How is this transistor been killed?
  • Thread starter Thread starter LavennzOsy
    Transistor
The discussion centers on the failure of a transistor subjected to three specific tests. Tests 1 and 3, particularly when voltages are applied without current limiting, can lead to transistor damage. Test 3 is identified as the most likely cause of failure due to the absence of current control. The term "pump in correct voltage" refers to connecting the transistor to a supply voltage with low output impedance, which is crucial for understanding the conditions that lead to damage.
  • Understanding of transistor operation and characteristics
  • Knowledge of voltage and current relationships in electronic circuits
  • Familiarity with testing procedures for electronic components
  • Basic concepts of current limiting in circuit design
  • Research current limiting techniques in transistor circuits
  • Learn about the safe operating area (SOA) for transistors
  • Study the effects of voltage and current on transistor performance
  • Explore methods for testing and diagnosing transistor failures
Electronics engineers, hobbyists working with transistors, and anyone involved in circuit design and testing will benefit from this discussion.
LavennzOsy
This is a homemade failure and i need to find out how is the transistor damaged after summited to these 3 tests:
test 1. base: pump in correct Vbb
emitter: grounded
collector: open
test 2. base: open
emitter: open
collector: pump in correct Vcc
test 3. base: pump in correct Vbb
emitter: grounded
Can any1 explain to me how is the transistor damage by these tests.
Either of tests 1 and 3 could kill it if you just applied voltages without any respect to current levels. Test 3 is the most likely (almost garanteed to) kill it if nothing is provided to limit the current.
BTW. What was the value of Vbb that you used anyway?
How could test 2 possibly kill it?
I don't understand what is meant by "pump in correct [voltage]". So, I just assume that means connect to some supply voltage (with low output impedance as alluded to by uart).
  • · Replies 24 ·
