RF 5 GHz circuit design |
Nov26-09, 12:45 PM
#1
vaka85 is
Offline:
Hi all,
I don't know if it's the right section in the forum, but here is my problem.
I have to design a small pcb working at about 5 GHz, and I don't know how to start exactly...
It's very simple, 2 sma connectors and 1 resistor. Here is the schematic:
And here is what I've done sofar in Microwave Office... but in this step there are some problems for sure...
Anybody knows how to proceed in microwave office (or similar software)? I need help because this topic isn't covered so much on the web...
thanks
Nov26-09, 12:59 PM
#2
f95toli is
Offline:
Re: RF 5 GHz circuit design
What exactly are you trying to simulate? I.e. which effects are you after?
The main question is you need a realistic simulation of the resisitor (with all stray effects)?
You don't really need Microwave office for the rest, just decide on what type of connector and PCB (e.g. Rogers XXXX) you need as well as the type of transmission line (if you want to terminate one end e.g a coplanar waveguide would work, unless you really want a via for some reason, but beware of parasitics). Then you just draw the circuit, as long as you avoid sharp bends this will be accurate enough.
You can calculate the parameters of the transmission line using for example TXLine (free software, made by the same company that makes Microwave Office).
However, if you want to simulate the "full" resistor things get more complicated. I guess you are planning to use a small SMD resistor, right? Do you have a circuit model for it?
Nov26-09, 01:18 PM
#3
vaka85 is
Offline:
sorry, you're right, I've forgotten to say some things...
1. I don't have to do a simulation.
2. I have to design the pcb from the beginning. I have FR4 as substrate, 2 SMA connectors, and one SMD resistor. That's all.
The project specifics are:
- About 4.5 GHz ( Not so strictly specific, also 4 or 5 GHz would be fine )
- 50 ohm impedance for the entire circuit.
I don't know if use microstrip technology or something else... any advice? Coplanar could be also ok( maybe in this case I can avoid to insert vias... )?
And if I estimate the width and the length of the tracks with TXline, then I can make the pcb with a normal pcb software? (obviously setting the correct values of W and L)
(sorry for my bad english)
thank you very much, these informations are very useful for me...
Nov26-09, 02:21 PM
#4
f95toli is
Offline:
OK, my suggestion would be to use a coplanar transmission line (CPW) since you then won't have to use vias.
And yes, once you have the dimensions of the line you can just use normal PCB software. That is what I always do with simple things like this.
One "trick" you can use when drawing CPW using normal PCB software is to set the width of the interconnects in the software equal to the widht of the centre line and then set the parameters for "copper pour" so that the distance between copper and interconnects is equal to the centre-line <->ground plane distance of your CPW. This makes it easy to draw bends etc.
BTW, FR4 isn't exactly a great material at 5GHz.
Also, what is the value of your resistor? I just noticed that you have R=1M in your simulation which doesn't make much sense, I am guessing it should be a 50 ohm resistor, right?
Nov26-09, 03:20 PM
#5
vaka85 is
Offline:
first of all: so many thanks! :)
I've don't understood exactly your trick, however tomorrow I'll study it better (now in Italy it's 9 pm ---> tired ..)
I'll make a test pcb and I'll show to you...
FR4 isn't great but, unfortunately, at the moment is the only material available...
The resistor is 1Mohm.
Why? I try to explain: I have a switch, on another pcb. It has 1 input (from an antenna) and 2 outs, the 2 outs go to this pcb I'm designing.
One sma goes to ground, to shortcircuit the antenna.
The other sma goes to an high resistance, to simulate the "open-circuit antenna condition".
I hope I made myself clear...
However, any advice to make a better design/schematic would be very useful.
The main goal is to switch the antenna from 2 positions: open and short-circuited.
thanks again
Nov27-09, 04:30 AM
#6
vaka85 is
Offline:
I've tried some variations on txline. here is the result:
What's your opinion?
(substrate fr4 wasn't in the list, so I've chosen another one, but with correct dielectric constant).
One more thing (maybe very stupid but very important for me):
The length (10mm in this case) is the lenght from connector to sma resistor or the length from connector to ground (resistor included)?
i.e.:
maybe it's a very stupid question because the track length from the resistor to ground should be zero, considering that this is a coplanar pcb...
thanks again
Nov27-09, 08:55 AM
#7
f95toli is
Offline:
That looks reasonable. Note that you can enter the material parameters yourself in txline
My guess is that the length isn't very relevant for you unless you are worried about the phase shift for some reason (the electrical length); but if you know exactly which frequency you will be working at it might be a good idea to think about where you want to place the resistor with respect to the nodes on the line.
Speaking of the resistor, I doubt there is such a thing as a 1MOhm resistor at 5 GHz, the parasitics in a real resistor will effectively shunt it meaning the impedance will be much lower than 1 MOhm, probably only a few hundred ohms.
Is there any reason why you can't just leave the line open?
Nov27-09, 09:08 AM
#8
vaka85 is
Offline:
really a few hundred?!?
there isn't a reason why I use a resistor instead an open line.. however if you say that the resistor behavior is that little value, so I can left the line open.
In this case, how far must be the open line from the ground plane? the value G (gap from line to ground) right? However, maybe the open line is only the connector...
Last thing: if I don't use the resistor, W and L are useless... I connect directly the sma connector to the ground plane... Is this correct?
If I understand these things then I can make the pcb...
Thanks
Nov28-09, 12:47 PM
#9
f95toli is
Offline:
Don't take my word for it, I've never even tried using a resistor that large at a few GHz; but I would be surprised if you get anywhere near 1Mohm. You basically have to find the datasheet for the resistor you are planning to use. Also, how you solder it etc will have a large effect on the result. You can download some applications notes about using SMD resistors at MW frequencies from e.g Vishay, although they will mainly deal with lower values.
You need a computer simulation to say for sure, but I'd say a gap of W should be OK.
Thanks
No, remember that at these frequencies the line itself will be a "component" (a common component in MW applications is the "stub", which is quite literally just a line) , both the open and the shorted line will for example give you resonances (just calculate the wavelength and you'll see why) of etc so it is definitely not the same thing as just a connector.
Nov28-09, 12:51 PM
#10
vaka85 is
Offline:
Ok, I've understand.
Next days I'll try to make a pcb, then I'll show the result.
Thank you very very much!
Dec1-09, 08:51 AM
#11
vaka85 is
Offline:
Hi!
Here are the 2 layouts: (dimensions are not real and connector picture is only to understand where it is the sma connector)
sma short-circuited:
sma open:
Whant do you think about them?
Thanks
Dec3-09, 06:51 AM
#12
vaka85 is
Offline:
last step please :)
Dec3-09, 04:28 PM
#13
waht is
Offline:
you have an open and a shorted transmission line, is it time to test it?
Similar Threads for: RF 5 GHz circuit design
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
circuit design
daniel_i_l |
Electrical Engineering |
4 |
May11-09 03:12 AM |
circuit design help
danonymous |
Engineering, Comp Sci, & Technology |
1 |
Nov5-08 08:41 AM |
Circuit Design
scott_alexsk |
3 |
Mar23-08 03:58 PM |
How to design this circuit?
L_Kuan |
0 |
Dec14-07 01:05 PM |
Circuit design
Serj |
12 |
May14-05 04:09 PM |
