Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image gravity Share It Thread Tools Search this Thread image
Old Nov4-09, 02:05 PM                  #1
millman
millman is Offline:
gravity
my son asked me a question that i can not find an answer too and i hope you can all help me :
could the gravity of a object be directly related to the density and speed of the object as it passes through the higs feild ?
Old Nov4-09, 03:28 PM                  #2
Nickelodeon
Nickelodeon is Offline:
Re: gravity
I would have thought that gravity is directly related to the density of an object.
As for the speed of an object, well some say the faster an object is moving the more energy it has which they then equate to an increase in mass and hence it will exert more gravity. I'm not a great fan of that idea. If the object is accelerating then that might be a different case, but just simply floating along with a uniform speed I can't see it.
Old Nov4-09, 03:43 PM                  #3
TurtleMeister
TurtleMeister is Offline:
Re: gravity
According to everything I've studied, the gravitational force produced by an object is directly proportional to it's mass. But I will admit that I have not studied GR, which may have more to say.
Old Nov4-09, 04:14 PM       Last edited by magpies; Nov4-09 at 05:39 PM..            #4
magpies
magpies is Offline:
Re: gravity
Density<-- Change this to Mass I guess... And imo and probably only mine density/mass is just how much space it displaces.
Old Nov4-09, 04:27 PM                  #5
TurtleMeister
Re: gravity
I think that density is the wrong word to use here. Just changing an objects density will not change the force of it's gravitational field. If I have two objects with the same mass but different densities then they will both still produce the same gravitational force, as long as the distance does not fall below the radius of the larger object.
Old Nov4-09, 05:36 PM                  #6
russ_watters
PF Mentor
russ_watters is Online:
Re: gravity
Right - what density affects is only how close you can get to the [center of] the object. If we're talking about the earth orbiting the sun, the density of the sun is completely irrelevant. Someone asked the question just yesterday: If you replace the sun with a black hole of equal mass, what happen's to earths orbit? Answer: Nothing.
Old Nov4-09, 05:39 PM                  #7
berkeman
PF Mentor
berkeman's Avatar
berkeman is Online:
Re: gravity
Well, except for the part where things get dark and start to get cold about 8 minutes later...
Old Nov4-09, 06:16 PM                  #8
millman
millman is Offline:
Re: gravity
hahahah at least thats one thing we dont have to worry about
the one question that this has raised with my self is , as we currently stand einsteins theories fail at 2 points one being the event horrizon of a black hole the other the big bang.
what if gravity instead of being one of the 4 forces is in fact a result of dense matter passing through the higs feild the denser the matter the greater the affect the greater the mass?
Old Nov4-09, 06:21 PM                  #9
Nabeshin
Nabeshin's Avatar
Nabeshin is Offline:
Recognitions:
PF Contributor PF Contributor
Re: gravity
General relativity actually doesn't fail at the event horizon of a black hole. This is a pretty common misconception. Where GR fails is the singularity of a black hole, and similarly, any proposed singularity at the big bang.
Old Nov4-09, 06:23 PM                  #10
gutti
gutti is Offline:
Re: gravity
Well many people have studied this, physicists and mathematicians and its shown that gravity is directly proportional to the mass, and density of an object doesn't affect it.
Stated in terms of newtons theory of gravitation, which isn't a totally accurate description of whats going on but close enough for this.
Gravitational force exerted depends on the mass of the object attracting, the mass of the object being attracted and the distance between them.
image image
Reply
Thread Tools
Similar Threads for: gravity
Thread Thread Starter Forum Replies Last Post
[help]how to obtain gravity eqution from gravity field Action S? zhushualbert Special & General Relativity 3 Jun22-09 12:59 AM
[help]how to obtain gravity eqution from gravity field Action S? zhushualbert Advanced Physics 2 Jun22-09 12:46 AM
Does gravity affect gravity the way gravity affects time? vebrown General Physics 10 Apr19-09 09:34 AM
Gravity: Point where Earth's Gravity and the Moon's cancel each other out? ND3G Advanced Physics 5 Mar21-09 07:19 AM
gravity on mass on earth's surface vs sun-earth gravity ninjagowoowoo Introductory Physics 2 Apr28-05 12:50 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
