Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image signal processing fft Share It Thread Tools Search this Thread image
Old Nov24-09, 02:23 AM                  #1
singedang2
singedang2 is Offline:
hello!
i'm given a signal h(t) = v(t)*g(t)
where g(t) is a distortion/noise that got added
and has a very low frequency compared to v(t)
i need to devise a method to clean up g(t)
i'm thinking of to do the fft on the signal h(t),
and remove the lower frequencies and do the inverse fft,
but this might not just remove g(t), but it may as well remove v(t)
any hints?
Old Nov24-09, 04:37 AM                  #2
MikeyW
MikeyW is Offline:
Re: signal processing fft
I haven't studied this in any good detail, so my answer is not going to be the best. But I think your solution is correct, and that the problem with this is a fundamental problem with removing noise. I have been searching my files because I remember reading all about this, but I can't find what I read anywhere.
I think the answer is in choosing the right method of suppressing low frequencies, for example, multiplying the Fourier transform by some function which is inversely proportional to frequency.
I wish I had this book though! By the way, is * a convolution in your notation or multiplication?
Old Nov24-09, 01:45 PM                  #3
berkeman
PF Mentor
berkeman's Avatar
berkeman is Offline:
Originally Posted by singedang2 View Post
hello!
any hints?
I have the same question as MikeyW. You say in your post that g(t) is added, but are using * as the combination symbol. If the g(t) is just added, and is lower frequency, they it seems that running h(t) through a DSP highpass filter would do what you want?
Old Nov25-09, 12:47 AM                  #4
singedang2
sorry for the confusion. it's a multiplication. by 'add' i meant the two signals got mixed altogether.
Old Nov25-09, 02:16 AM                  #5
berkeman
PF Mentor
berkeman's Avatar
Why are they multiplied? Where is the non-linearity? Or is this just a coursework exercise? What is the context please?
Old Nov26-09, 07:54 AM                  #6
singedang2
i don't know about the non-linearity. this is for a course, and we've only learnt fft and some fourier analysis.
the questions is we're suppose to receive am radio singal, but due to atmospheric/weather condition, loudness of the signal changes.
so the original signal we wanted to receive was v(t), but instead we get v(t)*g(t),
and g(t) has relatively low frequency compared to v(t).
Old Nov26-09, 08:01 AM                  #7
MikeyW
MikeyW is Offline:
Can you double check that it's not a convolution?
If you multiply two functions v(t)g(t) would be my notation, to me v(t)*g(t) suggests convolution, especially in signal processing... is the question in original form specific about what the symbol "*" means?
Old Nov26-09, 09:21 AM                  #8
singedang2
i've checked and it's multiplication, NOT CONVOLUTION. so v(t)g(t), instead of v(t)*g(t).
Old Nov27-09, 12:05 AM                  #9
singedang2
i was able to solve this problem.
the key was to take log of the function.
then it becomes logv(t) + log(g(t))
then we do the usual fft then do the filtering, then do inverse fft to get back the original signal.
Old Nov27-09, 12:15 AM                  #10
mheslep
mheslep is Offline:
Well you would not have the original signal, you would have log( original signal ).
BTW, as pointed out above the expression v(t) times g(t) is not an addition of noise, it is a modulation, a non-linear operation for any non-trivial g(t). No linear filter operation will recover the v(t). You'd need another non-linear operation to recover v(t), such as a demodulation.
image image
Reply
Thread Tools
Similar Threads for: signal processing fft
Thread Thread Starter Forum Replies Last Post
Signal Processing Tac-Tics Calculus & Analysis 4 Dec25-08 12:55 PM
Signal Processing FFT help kpcheah Engineering, Comp Sci, & Technology 1 Jul22-08 01:55 PM
Signal Processing FFT help phenommsu1 Electrical Engineering 4 Apr1-08 09:54 AM
Signal Processing babistopher Programming & Comp Sci 5 Dec12-07 11:46 PM
Signal processing inadaze Computing & Technology 5 Jul7-04 09:40 AM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
