Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Engineering > Electrical Engineering
Reply
image Help in finding R Thevenien? Share It Thread Tools Search this Thread image
Old Nov22-09, 08:18 AM                  #1
TipTip
TipTip is Offline:
The question is find R Thevenien using voltage test source across terminals a and b of the following circuit:
http://img255.imageshack.us/img255/8660/rthevenen.png
I did it by adding a 20 test voltage source and used mesh to get the following 4 equations of the 4 meshes ( I deactivated the 480 V independent source to be able to use test voltage method)
M1:6(x-t) + 40(x-y)+4x=0
M2: 40(y-x)+20=0
M3: 80(z-t) - 20q +2z-20=0
M4:4t + 8(t-z) +6(t-x)=0
q=x-t
I R thevenen to be 11.55 but actually the correct answer is 12 ohms.
Where is my mistake.
Old Nov23-09, 02:47 AM                  #2
The Electrician
The Electrician is Offline:
Re: Help in finding R Thevenien?
I don't see 4 meshes; I only see 3 meshes.
You need to explain in more detail what you are doing. What are x and y? I don't see anything labeled x and y on your schematic. You should tell me what they are, and don't expect me to figure it out for myself.
I would have used the nodal method, and select the node labeled b to be the reference (ground).
Then you can inject a test current of 1 amp into node a, and the voltage there will be equal to the Thevenin resistance (setting the 480 volt source to zero, of course).
image image
Reply
Thread Tools
Similar Threads for: Help in finding R Thevenien?
Thread Thread Starter Forum Replies Last Post
Finding the apparent magnitude of the sun, and finding Distances from it. TFM Other Sciences 0 May16-09 02:20 PM
Finding the Method of moments estimator? Having trouble finding E(Y^2) laura_a Calculus & Beyond 1 Aug9-08 07:57 AM
Finding L asi123 Calculus & Beyond 1 Aug3-08 03:16 PM
Finding the right ADC Jdo300 Electrical Engineering 11 Nov26-07 02:13 PM
finding the inverse and finding a matrix * A = 0 matrix mr_coffee Introductory Physics 6 Sep29-05 07:30 PM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
