(To clarify my general position, I am not a realist. Not even when it comes to physical law. Physical law, are merely inferred regularities about the universe, that is exploited for the benefit of the observer.)
Originally Posted by MikeyW
What sort of observer are you talking about? In the context of your post that I originally quoted I'd expect you to be talking about observers of different scale. But I don't see the difference between an ant looking at an object and a human, though there is a 10^3 difference in length scale.
The difference I see is that there is a substantial difference between what measurements or questions an observer CAN formulate and execute, and there is also a substantial difference in the amount of information about past interactions a give observer can hold/encode.
The memory size of a any is first of all way smaller than a human. Also the level of intelligence of the ant highly constraints the kind of questions a real ant could possibly and reasonably come up with.
The real difference on these points are apparent only when you study the behaviour/action of the ant vs the human in
relation to a specific system under study.
The behaviour of an ant, illustrates that it is indifferent to things that makes a difference to details to a human. Thus when it comes to understanding behaviour, these intrinsic perspectives are important. To understand how something acts, usually means you need to try to understand the logic of their reasoning, because it's reflected in it's actions.
- How does an light particle respond in a givern environment, as compared to a particle that are orders of magnitued more massive? The idea is that the behaviour of a particle reflects how it sees the world. Mass is like a constraining property that limits what's possible. A light particle is I think unlikely to RELATE to arbtitrarily high energies, and this is expected to make a difference to how it responds.
- How does say an electron view an atom nucleus, as compared to the external laboratory frame? ie. what "laws of physics" does an electro see? well, we sure don't know, but the reflection could be useful since we can still make a good inference, if we assume that the aciton of an electron in a specific sense, follows rationally from it's expectations of it's own environment.
- This ultimately POSSIBLY(I could of course be wrong) suggest that the notion of smallest scale and largest scale, is not universal since the only operational way for two observers to make the comparasion is to again, interact.
The laws of physics we have and call the standard model, and merely the human/earth level view of things. And in particular when it comes to unification programs, and understanding why the actions of matter look the way it does, and how to unify it also with gravity, this "intrinsic information view" is not respected. I think respecting it, would bring further constraints on physical actions, pretty much like say the string theory constrains the set of possible physical actions, but with a substantial difference that there is a very good explanation for it.
So my point in the original commen is that just maybe, a notion corresponding to "planck scale" and cosmological scale with observable universes, exists for EVERY observer. But it's not a priori obvious that it makes sense to say that the minimum scale for two observers are the same - since the only meaningful statement has to be defined in terms of an interaction.
This is why also MAYBE the "exploration of this so called planck scale" can actually be done in a different way - the corresponding minimal scale for a very light system, is likely to be much larger than the minimum scale for a massive earth based laboratory, and thus the ACTIONS of these light systems might reflect this.
So, I am not sure the only way to enlightment is to build more and more expensive accelerators, or to build larger and larger "telecscopes" or space probes, or detectors for cosmic stuff.
The range in between, complex but not cosmic scale systems, in particular when we consider why a systems acts the way it does in a given environment and how it evolves during darwin style process and how the system complexity (I mean specifically like the complexion number) apparently acts like an inertia that secures stability, can yield information that me enlighten use on other areas.
/Fredrik
