Some basic theory about drag coefficients of spheres.
This discussion centers on the experimental determination of drag coefficients for three spheres of varying materials and sizes (Teflon, aluminum, and steel) dropped in two fluids: water and sugar water. The spheres measured were 3.175 mm Teflon (0.05 g), 6.35 mm aluminum (0.375 g), and 12.7 mm steel (8.36 g). Key theoretical questions addressed include the oscillating paths of low-density spheres, the interaction of spheres with walls, and the angle of descent for streamlined bodies, with references to Kármán vortex streets and vortex-induced vibrations as critical concepts.
  • Understanding of drag coefficients and fluid dynamics
  • Familiarity with Kármán vortex streets
  • Knowledge of vortex-induced vibrations
  • Basic principles of lift generation in fluid mechanics
  • Research "Kármán vortex streets and their effects on falling objects"
  • Study "Vortex-induced vibrations and their applications in engineering"
  • Explore "Fluid dynamics of drag coefficients in different fluids"
  • Learn about "Lift generation in streamlined bodies and its implications"
Students and researchers in fluid dynamics, engineers working on aerodynamics, and anyone interested in the physics of falling objects and drag forces.
Vidatu
We did a lab where we dropped three spheres into two different fluids, measured their velocities, and found drag coefficients. We were also asked some theory questions, and these are what I need help with.
Spheres:
3.175 mm, 0.05 g Teflon
6.35 mm, 0.375 g, aluminum
12.7 mm, 8.36 g, steel
Fluids:
Water (density 998 kg/m^3)
Sugar water (density 1230 kg/m^3)
Questions:
1 - Why did some of the spheres of low density plastic follow an oscillating path as they fell?
2 - Explain why some spheres tended to bounce along the sides of the wall as they fell. In particular, explain what drew the spheres into the wall, and pushed them away after contact.
3 - Explain why a streamlined body can fall at an angle, rather than straight down.
I would guess that vortex shedding has something to do with the first two, but don't really know. Any help (or links to some sites with relevant theory) would be much appreciated. Thanks.
#1 Think about the pattern of Kármán vortex streets and the forces that would be created on a low density sphere.
#3 Think about how lift is generated.
Thanks, I got pretty good answers for those two now, just needed to prodded in the right direction.
As an FYI for anyone interested, I found some good info on this wiki page http://en.wikipedia.org/wiki/Vortex-induced_vibration. We were introduced to vortex shedding, but never learned about the lateral forces it can generate (those it makes sense intuitively).
Anyone have any help for question 2? It was a very pronounced effect, with the heavier balls at least. The steel sphere hit the wall before descending 15 cm, and hit hard enough to produce clicks audible across the room.
  • · Replies 28 ·
9K
