Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Engineering > Electrical Engineering
Reply
image Supplying Power To A Mullard Vacuum Tube Share It Thread Tools Search this Thread image
Old Nov11-09, 10:59 AM                  #1
ScienceNerd36
ScienceNerd36 is Offline:
How would a curious young gentleman like myself go about supplying power to a Mullard vacuum tube? I have several different types of Mullard tubes, but no idea as to how I can generate the electron beam.
P.S. If side-effects of solution include death, injury or Hannah Montana please do not post.
Old Nov11-09, 04:38 PM       Last edited by Bob S; Nov11-09 at 05:07 PM.. Reason: added urls            #2
Bob S
Bob S is Offline:
Recognitions:
PF Contributor PF Contributor
Re: Supplying Power To A Mullard Vacuum Tube
I had a pair of Mullard EL-34 pentodes as the final push-pull stage in a big vacuum tube audio amplifier. As I recall, the plates ran so hot that they turned red. See
http://upload.wikimedia.org/wikipedi...llard_el34.jpg
http://en.wikipedia.org/wiki/EL34
Here is a data sheet
http://www.drtube.com/datasheets/el34-philips1969.pdf
Max plate current, voltage is 100 mA, 250 V
http://www.eierc.com/rc/EL34.htm
The difference between the max supply voltage and anode voltage is the cathode bias resistor IR drop from cathode to ground.
Finally found a Mullard datasheet for EL-34:
http://www.hifitubes.nl/weblog/wp-co...llard-el34.pdf
Bob S
image image
Reply
Tags
electron beam, mullard, vacuum tubes
Thread Tools
Similar Threads for: Supplying Power To A Mullard Vacuum Tube
Thread Thread Starter Forum Replies Last Post
power in dc circuits...supplying or consuming? spazzy32 Electrical Engineering 1 Feb18-09 04:55 AM
Vacuum Tube Moonballs General Physics 10 Jan15-09 09:39 PM
valve (vacuum tube) help please Dezz101 Electrical Engineering 3 May11-08 10:57 AM
Modelling a vacuum tube? the.bone Engineering Systems & Design 13 Jan1-08 02:29 PM
looking for a vacuum tube Tweek General Physics 6 Jan1-04 07:29 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
