+1,...,l-1,l. ?
[tex][L^2,L_\alpha]=[L_x^2+L_y^2+L_z^2,L_\alpha]=[L_x^2,L_\alpha]+[L_y^2,L_\alpha]+[L_z^2,L_\alpha][/tex]. [tex][AB,C]=A[B,C]+[A,C]B[/tex]; Therefore,[tex][L_x^2,L_\alpha]+[L_y^2,L_\alpha]+[L_z^2,L_\alpha]=L_x[L_x,L_\alpha]+[L_x,L_\alpha]L_x+L_y[L_y,L_\alpha]+[L_y,L_\alpha]L_y+L_z[L_z,L_\alpha]+[L_z,L_\alpha]L_z[/tex]. Now what?
People having a hard time reading the problem?
Do you not already know [itex][L^2,L_x][/itex], [itex][L^2,L_y][/itex] and [itex][L^2,L_z][/itex]?
If so, just calculate [itex][L^2,L_x]\varphi[/itex], [itex][L^2,L_y]\varphi[/itex] and [itex][L^2,L_z]\varphi[/itex] and use the fact that [itex]L^2\varphi=l(l+1)\varphi=0[/itex] for [itex]l=0[/itex].
I don't understand gabbagabbahey's method. I would (using bra-ket notation) define three states [itex]|\psi_i\rangle = L_i|\phi\rangle[/itex], [itex]i=x,y,z[/itex], and then compute [itex]\sum_{i}\langle\psi_i|\psi_i\rangle[/itex].
Yes I calculated those commutators [tex][L^2,L_x]\varphi=(L_y*i\hbar*L_z)+(i*\hbar*L_z)(L_y)+L_z(i*\hbar*L_y)+(i*\hbar*L_y)L_z,[L^2,L_y]= L_x(i*\hbar*L_z)+(i*\hbar*L_z)L_y+L_z(i*\hbar*L_x)+(i*\hbar*L_x) +(i*\hbar*L_x)L_z, [L^2,L_z]=L_x(i*\hbar*L_y)+(i*\hbar*L_y)(L_x)+L_y(i*\hbar*L_x)+(i*\hbar*L_x)L_y[/tex], The comutators simply expand more and do not simplify . at [tex]l=0, l(l+1)\varphi=0[/tex]
Please look at my latex for the expression [tex][L^2,L_z][/tex] PF is not completely showing the solution to this expression for some reason. Now is it readable
What you've just written is completely unreadable...How do you expect others to be able to help you, if you don't take the time to make sure they can read what you are posting?
Begin by calculating the commutator [itex][L^2,L_x][/itex]...use the "go advanced" and "preview post" buttons to make sure whatever you write is actually readable, before submitting your post.
[tex] [L^2,L_x]\varphi=(L_y*i\hbar*L_z)+(i*\hbar*L_z)(L_y)+L_z(i* \hbar*L_y)+(i*\hbar*L_y)L_z,[L^2,L_y]= L_x(i*\hbar*L_z)+(i*\hbar*L_z)L_y+L_z(i*\hbar*L_x) +(i*\hbar*L_x) +(i*\hbar*L_x)L_z, [L^2,L_z]=L_x(i*\hbar*L_y)+(i*\hbar*L_y)(L_x)+L_y(i*\hbar*L _x)+(i*\hbar*L_x)L_y [/tex] Now is it readable? [tex][L^2,L_z]=L_x(i*\hbar*L_y)+(i*\hbar*L_y)(L_x)+L_y(i*\hbar*L _x)+(i*\hbar*L_x)L_y[/tex]
I still can't make heads or tails of what you've written...When you read a textbook or article, or even someone else's posts here...do they lay things out in a jumbled mess like that?
I will separate my commutators into separate latex code and aligned the commutators vertically. Maybe it should then be easier for you to read:
[tex][L^2,L_x]\varphi=(L_y*i\hbar*L_z)+(i*\hbar*L_z)(L_y)+L_z(i* \hbar*L_y)+(i*\hbar*L_y)L_z[/tex]
[tex][L^2,L_y]\varphi= L_x(i*\hbar*L_z)+(i*\hbar*L_z)L_y+L_z(i*\hbar*L_x) +(i*\hbar*L_x) +(i*\hbar*L_x)L_z[/tex]
[tex][L^2,L_z]\varphi=L_x(i*\hbar*L_y)+(i*\hbar*L_y)(L_x)+L_y(i*\hbar*L _x)+(i*\hbar*L_x)L_y[/tex],
at[tex]l=0, l(l+1)\varphi=0[/tex]
That's a little easier to read (Although I really wish you'd stop using that ugly [itex]*[/itex] symbol for multiplication). Why do you have a [itex]\varphi[/itex] on the LHS of each equation? And, you are missing some negative signs on the RHS...why don't you show me your steps for calculating [itex][L^2,L_x][/itex]?
okay.[tex][L^2,L_x]=[L_x^2+L_y^2+L_z^2,L_x]=[L_x^2,L_x]+[L_y^2,L_x]+[L_z^2,L_z][/tex]
[tex][L_x^2,L_x]+[L_y^2,L_x]+[L_z^2,L_x]=[L_y^2,L_x]+[L_z^2,L_x][/tex]
[tex][L_y^2,L_x]+[L_z^2,L_z]=L_y[L_y,L_x]+[L_y,L_x]L_y+L_z[L_z,L_x]+[L_z,L_x][L_z][/tex]
[tex][L_y,L_x]=i*\hbar*L_z, [L_z,L_x]=i*\hbar*L_y[/tex], therefore
[tex]L_y[L_y,L_x]+[L_y,L_x]L_y+L_z[L_z,L_x]+[L_z,L_x][L_z]=i*L_y(\hbar*L_z),+i*\hbar*L_z*L_y+i*L_z*(\hbar*L_y)+i(\hbar*L_y)*L_z[/tex] .How did you get a negative term? (Sorry, if I don't used the [tex]*[/tex] symbol, latex will read the i's and L's as a subscript rather than a coeffcient
[itex][L_y,L_x]=-[L_x,L_y]=-i\hbar L_z[/itex]:wink:
My calculations showed that [tex][L^2,L_z]=0,[L^2,L_y]=0,[L^2,L_x]=0[/tex], now what?
Now, by definition what is [itex][L^2,L_x]\varphi[/itex]?...compare that to what you've just calculated...
since[tex][L^2,L_x]=0[/tex],then[tex][L^2,L_x]\varphi=0\varphi=0[/tex]?
If I asked you the definition of [itex][A,B]\varphi[/itex], you would say [itex](AB-BA)\varphi[/itex], right?
So, when I say "by definition what is [itex][L^2,L_x]\varphi[/itex]?", you say ____?
yes that's right. [tex][L^2,L_x]=(L^2L_x-L_xL^2)\varphi[/tex], should I let [tex]L_x=(\hbar/i)*d/dx[/tex] and [tex]L=(\hbar/i)*d/dx+(\hbar/i)*d/dy+(\hbar/i)*d/dz[/tex] and let [tex](-\hbar/i)*d/dx+(-\hbar/i)*d/dy+(-\hbar/i)*d/dz[/tex]
No need for all that, by definition you have [itex][L^2,L_x]\varphi=(L^2L_x-L_xL^2)\varphi[/itex], and you also just calculated that this was equal to zero, so
[tex][L^2,L_x]\varphi=(L^2L_x-L_xL^2)\varphi=L^2L_x\varphi-L_xL^2\varphi=0[/tex]
Now, express [itex]\varphi[/itex] as a linear combination of the eigenfunctions [itex]\psi_l[/itex] of [itex]L^2[/itex], and use the fact that [itex]L^2\psi_l=l(l+1)\psi_l=0[/itex] for [itex]l=0[/itex] to show that [itex]L_xL^2\varphi=0[/itex]
I still don't think this works. We now have [itex]L^2L_x\varphi=0[/itex], but how do we go from there to prove that [itex]L_x\varphi=0[/itex]?
[tex]L^2L_x\varphi=0[/tex] why not this expression? Can't I assume [tex]L^2=0[/tex] or [tex]L_x\varphi=0[/tex]
  • · Replies 21 ·
  • · Replies 0 ·
  • · Replies 21 ·
