Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > Atomic, Solid State, Comp. Physics
Reply
image How to lower melting point of solids (TiO2)? Share It Thread Tools Search this Thread image
Old Nov9-09, 11:41 AM                  #1
paul143
paul143 is Offline:
Hi,
I'm currently doing experiments on a 99.9% TiO2 source powder.
I was wondering if there is anyway to lower the melting point of this solid?
If possible, without compromising its purity.
I only have access to an electrical furnace that is capable of reaching a maximum
of 1200 degC only. Seeing that this material has a melting point of around 1800 degC,
I am kinda stuck right now.
By the way, I also have access to a relatively primitive vaccuum technology. I tried
to seal my sample in a quartz tube then lowered the pressure inside up to around
10-6 torr. But I am not sure if this really has a significant effect, for I
have learned before that a change in pressure does greatly affect the boiling point
but I am not sure to the extent of its effect on melting point of solids.
Hope for any replies or suggestions.
Thanks very much for any information.
Old Nov9-09, 01:12 PM                  #2
kanato
kanato is Offline:
Re: How to lower melting point of solids (TiO2)?
I'm not sure if there is much that you can do. pressure can change the melting point, but the difference between atmospheric pressure and 10^-6 torr is quite negligible for a solid. If you could apply a pressure of 10-20 GPa that would be a different story, but it probably would not change the melting temperature in the direction you want!
Old Nov9-09, 03:02 PM                  #3
f95toli
f95toli's Avatar
f95toli is Online:
Recognitions:
PF Contributor PF Contributor
The melting point is an intrinsic property of a solid, it can't be change without somehow altering the material itself. Lowering the pressure won't have any practical effect on a solid (nor would increasing it unless we are talking about REALLY high pressures).
Old Nov12-09, 04:16 PM                  #4
ronaldlover
ronaldlover is Offline:
i agree.by changing the melting point then the composition as well, will change.
image image
Reply
Tags
melting point, pressure, titanium oxide
Thread Tools
Similar Threads for: How to lower melting point of solids (TiO2)?
Thread Thread Starter Forum Replies Last Post
melting point ProblemSets Other Sciences 8 Apr5-07 12:01 PM
melting point hediki Other Sciences 3 Mar25-06 09:52 PM
Melting Point andyman20 Introductory Physics 4 Jul13-05 10:32 AM
Melting point pitchharmonics Chemistry 1 Dec1-04 09:23 AM
Melting point of 40% Sn and 60% Pb Monique Chemistry 11 Oct10-03 12:12 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
