Thread Closed
Formula for Density
Share Thread Thread Tools
Mar7-10, 02:03 PM   #1
Formula for Density
Hello;
I know that the formula for density is mass/volume. However, this is only true for rest mass. What about when the particle is moving?
Thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Intel's Haswell to extend battery life, set for Taipei launch
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
Mar7-10, 02:07 PM   #2
Mentor
This opens up the whole can of worms about the different kinds of mass in relativity. I suppose the answer would depend on what you want to use the density of the moving object for.
Mar7-10, 02:38 PM   #3
Mass increases with velocity, right?
Do I have to use Einstein's General Theory of Relativity and somehow use that with my original density formula? I'm confused
Mar8-10, 01:24 AM   #4
Formula for Density
Note that the particle itself would not know if it is moving or not, unless it was being accelerated. So according to the particle, it's density would not increase.
However, from the viewpoint of an external observer, it could be said that the density of the object had, in a way, increased.
In the end, whether this density is what would fit in with your usual concept of density or not, depends on what you want to use it for, as jtbell said.
Mar17-10, 02:44 AM   #5
I don't get it... what do you mean by this?
Thread Closed
Thread Tools
Similar Threads for: Formula for Density
Thread Forum Replies
Gravity/Density formula Classical Physics 0
Pretty basic chem/density problem: finding density of irregular shaped soluble solid Chemistry 1
calculating the redshift at which radiation energy density equaled mass density Cosmology 4
Bariometric formula in Statistical Physics (particle density per unit volume) Advanced Physics Homework 4
what is the essentail difference between local density of states and density of state Atomic, Solid State, Comp. Physics 2
