Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Science Education > Academic Guidance
Reply
image Taking Two Math Classes Simultaneously Share It Thread Tools Search this Thread image
Old Nov4-09, 11:49 AM                  #1
erok81
erok81 is Offline:
I am thinking of taking Multivariate Calculus & Differential Eq/Linear Algebra both during summer semester. Doing will save me an entire semester and both have the same Calculus II pre-req.
My questions is: are these two classes okay to take at the same time? Or should one be done before the other? Any other input is appreciated.
I'm not worried about course load or ability to study the materials, I am fine there. I'm just looking how these two classes might relate to each other and how taking two math classes at once is. I've never taken more than one math class at a time, so this concept is new to me.
Old Nov4-09, 12:19 PM                  #2
Monocles
Monocles is Offline:
Recognitions:
PF Contributor PF Contributor
Re: Taking Two Math Classes Simultaneously
It depends on your ability. If you were able to sail through calc 1 and 2 then it will be a walk in the park to take calc 3 and diff eq at the same time (which I'd argue are both easier than either calc 1 or 2). If these classes required a lot of studying on your part then you might have a rough time.
Old Nov4-09, 01:13 PM                  #3
union68
union68 is Offline:
Linear algebra is used in multivariable calculus (dot products, projections, etc.), but not enough to where it should be a prerequisite. You should be fine there. However, this is based off of my experience with Calculus III at my school.
Nothing in multivariable calculus will be used in an ODE class. If it were, it would be a PDE class!
Old Nov4-09, 01:54 PM                  #4
physics girl phd
physics girl phd's Avatar
physics girl phd is Offline:
Recognitions:
When an undergrad, I often took two math classes at the same time in order to get a math minor. Since the prerequisites are covered, you should be fine. It might, however, be harder to do so during a summer term... summer courses tend to move very quickly because of the shorter duration term, even if it is a "full summer" course... and I personally always found it tough to take any summer courses just because of the nice weather!
Old Nov4-09, 02:06 PM                  #5
erok81
erok81 is Offline:
Thanks for the advice everyone, sounds like I should be okay.
Math comes pretty easy to me (pretty much the only thing that does) so I don't need to study too much to succeed.
And physics girl phd, that's the other thing I had on my mind - the shorter semester. I'm only taking those two classes and an english class, so I hope I'll be okay. Thankfully they are all full summer semester classes rather than the shorter ones.
Old Nov4-09, 04:04 PM       Last edited by 206PiruBlood; Nov4-09 at 04:29 PM..            #6
206PiruBlood
206PiruBlood is Offline:
The short quarter might be difficult however it is definitely doable. I took differential equations, multi variable calc, and a physics course all at once. It seems much easier to lose motivation during the summer months though.
As for these courses being easier than calculus one and two, thats debatable. It wasn't that differential equations was particularly difficult, it just took much more time to complete the homework than any of my calculus courses. Obviously the difficulty will range depending on school, instructor, etc. Maybe you should get a syllabus an see how much material will be covered.
Old Nov4-09, 04:40 PM                  #7
Bourbaki1123
Bourbaki1123 is Offline:
Should be cake. I typically take 3-4 math classes per semester. When I took diff eq's I also had Abstract Algebra 2, Discrete Math, and I think some other math course plus some gen ed classes (one was honors English, the other was some garbage time-waster/grade-booster b.s.).
Differential equations really isn't usually that tough. Most of it is remembering techniques, doing linear algebra and reading vector fields. A good number of the techniques are pretty intuitive (though some of the tests for uniqueness of solutions ect. were more straight memorization for me). I do know that a friend of mine who goes to a university a city over had a diff eq's class geared towards engineering students that he claims was a killer.
Old Nov4-09, 05:02 PM                  #8
union68
union68 is Offline:
I have the opposite experience. My school is predominantly an engineering school, so all of our DE classes are geared towards engineering. In other words, the classes are ENTIRELY computational and, I thought, quite easy. Uniqueness and existence? Theory? Nope. Nothing.
Bummer for me.
Old Nov6-09, 12:11 PM                  #9
Bourbaki1123
That sucks, I can't see how you could skip over proving a solution exists and its uniqueness. What if you want to use some techniques in the field but you don't know any tests for finding out if a solution even exists?
Old Nov6-09, 05:10 PM                  #10
rubrix
rubrix is Offline:
depends on your ability. Can you handle doing two math courses at once? If you are a math major (or planning on being one) you'll need to take at least 2 classes at once. That goes for other subjects majors too.
* i'm assuming you are taking Applied Linear Algebra for Engineers. There probably is another Linear Algebra for Mathematics Major and it involves proofs. In that case, you'll need an introductory proof course before that.
Yes it is quite okay to take Calc III + Linear Algebra at once. At the surface, there will be little to no correlation between the two.
As per Calc III + DE...well, at the end of your DE course you might need "Partial Differential" concept (it's easy btw) from Calc III. But by the time you need that....you'll already learn it in Calc III.
Old Nov7-09, 03:56 AM                  #11
Vanadium 50
PF Mentor
Vanadium 50's Avatar
Vanadium 50 is Offline:
I think this varies by school.
When I took Calc I and Calc II it was a walk in the park. Calc III and Differential Equations were among the very hardest classes I ever took. There was no way I would have been able to take them both simultaneously. Not and keep my sanity.
Old Nov7-09, 03:48 PM                  #12
rubrix
rubrix is Offline:
Yeap it does depend in school and the student too!
our instructor who has taught all Calc I, Calc II, and Calc III course says...
student find Calc I the easiest among those three course
they find Calc II the hardest
and Calc III easy
i personally loved Calc I and Calc II but didn't like Calc III. I also enjoyed DE course when most of my peers hated it.
and i didn't like Linear Algebra either. But the Linear Algebra class i took required me to do proofs :-\
I think if i had done Applied Linear Algebra course (the one with lots of problems and no proofs) i would have enjoyed it.
Old Nov8-09, 09:50 AM                  #13
mrb
mrb is Offline:
My concern with the summer classes would not be so much the difficulty, but the question of whether you will retain the knowledge. At my school summer classes last only 5 weeks. Too late I realized that it's not wise to take anything you will need to know later in this format. I took Diff Eq as a summer class; within weeks after the class was over I had pretty much completely forgotten everything.
Old Nov8-09, 06:14 PM                  #14
Nick M
Nick M is Offline:
I took Calculus II and Linear Algebra at the same time.
I got A-'s in both, but it was a lot of work!
I'd rate the math courses I took as follows... (from most to least time consuming)
1. Linear Algebra (w/proofs)
2. Calculus II
3. Differential Equations
4. Multivariate Calculus
5. Calculus I
6. Pre-Calculus
I've heard the engineering-geared combined Diff-EQ/Linear courses aren't bad at all.
I would be concerned about what you actually cover though, as I took the separate courses and we learned new material all the way to the buzzer with many things still untouched in the text (which I've been exploring as time permits).
Old Nov9-09, 11:40 AM                  #15
erok81
erok81 is Offline:
Thankfully my summer semester is 12 weeks as opposed to the normal 16 week fall/spring semesters. If they were only 5 weeks I'd probably be looking at other options. I definately wouldn't want to take those classes over a period of 5 weeks.
Old Nov9-09, 04:19 PM                  #16
mdnazmulh
mdnazmulh is Offline:
I had taken two math courses in last semester- Probability and Complex variable & FT. They were not interrelated that much but it didn't make any problem for me. Actually it depends on the person. If you are confident to take two math courses, do not hesitate. At least do something new to achieve something new! good luck.
image image
Reply
Thread Tools
Similar Threads for: Taking Two Math Classes Simultaneously
Thread Thread Starter Forum Replies Last Post
How important is taking extra math classes to get into physics grad school? xbomber88 Academic Guidance 10 Mar3-09 01:26 AM
Is taking to many classes bad for app. to PHd? Unassuming Academic Guidance 4 Dec25-08 08:24 AM
Worth taking higher level physics classes? djfermion Academic Guidance 3 Oct6-08 11:20 PM
extra math classes for a math minor... Matt1 Academic Guidance 17 Nov18-06 01:28 AM
What classes are you taking/teaching this semester? Sonty General Discussion 21 Aug18-03 01:55 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
