How to Integrate [1/(x^2 + 1)] dx?
The discussion revolves around the integration of the function \(\int\frac{1}{x^2 + 1} \ dx\), which falls under the subject area of calculus, specifically focusing on integration techniques.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss various methods for integration, including substitution and trigonometric substitution. Some express difficulty in eliminating the variable \(x\) from the integral. Questions arise about the effectiveness of these methods and the necessity of substitution.
The conversation includes multiple interpretations of the problem and various approaches being explored. Some participants suggest using trigonometric identities, while others reflect on the direct formula for the integral. There is no explicit consensus on a single method or solution.
Participants note constraints related to the forms of the integrals and the computational limitations of certain tools, as well as the desire to approach the problem in a classical manner rather than relying on direct formulas.
optics.tech
Hi everyone,
Can you tell me how to integrate the following equation?
[tex]\int\frac{1}{x^2 + 1} \ dx[/tex]
I've tried the substitution method, u = x^2 + 1, du/dx = 2x. But the x variable is still exist.
Also, the trigonometry substitution method, but the denominator is not in [tex]\sqrt{x^2 + 1}[/tex] form.
Thanks in advance
Huygen
Hi Huygen! :smile:
Try x = tanu. :wink:
Wait -- are you saying you tried it and failed? (If so, would you show your work, please?)
Or are you saying you didn't actually try it at all?
Don't you have an equation relating x to the variable you want to write everything in?
OK, as you asked for it:
FIRST
u = x^2 + 1, du/dx = 2x, du/2x = dx
[tex]\int\frac{1}{x^2+1} \ dx = \int\frac{1}{u} \ \frac{du}{2x}[/tex]
I can not do further because the x variable is still exist.
SECOND
[tex]x = tan \ \theta[/tex]
[tex]\frac{dx}{d\theta}=sec^2\theta[/tex]
[tex]dx=sec^2\theta \ d\theta[/tex]
[tex]x^2+1=(tan \ \theta)^2+1=tan^2\theta+1=sec \ \theta[/tex]
Then
[tex]\int\frac{1}{x^2+1} \ dx=\int\frac{1}{sec \ \theta} \ (sec^2\theta \ d\theta) = \int sec \ \theta \ d\theta= ln(tan \ \theta+sec \ \theta) \ + \ C=ln[x+(x^2+1)]+C=ln(x^2+x+1)+C[/tex]
If you applied the correct identity it might help . . .
[tex]tan^2(x) + 1 = sec^2(x)[/tex]
Your integral equation then becomes,
[tex]\int\frac{1}{x^2 + 1} \; dx = \int \, d\theta[/tex]
he he :biggrin:
optics.tech, learn your trigonometric identities ! :smile:
It's my mistake :redface:
[tex]arc \ tan \ x+C[/tex]
Isnt the answer just inverse tan x +C ? Why do you need to use substitution?
If you don't recognize the anti-derivative at first sight, the substitution allows you to evaluate the integral without too much difficulty.
This is a standard contour integral. Convert x to z and locate the poles at +/- i.
hi, This is an old thread.. So if u'd like me to post it elsewhere, do let me know..
I need to calculate the theta using inverse-tan. But since micro-controllers do not provide much computational freedom, I was looking to solve it as the integral of 1/(1+x^2).
Other than the fact that, integral of 1/(1+x^2) is arctan(x). But since i'd like to know arctan(x), could someone please help me to find the intergral in terms of x (non-trigonometric).
vish_al210 said:
… integral of 1/(1+x^2) is arctan(x). But since i'd like to know arctan(x), could someone please help me to find the intergral in terms of x (non-trigonometric).
hi vish_al210! :smile:
(try using the X2 icon just above the Reply box :wink:)
you could try expanding 1/(1+x2) as 1 - x2 - … , and then integrating :wink:
there is a direct formula for these kind of questins i.e integrate[1/(a^2+x^2)]dx = 1/a[arctan(x/a)]
so u can assume a=1...so ur ans vil b (arctan x)...jst dis..
welcome to pf!
hi kanika2217! welcome to pf! :smile:
kanika2217 said:
there is a direct formula for these kind of questins …
yes we know, but we're all trying to do it the way the ancient greeks would have done! :wink:
(btw, please don't use txt spelling on this forum … it's against the forum rules :redface:)
hi!
v olso have a drct frmila for these kind of ques...i.e.integration[1/(a^2 + x^2)]dx = (1/a)(arctan (x/a)...so you can assume a=1 here and hence the ans wud b 'arctan x'...
optics.tech said:
Hi everyone,
Thanks in advance
Huygen
The answer is : Ln (x^2+1)/2x
Welcome to PF!
Hi M1991! Welcome to PF! :smile:
(try using the X2 button just above the Reply box :wink:)
no, that's ln(x2 + 1) - ln(2) - ln(x) …
its derivative is 2x/(x2 + 1) - 1/x :wink:
Direct formula: 1/(x2+a2)=1/a * arctg( x/a ) to Integrate [1/(x^2 + 1)] dx
  • · Replies 105 ·
13K
  • · Replies 44 ·
  • · Replies 22 ·
  • · Replies 54 ·
19K
