| Thread Closed |
Global warming question |
Share Thread |
| Oct28-09, 04:41 AM | #1 |
Is there any proof that it is the CO2 levels that cause the temperature increases, and not that increasing global temps by themselves increase CO2 levels? It seems to me that the warmer it gets the more things would grow as long as they had sufficient water, if more things are growing then more things would be dying and decaying, which would release more CO2 into the atmosphere. I have seen a few studies that said that with increases in CO2 levels plants produce more so imo the higher production would lead to more carbon being released when the produce is used or dies, so it looks to me like even the effects of CO2 on plants could be responsible for higher CO2 levels. How wrong am I?
| Oct28-09, 05:29 AM | #2 |
Recognitions:
Moonbear should be taking this one, but...
You are talking about increasing the frequency of a full cycle. Plants convert CO2 to O2 as they live, then decay back into CO2 when they die (over-simplified, of course). So increasing the rate at which they grow will increase the rate they die. This should maintain equilibrium. For the CO2 side of the equation to rise, the dying would need to be greater than the growing. This is what is essentially happening. Not just a reduction in rain-forest canopy, but the carbon that has been taken out of the cycle (fossil fuels) has been reintroduced. Another flaw: If your notion were somehow true anyway, the additional quantity of vegetation would at first create a net decrease of CO2, since there would be a lag between growing and dying. The recordings of CO2 quantities in the air are under debate, but I don't think a fall has been detected. |
| Oct28-09, 03:03 PM | #3 |
Edit: I just realized my thread had been moved to a more appropiate forum, thanks. |
| Oct28-09, 03:14 PM | #4 |
Global warming questionThat's exactly the problem with scary claims, trying to fix non-problems things that can't be fixed. So if you argue that it's better to cut down the rain forests for whatever reason to solve CO2 issues, then you simply have no more rainforests. How would that loss relate to the fraction of a degree change in global temperature. You can see here in what small order of magnitude the rainforest contributes in the dynamic equilibrium of the carbon cycle maybe not a good idea to panick and destroy one of the most precious heritages of earth. |
| Oct28-09, 03:21 PM | #5 |
Recognitions:
| Oct28-09, 07:48 PM | #6 |
Changes in temperature should alter CO2 levels by influencing gas solubility in water, perhaps wind patterns and ocean upwelling, changes in the biosphere, permafrost and ice extent changes, etc. It shouldn't be surprising that the carbon cycle can be perturbed if you change the underlying climatic boundary conditions.
Changes in CO2 levels effect temperature due to radiative transfer. That simple. |
| Oct28-09, 08:19 PM | #7 |
The answer to the first is industrial CO2 emission. This is confirmed by a wealth of evidence and is not in any serious doubt. The answer to the second is that rising CO2 levels do indeed have a major contribution to rising temperatures, by basic physics. There are other factors contributing as well, and the complexity of the Earth's climate system is such that we only know approximately how much temperature rises in response to all these forcing factors; but carbon dioxide does stand out as the largest contributing factor for changes over recent decades. Here is a bit more detail on how we know this. The cause of the current rate of increase in atmospheric carbon Atmospheric carbon dioxide is currently increasing at about 1.7 to 1.8 ppm per year. Each ppm is 2.13 PetaGrams of carbon (a PetaGram is also a GigaTon), and so the increase is about 3.75 Pg/year. The burning of fossil fuels is currently adding about 6.5 Pg/year to the atmosphere. The effect of the carbon cycle is to redistribute the additional carbon, so that about half of what is being added goes into carbon sinks in the ocean and the land. There are several additional lines of evidence the help sort out how carbon is moving through the carbon cycle. As well as direct measures of carbon in the atmosphere and the ocean, two important supplementary measurements are the ratio of 12C and 13C isotopes, and the amount of oxygen in the atmosphere. There has been a marked fall in the ratio 13C/12C. This is because plants and fossil fuels have significantly smaller ratios, due to the preferential take up of the lighter isotope in plants. As carbon from deforestation and fossil fuels mixes into the atmosphere, the ratio falls there as well. Addition of carbon to the atmosphere comes with a removal of oxygen; and different processes remove different amounts of oxygen. Fossil fuel burning removes about 1.4 mol of O2 for each mol of CO2 produced; but respiration from plants removes about 1.1 mol of O2. Also, carbon dioxide is much more soluble in the ocean than oxygen. This means data from oxygen levels in the atmosphere, determined by the ratio N2/O2 can help sort out the sources and sinks of carbon. There has been careful study of these measurements in recent times, as scientists attempt to sort out details of the carbon cycle. There's no real question that rapidly rising atmospheric carbon levels are far and away being driven by industrial CO2 emissions; but there are open questions about where it gets distributed through the carbon cycle. A good reference here is
For your question, the bottom line is this. The amount of carbon being added into the carbon cycle from fossil fuel burning in the present is very large, and much more than the rise in atmospheric carbon. This, by far, is certainly the cause of rising atmospheric carbon levels in the present. The cause of rising temperature Carbon dioxide levels have increased dramatically over the last century and they continue to increase now. It is a straightforward consequence of basic thermodynamics that this leads to an increased greenhouse effect, with a "forcing" of increased energy supplied to the Earth's surface. There are other many other forcings that also play a part in Earth's energy balance, both positive and negative, but in the present epoch carbon dioxide stands out as the largest single forcing at work. There is a thread for explaining more of the background physics on this, with plenty of references, at Estimating the impact of CO2 on global mean temperature. What is uncertain There are, of course, lots of open questions and uncertainties in this whole topic. It's quite definite that CO2 levels in the atmosphere are rising rapidly, and that this is caused by industrial emissions. There are significant open questions about how the extra carbon being added gets redistributed through the carbon cycle; and in particular how much is ending up in the ocean and how much in terrestrial carbon sinks. It's quite definite that increased CO2 levels in the atmosphere give a significant forcing to drive increased temperatures; and indeed the forcing involved is known quite accurately. There are significant open questions about other less well understood forcings that are at work; but it is highly unlikely that there is any unknown forcing of a comparable magnitude to the greenhouse forcing which has escaped everyone's notice. As well as this, there are very significant open questions about the response of the Earth to forcings. The amount of temperature increase for a forcing is a consequence of climate sensitivity, which is known only approximately. Felicitations -- sylas |
| Oct28-09, 08:46 PM | #8 |
| Oct28-09, 09:10 PM | #9 |
If you want to know more here is a good place to start. http://ohioline.osu.edu/aex-fact/pdf/0510.pdf |
| Oct28-09, 09:14 PM | #10 |
I am not arguing that the earth isnt warming I most definitely understand that it is, i'm just wondering how much were to blame if any and trying to see if some other remedy makes more sense to me than taxing CO2(not eliminating it just taxing it). There is so much I dont know I am just trying to reduce that number a little. |
| Oct29-09, 07:53 AM | #11 |
what type of vegetation uses up the most co2?
| Oct29-09, 10:19 AM | #12 |
Fastest growing, most efficient, or long term sequesters. Bamboo is considered to be one of the best absorbers of CO2 since it grows fast and doesn't decay rapidly after it dies. Algae also grows fast, but it decays rapidly. |
| Oct29-09, 05:43 PM | #13 |
| Thread Closed |
Similar discussions for: Global warming question
| Thread | Forum | Replies | ||
| The Question of Global Warming - Freeman Dyson | Social Sciences | 17 | ||
| A Global Warming Question | Earth | 4 | ||
| How can anyone question man's significant role in global warming? | Earth | 86 | ||
| question about global warming | Earth | 6 | ||
