Thread Closed
Lagrange multipliers with two constraints
Share Thread Thread Tools
Dec10-09, 02:59 PM   #1
1. The problem statement, all variables and given/known data
By using the Lagrange multipliers find the extrema of the following function:
f(x,y)=x+y
subject to the constraints:
x2+y2+z2=1
y+z=1
2. The attempt at a solution
Using lambda = 1/(2x) I got x=y-z and y=1-z
plugging that into the first constraint, I got:
6y^2-6y+1=0 which makes y=0.5+-(31/2/6)
I got the same thing when solving for z, which means x=0 and lambda = infinity, which doesn't make sense.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Dec10-09, 04:07 PM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
You've also got z=1-y. So if you choose the root y=(3+sqrt(3))/2 you have to choose z=(3-sqrt(3))/2 not the other root for z. You can't mix and match any two roots with each other.
Dec10-09, 04:31 PM   #3
Ah, I forgot to distribute the negative! I hate when that happens...it's all worked out now, thanks a lot!
Thread Closed
Tags
constraints, lagrange, lagrange multiplier
Thread Tools
Similar Threads for: Lagrange multipliers with two constraints
Thread Forum Replies
Lagrange multipliers Calculus 1
LaGrange Multipliers Calculus & Beyond Homework 3
Lagrange Multipliers. Calculus 0
Lagrange multipliers Calculus & Beyond Homework 1
Lagrange multipliers Calculus 11
