Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image Strain Gage Adhesive Share It Thread Tools Search this Thread image
Old Nov4-09, 06:44 PM                  #1
cs003
cs003 is Offline:
Hi,
Can anyone recommend a good adhesive to glue a strain gage to steel? Ideally it would be something readily available at a hardware store or something like that. The expected strain will be approx. 10%... hopefully less, but possibly slightly more.
Thanks!
Old Nov4-09, 06:54 PM                  #2
FredGarvin
FredGarvin's Avatar
Engineer Guru 2008
FredGarvin is Offline:
Recognitions:
PF Contributor PF Contributor
Re: Strain Gage Adhesive
The only thing that comes close is the very thin cyanocrylate. I would worry that using that would result in debonding at high strains. However, if it has to be something from a hardware store, that's probably your best bet. Your prep work prior to the bonding is also of the utmost importance.
I would highly recommend looking here and purchasing from them:
http://www.vishay.com/accessories/adhesives/
http://www.vishay.com/docs/11011/bondae10.pdf
Old Nov4-09, 07:51 PM                  #3
xxChrisxx
xxChrisxx is Online:
Super glue, a very very thin layer.
That's what i've used in the past, although the strains I have been measuring were quite low.
Obv, its only worth using super glue if you have cheap strain gauges. If you start getting expensive ones, see what the manufacturer reccomends you use.
Old Nov4-09, 08:28 PM                  #4
Phrak
Phrak is Offline:
Recognitions:
10% strain in steel? How is that happening?
image image
Reply
Thread Tools
Similar Threads for: Strain Gage Adhesive
Thread Thread Starter Forum Replies Last Post
Gage Pressure, Absolute Pressure - Gage in Different Environment Problem lizzyb Engineering, Comp Sci, & Technology 3 Sep7-09 10:18 PM
Adhesive jeff1evesque General Physics 5 Aug9-09 10:28 AM
what's the physical meaning of true shear strain and simple shear strain mydogsmall Atomic, Solid State, Comp. Physics 2 Sep26-08 11:42 PM
Gage Pressure vs Pa and P evotunedscc General Physics 2 Sep6-07 07:42 PM
Strain Gage djklocek Materials & Chemical Engineering 3 Nov9-06 12:36 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
