Cesiumfrog you are right. I made a big mistake in my previous argument. I previously argued that the surface tension force of a meniscus is balanced by the static water
pressure so that the perpetual motion boat is impossible. I think that argument is correct as far as the perpetual motion boat is concerned. Cho's boat is different in that the meniscus at the back is moving up and down. So I did the following experiment:
A loaded triangular paper boat is put in the middle of a basin of water. A pencil parallel to and near the back of the boat is pushed into and out of water at a rate of about twice a second. The boat is observed to move forward until it hits the wall in a few seconds.
Surface tension force does not seem responsible for the propulsion of the paper boat above. My explanation is as follows. When water is pushed downwards quickly, it is pushed against surrounding water which is quite heavy and viscous, so the water pressure nearby increases considerably, and it is this pressure that propels the boat. When water is drawn upward, there is negative pressure, but that pressure is limited - the pressure at the back of the boat cannot be lower than the atmospheric pressure by any significant amount, while the pressure built up at the front is small because of the boat's slow speed. As a result, the boat gets a big push and small pull in each cycle. This propulsion mechanism can also account for the larvae's locomotion.
Thus, while Cho's invention is sound, his explanation is dubious, and I proved myself a fool B:(.
Wai Wong
