Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > General Physics
Reply
image Space in an atom Share It Thread Tools Search this Thread image
Old Nov23-09, 01:30 PM                  #1
vibjwb
vibjwb is Offline:
Space in an atom
What happens to the space in two atoms that fuse together?
Fusion takes place inside the sun’s core from the protons of two atoms fusing together.
Is the new atom bigger or has the space between the nucleuses and the electrons remained the same and some space disappears?
Old Nov23-09, 06:13 PM                  #2
loreak
loreak is Offline:
Re: Space in an atom
I would think you would basically lose one atom of volume so the sun would physically be denser by volume overall.
However you have to remember that at the core of the sun the reason they are fusing is because the densities are so extreme as well as their kinetic energy from being so hot, but there should still be space being lost.
Old Nov24-09, 03:26 PM                  #3
FoxCommander
FoxCommander is Offline:
So to begin no its not the protons that are fusing, its two atoms that are fusing, just thought i should clarify.... Second, I think that If the outer layer of an atom could be though of as a ball if you put two balls together you will see that you cant just lose space, they will become a ball with twice the volume. I dont know If you have ever seen an H2O molecule in a science book or something but if you notice the Hydrogen atoms are very small compared to Oxygen atoms. If in fact space was lost inside of an atom when it was fused together then you will see that the Hydrogen and Oxygen atoms should be the same size..... Note that Oxygen was made by fusion, just like all other elements other than Hydrogen.
Old Nov24-09, 04:47 PM                  #4
loreak
loreak is Offline:
Oxygen is larger because ithas more electrons in higher orbitals so you are going to lose thenet difference between the 2 fused atoms. I was picturing 2 hydrogen atoms combining to form helium which still uses the first orbital but any element below iron can fuse
Old Nov24-09, 04:52 PM                  #5
DaveC426913
DaveC426913's Avatar
Best Humor 2009
DaveC426913 is Online:
Recognitions:
PF Contributor PF Contributor
The radius of an atom is largely dependent on its electron shells and how full they are in addition to the obvious one of atomic number.
Here are a couple of diagrams showing various radii of atoms as a function of their atomic number.
Note that in most definitely not a smooth curve from small to large. (The top chart reads from left to right then top to bottom, just like a book.) The sawtooth diagram at the bottom shows this very well.
Google or Wiki "atomic radii" for a more in-depth explanation as to how the radius changes with the element.
Old Nov24-09, 07:28 PM                  #6
FoxCommander
Never mind i was wrong about that, But to correct you in one fact, Iron can fuse but the only problem is that anything higher and including iron, when fused actually takes energy instead of giving off energy. It wouldnt make sense why we have elements bigger than Iron if anything higher than Iron could not be fused together
Old Nov25-09, 10:17 AM                  #7
loreak
loreak is Offline:
Well we were talking about fusion at the center of a star during normal behavior so Iron does not fuse specifically due to the reason you stated, all elements above that are created during more energetic events such as supernova. I wasn't saying it was impossible
Old Nov25-09, 10:39 AM                  #8
MikeyW
MikeyW is Offline:
We are talking about the sun with a core temperature of 10^6 K; photons of temperature any higher than about 3000 K are energetic enough to cause dissociation of electrons in hydrogen, so we aren't working with atoms but with a plasma of subatomic particles and highly energetic photons.
I think that sort of renders the question of "space" irrelevant since all the space in atom comes from the relatively large separation between electrons and nuclei.
Old Nov25-09, 11:28 AM                  #9
Math Jeans
Math Jeans is Offline:
I agree with Mikey on this. The term "space" needs to be clarified as space between the electrons and nuclei, or space taken up by the actual guts of the atom (particle, whatever).
Old Nov25-09, 11:58 AM                  #10
loreak
loreak is Offline:
yeah I didnt think about that, the sun is a plasma so its simply free floating nuclei coalescing.
Old Nov25-09, 12:10 PM                  #11
Naty1
Naty1 is Offline:
Post #8 has the right idea...the original question of "atoms" in fusion is incorrect since it is nucleii that fuse, not atoms.
The fusion of lighter nuclei, which creates heavier nucleii and free neutrons also complicates comparisons. The strong force, electromagnetic force, binding energy and energy levels operate in complex ways. In addition, some mass is actually converted to energy (is it maybe a few percent?) so I don't know how all those things net out. I am unsure if quark spacing within neutrons and protons always remains fixed; I suspect so.
Old Nov25-09, 12:42 PM                  #12
MikeyW
MikeyW is Offline:
I don't know exactly if heavier nuclei are more dense than lighter ones.. you have some conflicting terms due to electrostatic repulsion, strong quark confinement, etc., seems way beyond what I have learnt. In any case I think the size of any change in radius of the nuclei is totally and utterly negligable compared to their mean free path, of even perhaps their de Broglie wavelength!?
image image
Reply
Thread Tools
Similar Threads for: Space in an atom
Thread Thread Starter Forum Replies Last Post
where is the higgs boson located in the atom? or is it even in the atom? neutronstar11 High Energy, Nuclear, Particle Physics 2 Nov24-09 02:29 AM
one atom in space what happens Quantom Quantum Physics 2 Aug18-09 01:38 AM
Space in an atom vibjwb General Physics 3 Mar3-09 08:17 PM
Higgs Boson and Space in an Atom Noj Werdna Beyond the Standard Model 4 Jun6-08 11:29 PM
Lattice Waves: Atom Chain Fixed at Ends or Free is Space? dimensionless Atomic, Solid State, Comp. Physics 1 Apr19-07 05:40 PM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
